Projects 1930 Road King... from pieces.
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Jan 17, 2021.
  1. sloppy jalopies
    sloppy jalopies
    Just another coupester but has a few roadster parts...
    rough '32 frame, A crossmember, '30 cowl, '29 stanchions, capped '30 coupe doors, '30 roadster rear clip,
    F1 dash, '30 grill, '30-'31 hood, deitz head lights...
    DSCN5798 (1).JPG .
  2. I'm sorry sir, but frame swaps aren't allowed here, not my rules, I'm just p***ing it along :p:D looks like the beginning of a helluva good time to me;)
  3. sloppy jalopies
    sloppy jalopies
  4. hotrodjack33
    hotrodjack33
  5. sloppy jalopies
    sloppy jalopies
    Going to graft the trailing 4"> 2" of a '30 closed car cowl to the leading edge of a '30 roadster quarter...
    making a transfer from closed car to roadster beltlines by diminishing the smaller, lower bead and letting the trailing edge of the door fit flush...
    will also let me use the CC A pillar as the new B pillar... stronger than the roadster's B pillar...
    will need to shorten the roadster quarter the door difference plus the 2" or so of cowl metal...will have about 5" from the roadster's B pillar back, for sale or trade...
    using the CC cowl section will mean it needs to be sectioned about 5/8" the thickness of the to be removed lower beltline bead... pix when i do that...
    View attachment 4951961 View attachment 4951962 DSCN6445.JPG DSCN6446.JPG DSCN6447.JPG View attachment 4951966
  6. AHotRod
    AHotRod
    Ya got the makings for a Hot Rod there buddy!
  7. hotrodjack33
    hotrodjack33
    A lot of really neat work to actually make it a roadster, instead of just another coupester, Pretty damn impressive.
  8. sloppy jalopies
    sloppy jalopies
    Thanks 33,
    Not just the cost of roadster parts, but the longer coupe doors [27.5"], [roadster 24"] are a plus for a "big man"...
    Going to keep the ****pit the roadster size [5" less than coupe] with big man doors...
    subfloor build 1/2 old and rotten, 1/2 new home fabbed steel, pix to come...
    Runnin shine, winduptoy and loudbang like this.
  9. sloppy jalopies
    sloppy jalopies
    boom !
    because i was cutting off the subfloor for the '32 frame kicks i didn't need the subfloor's rear half,
    well this subfloor didn't have a rear anything...
    had to scab in some patches just to get to the frame kick-up sections...
  10. sloppy jalopies
    sloppy jalopies
    Home made subfloor kick-ups, [ brake and shrinker]...
    the kick ups are made from 2 layers of 90* bent strips and a buddy's shrinker...
    drilled holes to rosette them together,
    LT. eye surgury thursday,
    can't go anywhere till then [covid test/ quarentene]...
    didn't want to run out of shielding gas... tacks only till then...
    not building the rear of the floor till i put the body on... rectangular pan to hold the battery, cables, toolbox, water jug... etc...
  11. sloppy jalopies
    sloppy jalopies
    Cut the roadster quarter, trimmed it to fit the '30 A closed car cowl's trailing 4.5" plus i kept the A pillar.
    the A pillar is much more rigid than the roadster's B pillar...
    yes i am as guilty as the next guy... you can see where i added the door offset when i should have subtracted it... errrrrr !.
    DSCN7451.JPG View attachment 4992667 View attachment 4992668 View attachment 4992665
  12. wheeldog57
    wheeldog57
    SMITTY!!!
  13. 48fordnut
    48fordnut
    Keep after it.
  14. sloppy jalopies
    sloppy jalopies
  15. hotrodjack33
    hotrodjack33
    This one cool "big door" roadster build:cool:.
    I'm subscribed:D
    sloppy jalopies likes this.
  16. Paul Crane
    Paul Crane
    from Montana
    Great post and pics! Can't wait to see how it turns out. Bringing a hotrod to life out of parts.
  17. roll of the dices
    roll of the dices
    Keep up the great work. Subscribed
    loudbang and sloppy jalopies like this.
  18. toddwkman
    toddwkman
    cool... keep updating with pics
  19. sloppy jalopies
    sloppy jalopies
    Following "roll the dices'" lead with a "sloppy" parts list...
    of co**** i am at the lower end of $ investment scale...
    i don't keep track of labor $ as i am retired and like "most" of the work...
    parts cost so far ;
    '32 frame -$600, sold the rear X mem. for $100...
    'A - H/L bar "stands" + Deits 7" h/l pr. -$75 ...
    '30 grill - $100...
    front X mem. - 75...
    2"x 4" tube rear X mem. - $20...
    '30 closed car cowl - $100... firewall stashed...
    '30 dash rail... - $75 ...
    '28-'29 roadster stanchions - $150...
    '32 comm. w/s frame - $200...
    '30-'31 coupe doors LT. - $100... RT. free, w/ a new belt down skin -$75 ...
    "Spanky's door caps - $50 pr.
    '30 cpe. pr. of "no roof" qtrs. - $500... traded for '30 roadster qtrs...
    '30-'31 above deck panel... - $100...
    '30-'31 below deck panel... $125...
    '30 subfloor, rusty front half. - $50...
    home made rear subfloor kick ups - $15...
    'A front suspension . - $100...
    'A front frame horns, as rear '32 frame horns - $50...
    total parts ; $2,255 old math ?
  20. sloppy jalopies
    sloppy jalopies
  21. roll of the dices
    roll of the dices
    Love it! Great job!! Keep the progress going.
  22. sloppy jalopies
    sloppy jalopies
    Been a while as i slowly got over pooching the roadster / sport coupe splice...
    A much appreciated hamber gave me my money back on the r. qtrs...
    Back to using a pair of sport coupe quarters i had planned on using on another "coupester"...
    Has plenty of dings, welding pin holes and some lower rust out...
    Had a nice tulip, thanks hamber.. bought a repop lower panel...
    >>>>Deck needs the lower 1"-2"... anyone making that patch ? <<<<
    DSCN7562.JPG DSCN7561.JPG DSCN7560.JPG DSCN7563.JPG DSCN7559.JPG DSCN7558.JPG DSCN7557.JPG DSCN7564.JPG
  23. Shaping up to be a fun car.
  24. buckwild27
    buckwild27
    Making some great progress can't wait to see it finished
  25. sloppy jalopies
    sloppy jalopies
    i am shooting for a one piece body, swinging doors, patch panels, bus seat on '32 rails...
    will try and trade it for a year's taxes...
  26. sacminiwheels
    sacminiwheels
    Very cool!
  27. hotrodlane
    hotrodlane
    looks cool
  28. nuppi
    nuppi
    Great work!
  29. 48fordnut
    48fordnut
    Amazing innovation. Great work.
  30. sloppy jalopies
    sloppy jalopies
    Thanks boys !
    Trimmed my A frame horns, flipped then upside down, leved and tacked...
    buddy gets me the 1.5" stainless pipes the dr.'s equipment adjusts on, use as my spreader bars...
    will need the difference in frame rail thickness filled in... will support the back half of the trunk and the spreader bar... didn't have to rebuild the lower body to clear the '32 rear frame horns...
