Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. loudbang
    Well that big move it FINALLY under your belt congrats. :)
    Stogy, 33Doll and brady1929 like this.
  2. 33Doll
    33Doll
    Tanks!
    Cant wait to get that Bronco done, and sold sold so Incan get back on it!
    chryslerfan55, Stogy and loudbang like this.
  3. roll of the dices
    roll of the dices
    Congrats! Finally done and can now put it behind you.
    I am still waiting for Sacramento to finish processing my YOM plates :-(
  4. 33Doll
    33Doll
    Getting some headway on my “other” temporary project! Hopefully soon I’ll be done, it’s looking good, turning out good.
    I couldn’t believe that this carburetor actually made fuel go through! It was so full of sludge and dirt in brush hair and I don’t even know what the hell is in there! Couldn’t even see the Jets!
    I’ll have to say, I’m real impressed with Carter/Edelbrock carburetor‘s! They are tough as nails!!!
    I’m real curious to see how it’s going to run after I get this back together IMG_1704.JPG IMG_1718.JPG IMG_1706.JPG IMG_1719.JPG
    Desoto291Hemi, AHotRod, brEad and 2 others like this.
  5. 33Doll
    33Doll
    F$&&&kkk!!!!!
    Damn! Needle Bearings Fell out Trying ti put the ****** Back in the B$&@@co!
    Now I have to rebuild the whole damn thing, had to cut off the bearing on the back get it apart!!!!!
    Oh well there’s a few broken clips and things anyway!!!!! IMG_1867.JPG IMG_1871.JPG IMG_1870.JPG IMG_1872.JPG IMG_1861.JPG
  6. 33Doll
    33Doll
    It was a good thing though, the snap ring broke on the inside shaft were the synchro rides, and it was forcing the cone into the inside getting it really hot you can see the bluing.
    Desoto291Hemi, loudbang and dumprat like this.
  7. RodStRace
    RodStRace
    The trans builders I watched used a red ***embly grease to keep them stuck in place.
  8. dumprat
    dumprat
    from b.c.
    Probably a good thing you took it apart!
    loudbang and Algoma56 like this.
  9. dumprat
    dumprat
    from b.c.
    I use red and tacky, cause it's sticky. It's not magic and has worked on quite a few trans and lots of transfer cases.
  10. 33Doll
    33Doll
    Thanks!
    I got some really thick purple stuff we use at work!
    I used on the transfer case, because of course they all fell out first!
    I took everything off in sections because everything is cast-iron and heavy as hell, I guess I have to leave the adapter on the transfer case!
    Der! I forgot the input gear is on it!
    Trying to bench press all that stuff Up into there like an idiot!
    Of course I got rid of my ****** jack adapter when I moved!
    One roller/needle bearing was missing or lost. So I’m kind of proud of myself, I took a drill bit that was the same size as the missing one, and cut it down and made it fit, you couldn’t even tell! Plus I figure it’s hardened! Should be fine. (Red-neck engineering)
    At first I was having fun working on this vehicle, but now I just want it the hell out of here!
  11. 33Doll
    33Doll
    I’ve been learning Stuff!
    Now I can do a C-4, early Ford, 3 speed, and a later Ford 3 speed!
    I made a dummy shaft for the cluster shaft, made life a lot easier, plus the needle bearing kit I got they are slightly tight on purpose, so they can’t fall out, even without
    The Grease. Put some in anyway.
    (The Zip ties are so the shaft can not pop out on me again, while putting it in!)
    IMG_1878.JPG IMG_1886.JPG IMG_1887.JPG IMG_1889.JPG IMG_1893.JPG IMG_1897.JPG IMG_1901.JPG IMG_1907.JPG
  12. 33Doll
    33Doll
    All Done!
    Almost done with with the unnamed one!
    Cant wait to get back to the Doll!”
    (After a bunch of year long put off honey dos first!)
    It was a good run though!
    Knew it would catch up!
  13. 33Doll
    33Doll
    Well. The ****** shifts real easy and smooth now... and the clutch works awesome... but... now it has whiny
    1/2/R
    When I Downshift, and let off the gas, doesn’t do it under load or in third, so I think it’s probably that gear train and the Cluster shaft might’ve got worn a little bit from that snap ring being broken, and then the shaft being able to float a little bit, made its own sweet spot, so now that everything is fixed properly with new parts I think it’s sloppy just can’t see it with the eye!
    that’s my theory anyway.
    I put 80/ 90 in it and it’s pretty whiny so I switched to 85 /140 and want to see if that might quiet it down a bit.
    I’m done screwing with it!!!
    loudbang and kidcampbell71 like this.
  14. dumprat
    dumprat
    from b.c.
    I was going to mention 75-140. 80-90 is too thin for those transmissions.
    33Doll and loudbang like this.
  15. 33Doll
    33Doll
    Well, it did quiet it down a little bit, and then also putting the trans cover and boots back on so it’s not going right up into my face! still whines but it’s not too bad it hasn’t changed in two days so I think it’s probably good to go it’s just the gears are old.
    Shift smooth a child could shift it now!
    And that diaphragm style clutch is real super easy to push.
    i’m gonna finish cleaning the interior give it one more bath! Then I’m gonna sell it!!!
    brEad, kidcampbell71 and loudbang like this.
  16. 33Doll
    33Doll
    I should probably put the 85/140 in the transfer case also huh?
    that 80/90 was thin like water when it’s hot
  17. dumprat
    dumprat
    from b.c.
    Some Lucas gear oil snot might help too.
  18. 33Doll
    33Doll
    Ive used this before
    brEad and loudbang like this.
  19. 33Doll
    33Doll
    I can’t remember are you supposed to mix it with oil-that is in there or just use this? I think you’re supposed to mix it
  20. 33Doll
    33Doll
    I found it it’s 20%, and here’s one review off of Amazon I found it specific for my situation
    Anyway it won’t hurt!
  21. 33Doll
    33Doll
    I’m mostly talking to myself here, but I have a plan!
    So the container I use to pump oil has all the measurement lines on it, instead of trying to figure all the amounts in each box,I’ll just put the 85/140 in there and then I’ll add 20% of the Lucas to amount in the container, and mix it all together really good and then drain all the oil, and just fill up all the gear boxes diffs, Transfer case, and the ****** with the premixed amount
    ( like you do with 2 stroke)
    What do you think Matt?
  22. dumprat
    dumprat
    from b.c.
    Sounds like a plan! A great deal more scientific that I would I would have thought of. I woulda eyeballed it....
    But I'm the guy who ran four bananas and half a car of engine restore in a ford 9", which worked marvellously by the way.
  23. 33Doll
    33Doll
    I can’t get away from this Bronco!
    I got it up for sale now, and a bunch of people are asking me if I would do upgrades for them! Because I guess they like my ****-retentive work! Maybe I should get into the Bronco building business LOL!
    I just wanna get back to my hot rod!!!
    It is a complement though!
    All these young Guys want cl***ics
    Have money, but don’t know how work on anything. Alot of Business potential out There!
    If i were 15 years younger!
  24. dumprat
    dumprat
    from b.c.
    A cl***ic car and no mechanical skills? That sounds like a recipe to get ripped off!(not by you Of course) but I have seen it a bunch in the off-road world.
  25. 33Doll
    33Doll
    BRONCO is Sold!
    Gone!
    Back to the Doll!
    (After Some backed up honey-dos!
    Might be another month or so)
    She’s worth it! She was very patient while I was doing this for the last three or four months!!!
    Plus she’s getting a new Mac computer from my pay cut!
    Put the doll in there with this pic so I don’t get in trouble!!!
  26. 33Doll
    33Doll
    Poor Painted Frame! Getting dusty!
  27. Jim Bouchard
    Jim Bouchard
    Yay!!!!!
    Standing by
    Stogy, loudbang and 33Doll like this.
  28. 33Doll
    33Doll
    88BAD99B-B5DE-40CC-A015-AFCF5CEB9941.jpeg 93B2B22F-E9F8-4713-9A08-012FAA0626E6.jpeg F7861B9F-2DB4-4CD7-97B9-55E46DFE5F9B.jpeg AE350A48-7D70-49FD-9DD5-6D0D34B05359.jpeg
    What the hell happened to the HAMB app?
    i’m lost without it! Having a hell of a time navigating on the full site on my phone.
    Took me a half hour just to find my posts!
    anyway I did a little work on the doll today in between honeydos!!!!
    brEad, Jim Bouchard, loudbang and 2 others like this.
  29. 33Doll
    33Doll
    Running out of places to store things especially now that they’re painted!
    Just got to clean up the housing and weld a bung for drain then I can start painting it. and putting The rear end in and back together!
  30. loudbang
