Projects 33 3 Window Coupe
Discussion in 'Traditional Hot Rods' started by pennafxu, Mar 4, 2021.
  1. pennafxu
    pennafxu
    from Kentucky
    The only thing better than a Merc flathead, is 2!
  2. pennafxu
    pennafxu
    from Kentucky
    Some other parts...
    And a nice 4-speed manual transmission with overdrive.
  3. pennafxu
    pennafxu
    from Kentucky
    Engine One
  4. pennafxu
    pennafxu
    from Kentucky
    Engine 2
    Need to dis***emble and get them to the machine shop! I’m gonna be racing my son on dis***embly. I have another couple engine stands but can’t find my locking bolts... [emoji20]
    They are the same size/thread pitch as the head bolts but 2-3” longer.
  5. pennafxu
    pennafxu
    from Kentucky
    This trans bolts directly to this block with the help of the bellhousing...
    chryslerfan55 and kidcampbell71 like this.
  6. rusty valley
    rusty valley
    the trans in the photo is an overdrive ******, (not the newyork kind), and it should require the 1/2 bell
    kidcampbell71 likes this.
  7. pennafxu
    pennafxu
    from Kentucky
    I believe I have that bell?
  8. rusty valley
    rusty valley
    I dont see it in any photos
  9. pennafxu
    pennafxu
    from Kentucky
  10. rusty valley
    rusty valley
    that bellhousing is for a trans with a flat front mount, more like modern stuff. your overdrive mounts on a 1/2 bell, similar looking to the rear of the earlier ford flathead blocks
    pennafxu likes this.
  11. pennafxu
    pennafxu
    from Kentucky
    Is there an adapter for this? Or do I have to make it?
  12. rusty valley
    rusty valley
    chryslerfan55 and pennafxu like this.
  13. alchemy
    alchemy
    The red transmission is a 3 speed, not a 4 speed.
    48fordnut likes this.
  14. pennafxu
    pennafxu
    from Kentucky
    Does the above still apply?
  15. alchemy
    alchemy
    Not sure what "above" you mean? To bolt that transmission to the back of the late flathead block you will need a 1/2 bellhousing like they said. It's a ring about 4" thick that bolts to the block, then the trans bolts to it. They were made in stamped steel, or cast iron. Those two interchange just fine. When buying a cast iron one look them over closely as they are commonly cracked.
  16. pennafxu
    pennafxu
    from Kentucky
    Just acquired one... what all is the yellow stuff?
  17. alchemy
    alchemy
    6411 is a gasket. And 6825 is an angle bracket to attach the plate to the oil pan, not really needed.
    You won't need any of the 1952 era stuff.
  18. pennafxu
    pennafxu
    from Kentucky
    So these parts are not needed?
  19. rusty valley
    rusty valley
    No. not needed. The red trans is not an overdrive?
  20. pennafxu
    pennafxu
    from Kentucky
    It is...
  21. alchemy
    alchemy
    Technically then an overdrive would make it a 6 speed right?
  22. pennafxu
    pennafxu
    from Kentucky
    It has 2 shifter linkages on the side... I thought an overdrive was irrelevant of amount of gears
  23. goldmountain
    goldmountain
    An overdrive is like a bicycle with two sprockets on the crank - two ranges. The transmission is like the 5 or 6 sprockets on the rear wheel.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  24. pennafxu
    pennafxu
    from Kentucky
    Tire removed at my buddies shop.
    So much easier than doing it by hand. IMG_1333.JPG IMG_1334.JPG IMG_1335.JPG IMG_1336.JPG IMG_1337.JPG IMG_1338.JPG IMG_1338.JPG
    brEad and chryslerfan55 like this.
  25. pennafxu
    pennafxu
    from Kentucky
    He even hooked me up with new valve stems and fitted them with this cool tool!
    Back at home...
    Outback, brEad and chryslerfan55 like this.
  26. alchemy
    alchemy
    What do the wheels fit?
  27. pennafxu
    pennafxu
    from Kentucky
    16x6” 4.5” lug pattern...
  28. pennafxu
    pennafxu
    from Kentucky
    Need to patch this door... and pick a cut point...
    Nailhead A-V8 and chryslerfan55 like this.
  29. rusty valley
    rusty valley
    two shift levers on the side, no lever, or solenoid on the back end of the case?
  30. pennafxu
    pennafxu
    from Kentucky
    Has the solenoid...
