Hot Rods HAIRPINS!!!!!!!!!
Discussion in 'The Hokey Ass Message Board' started by porknbeaner, Mar 10, 2021.
  1. blvdbill
    blvdbill
  2. 1971BB427
    1971BB427
    from Oregon
    The hairpins that came with my neighbor's tube axle have two cross braces. One straight up, and a 2nd one welded aat an angle about halfway forward. Most have none, or just one, and I prefer at least one close to the middle, or slightly forward of middle.
    Desoto291Hemi and nochop like this.
  3. Old Tony
    Old Tony
    from Benton, AR
    Thanks for responding. Makes sense...good info
  4. Blues4U
    Blues4U
    from So Cal
    Front hairpins are left unbraced intentionally, especially with a tube axle, to allow some give when the axle moves vertically on one side only, since the axle itself cannot flex, and something has to give, so the hairpins provide that. This is less of an issue with a beam axle as the axle itself will give. Rear hair pins are usually braced because they are under more stress due to handling the torque loading from the power train.
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
  6. SEAAIRE354
    SEAAIRE354
    @blues4you thanks for the explanation on tube axles as I’ve been wondering the differences other the than the obvious. As I mentioned earlier I’m considering doing away with my 4 link and using hair pins. I like the function of the 4 link but on a fender less car it just isn’t working for me. And @porkn****** thank you for starting the thread. It was perfect timing.
    porknbeaner and Blues4U like this.
  7. the37thstreet
    the37thstreet
    Picture 439.jpg Designed and built from heavy boiler tube. Picture 290.jpg 055.JPG
  8. That looks like an upside down 8 in a cl***ic Ford V8 emblem.
  9. the37thstreet
    the37thstreet
    That is what I used for the look. Early Ford V-8 Emblem. Good Eye.
    HemiDeuce likes this.
