Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. Piewagn
    Piewagn
  2. Piewagn
    Piewagn
    Wasn’t happy with the driver quarter.....so I m***aged it a little more....NOW I’m happy with it! Just have the doors to do now and I’m off to the races!! Dropping the top probably 31/4”-31/2”.....I want to leave the windshield swing locks in the factory position......happy weekend fellas!! IMG_0920.JPG IMG_0921.JPG
  3. Piewagn
    Piewagn
    Gettin’ close to final glaze!! Thanks for everyone hangin’ with me! IMG_0939.JPG IMG_0940.JPG
    chryslerfan55, Aaron D. and loudbang like this.
  4. Piewagn
    Piewagn
    Started on the dash tonight....just alot of little things before I hit everything with final glaze... IMG_0944.JPG IMG_0945.JPG
  5. koolbeans
    koolbeans
    Catching up.
    Dang, that hot rod coming along well.
    As usual enjoy your posts.
    Been away playing with new toy. My prized Healey got wacked/totaled by a kid running a stop sign. My long time lust for a "shine" car fulfilled by default. '39 deluxe, 350/350, just a plain jane really nice driver.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  6. Love the coupe. The self serving ******* who hammered your Healy needs to be tarred, feathered and thrown under a bus.
    Big mike 1968, loudbang and koolbeans like this.
  7. koolbeans
    koolbeans
    First time for tapping insurance with 77 clicks on the pavement. The underinsured line item/clause sure paid dividends. Healeys are complex, right front hit trapazoided to left rear.
    Be sure of your insurance.
  8. Piewagn
    Piewagn
    Thanks KB! Just pluggin’ away....I’ll get there soon enough.....
  9. Piewagn
    Piewagn
    Don’t know if I want to put this on the Tudor or the coupe....hmm [emoji848]
    Finishing up the firewall too....
    IMG_0932.JPG IMG_0935.JPG IMG_0954.JPG IMG_0955.JPG IMG_0956.JPG IMG_0959.JPG
  10. Piewagn
    Piewagn
    I’m experimenting with 2 different types of glaze....one is lacquer based and the other polyester. The lacquer based is way easier to sand and there’s no mixing hardener....I’ll probably use a combination of both. IMG_0961.JPG
  11. RodStRace
    RodStRace
    No mixing?
    Just a tube?
    called spot putty?
    I was told (and have experienced) that this stuff shrinks, meaning it is not suitable for quality repairs.
    dmar836, Bandit Billy and greaser like this.
  12. Piewagn
    Piewagn
    That would be the stuff called "Nitrostan".....that stuff is waterborne.... I used the lacquer based stuff on my truck when I built it in '04.....still looks great! We're filling 36grit scratches here.....not dents....:D
  13. Piewagn
    Piewagn
  14. Piewagn
    Piewagn
    patman, guitarguy, brEad and 3 others like this.
  15. Piewagn
    Piewagn
    Holy moly.....sanding and more sanding! I still have to drop the top and do the deck lid too.... I just want to get this thing in fill primer so I can sand some more.... It’ll be worth it in the end.....
  16. Piewagn
    Piewagn
    PRIMER!!! Wooo Hooooo!
    Still have to drop the top, then I can finish up the rest of the bodywork....Gettin’ there! Thanks fellas!! IMG_0977.JPG IMG_0978.JPG IMG_0979.JPG IMG_0980.JPG IMG_0981.JPG
  17. loudbang
    Looken good. :)
    Piewagn likes this.
  18. 34 5W Paul
    34 5W Paul
    from Fresno CA
  19. Piewagn
    Piewagn
    Dash work finished, rear panel done and a better shot of the driver side..... IMG_0991.JPG IMG_0987.JPG IMG_0990.JPG
  20. Piewagn
    Piewagn
    WOW!! Like magic! Now.....when I get there in the morning, will it be all finished?:D
    Looks great! Thank you for your generous efforts kind Sir!
  21. Piewagn
    Piewagn
    Outter deck lid done, jambs done and wheel wells done! I can almost taste it!! IMG_0996.JPG IMG_0998.JPG IMG_0999.JPG IMG_1001.JPG IMG_1002.JPG IMG_1003.JPG IMG_1004.JPG IMG_1005.JPG
  22. Ooo lalala
    Piewagn and loudbang like this.
  23. Piewagn
    Piewagn
    Thank you very much kind Sir!
  24. Piewagn
    Piewagn
    Got my woods installed.....the one I got for the rear was way too small, so I had to whip one up outta s****s from old skids.....it’s hardwood alright.... it kept knocking the blade off the bandsaw and was a bear to cut! I’ll tweak it up later after I chop the top....I just wanted to get them all installed.....FINALLY! Got my deck lid squared away too....
  25. Piewagn
    Piewagn
    Painted the inside of my deck lid tonight.....nothing spectacular but serviceable....time to chop! IMG_1020.JPG
  26. RodStRace
    RodStRace
    After all that effort on the gaps, don't forget to brace the body before cutting!
    chryslerfan55, loudbang and Piewagn like this.
  27. Piewagn
    Piewagn
    Absolutely! I've already got the stock ready to roll.....just have to cut to length.
  28. Piewagn
    Piewagn
    Got my hinges installed! They’ll still have come off again, but that task is finished! Picked up some hinges from a Triumph TR model not sure if it was a 3 or a 7.....either way, they kick ***! Thanks fellas! IMG_1022.JPG IMG_1028.JPG IMG_1027.JPG IMG_1029.JPG IMG_1024.JPG IMG_1032.JPG
  29. RodStRace
    RodStRace
  30. Piewagn
    Piewagn
    Yes....you are correct! Here they are.....I can't believe I only paid around 20 bucks for these. The subtle contour fit perfectly! upload_2021-4-1_21-15-28.png
    Atwater Mike, Jrs50, brEad and 4 others like this.
