Projects The Quaran-T T Bucket Build
Discussion in 'Traditional Hot Rods' started by gonzo, Feb 14, 2021.
  1. 210superair
    210superair
    from Michigan
    Looks beautiful man!
    Stogy, loudbang and gonzo like this.
  2. gonzo
    gonzo
    Thanks! I'm pretty happy with it so far. Can't wait to put some real shakedown miles on it.
  3. swade41
    swade41
    from Buffalo,NY
    Looking good, brings back a lot of memories building mine, I used all marine wood and epoxies I got from the local boat builder supply warehouse and it's been holding up great for the last 15 years.
    I also made a metal tie bar behind the dash with plates welded on the ends, it sandwiched the body between it and the windshield posts, my theory was to support the windshield and prevent cracks in the body.
    As I get older and more physically challenged I wish I would've put working doors on mine, sure is a fun car though. Good luck with yours.
  4. Paul
    Paul
    Editor
    They look perfect
  5. gonzo
    gonzo
    Thanks Paul. The slicks were an essential piece.
    I do kind of wish I'd done a four bar set up like you did on the 27 your building but using the hairpins was a lot easier.
  6. RodStRace
    RodStRace
    Really glad to see the progress. I enjoyed it in the ugly thread, but you have done us all a service starting your own thread.
  7. bchctybob
    bchctybob
    You did a fantastic job of bringing it back to life, great proportion's!
    Stogy, J.Ukrop, loudbang and 2 others like this.
  8. patmanta
    patmanta
    from Woburn, MA
    Man, finally a build thread on this one! Subscribed!
    Once we get our shots come take a rip up 95 and swing by some time soon. My car is blown apart still but I'm catching up to you (no I'm not).
    Oof, I used that nasty automotive stuff to patch the bumper on my mom's old 94 ****** wagon when she backed it into who-knows-what and it was a horror show. I got it done, but not without dropping my gl***es in the resin. The finished product looked like the car had a tumor. Never. Again. Thanks for the tip on the marine grade stuff.
    chryslerfan55, Stogy and loudbang like this.
  9. gonzo
    gonzo
    Thanks Pat. I can't wait to get the whole plague business in the rear view mirror. Working from home has been great but it'll be even greater to be able to go out to some car shows and visit without the worry of creeping death.
  10. dirt car
    dirt car
    from nebraska
    Curious to know what rim width you happen to use on your rear slicks, looking to find similar slicks compatible with my 5" wide rims Thanks, Ron
    Stogy, gonzo and loudbang like this.
  11. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    you really make me wish id shortened my frame like yours too. LOVE that stance!
    gonzo, loudbang and High test 63 like this.
  12. flatheadpete
    flatheadpete
    from Burton, MI
    I second that....Sits really nice with everything in the right place.
    Stogy, gonzo, loudbang and 1 other person like this.
  13. gonzo
    gonzo
    They're '62-'64 Chevy wheels, which can be id'd from the two nubs near the valve stem. With the tires mounted it's hard to tell exactly how wide they are but a quick google search suggests they're about 6". Your five inch wheels might be a little narrow for 8" slicks, I'd find a wider pair if possible.
    Thanks. Yeah the front mount was only tack welded on when I decided to cut it off. If I'd been much further along I would have been pretty reluctant to undo all that work.
  14. Stogy
    Stogy
    @gonzo, the trip back in time is Hambtastic...big thumbs up from this front row seat...;)
  15. dirt car
    dirt car
    from nebraska
    Thanks Gonzo, I thought you might have the 6" wide rim as well, I had my rims powder coated so might ck. with the Towell City boys & see what is available altho didn't see anything on the web. Thanks again
    gonzo, loudbang and Stogy like this.
  16. Hot Rod Nut
    Hot Rod Nut
    Nice work on the T, glad your bring it back to life.
  17. gonzo
    gonzo
  18. gonzo
    gonzo
    Taking the T on progressively longer test drivers. So far it's running great.
    F8F13100-9ED5-4A17-B4F0-93C017CBC5D2.jpeg 875CBDE8-3985-4F3A-A460-9CBAA1EE26A6.jpeg E6ED6BD4-7E7E-40A4-82D9-D34FEEB375DD.jpeg
  19. 32 hudson
    32 hudson
    Cool !! I like this bucket. It has character.
  20. AHotRod
    AHotRod
    Man I love it !
    You've done it Spot-On .
    It's got "Style" !!!
    chryslerfan55, loudbang and gonzo like this.
  21. I really like the looks of your T. You did a fine job.
    What is the width of your rear axle?
  22. gonzo
    gonzo
    It's a 58 Chevy rear with 325 gears and a posi. I'll need to measure the width tomorrow but google tells me it should be about 60" (I'm guessing that's flange to flange).
  23. gonzo
    gonzo
    @Jrs50 its 52" between the backing plates.
    loudbang and Jrs50 like this.
  24. gonzo
    gonzo
    Took it out for about 10 miles tonight to run some errands with no failures to report. I'll need to dial in my kick down linkage and I really need my interior back because riding around on patio furniture cushions is not going to cut it.
    Sadly I forgot my phone at home because it looked really sweet under the street lights in the parking lot. This one from the garage will have to do.
  25. Thank you.
    I ask that because your proportions look good. However, my turtle deck is 33" wide. 9.5 inches on each side just seems wide.
  26. Stogy
    Stogy
  27. RodStRace
    RodStRace
    Jrs50, get the wheels and tires you want to run and stand them up in position to the body. Look at the combo from as many angles as you can, adjusting for best look. Leave a bit of room so you don't rub from tire flex. Once you have determined where, measure from inside wheels. That's the width you want. Do a search for "rear axle ** inches wide" and see if there is a stocker that will work without making a custom width.
    Gonzo, great job bringing a garage refugee back to the street!
  28. gonzo
    gonzo
    Thanks Rod
    @Jrs50 you can also play around with some custom backspacing depending on the type of wheels you plan to run.
    Stogy, loudbang, Jrs50 and 1 other person like this.
  29. rustydusty
    rustydusty
    Your T is really shaping up! These things are just a "blast" to drive, aren't they? Still find it scary on the highway, guess I'm just getting old...
  30. gonzo
    gonzo
    I actually haven't had it on the highway yet but I have performed a few "stress tests" on the drive train. It's definitely a blast to drive but it gets scary when I manually shift it into second. It's a lot more comforting to have two hands on the wheel.
