Technical A V/8 with 3 carbs/??
Discussion in 'Traditional Hot Rods' started by 48fordnut, Mar 14, 2021.
  1. 48fordnut
    48fordnut
    I need to see a picture of others with 2 carbs ,or 3 carbs that have the offset gen mount.
    Mine has a gen delete, needs parts to complete, and a left side gen mount on a 8cm eng. It has been converted to truck pumps and a 48 style dist dist. I will have the fan mounted on the gen delete.
    Thanks ,
    jim
    TCATTC likes this.
  2. Model A Gomez
    Model A Gomez
    I'm running a dual carb Offenhauser intake and a pair of Holley 94's and that is plenty of CFM for a flathead, 3 two's is overkill for a street car. The Offenhauser allows you to run the generator in the stock position and I'm running a 37 pulley and fan on my 12 volt generator.
  3. AngleDrive
    AngleDrive
    from Florida
    I agree^^^^^^^^
    Fairlane500, Hnstray and 48fordnut like this.
  4. Bigmac48
    Bigmac48
    from Dundalk Md
    image.jpeg image.jpeg image.jpeg View attachment 5005998 image.jpeg image.jpeg image.jpeg 48, probably won't help but here are a couple of my 3 two set up with an alternator .tried to delete duplicate pictures , sorry
    Desoto291Hemi, Hnstray and 48fordnut like this.
  5. Bandit Billy
    Bandit Billy
    :eek: :cool:
    I run my fake gen/alt off the left head on a Navarro bracket. I don't run run hood sides or this would require a blister on my 34. Easy belt adjustment and super clean install.
  6. 6sally6
    6sally6
    Why come I never see any 'flatties' with a 4 barrel carb?? Is the valley too narrow?
    6sally6
    I guess you can tell........I ain't 'all-that-sporty-' when it comes to flat heads.:oops:
    6sally6
  7. Bandit Billy
    Bandit Billy
    Cuz they is ugly! A guy on here was trying to put a quadratoilet on a flatty but not sure if i ever saw that thread wrap up successufully. It's like putting Hoss's 10 gallon hat on Little Joe, Hop Sing be like "yu rook redicurous!"
  8. Kiwi 4d
    Kiwi 4d
    The nice blue 39/40 has 39 carbs judging by the pictures.
    48fordnut likes this.
  9. 1935ply
    1935ply
    from peyton,co
    Edelbrock Super E IMG_0130.JPG IMG_0130.JPG manifold, 38 truck generator cut down for fan, 2- 97's
    Sorry for dual pictures.
  10. 48fordnut
    48fordnut
    I have a 2 carb manifold also. The one by 1935 Ply is what I wanted to see.
    Thanks all.
    jim
    1935ply likes this.
  11. BJR
    BJR
    3 carbs are useless on a flathead Ford motor. On a bigger V8 they work, like a 389 Pontiac or a big block Chev or Mopar. But on a flathead way over carbed.
    Fairlane500 likes this.
  12. Mr48chev
    Billy Bandit pretty well nailed it. The general consensus is that they are ugly.
    Most of the guys that run one use a WCFB off a 265 or 283 Chevy. I'm thinking that is what the Offy 4 barrel intake was designed for.
    Desoto291Hemi and Bandit Billy like this.
  13. dwollam
    dwollam
    I run a WCFB 4bbl carb on my 286 flatty in my '40 Std Tudor. Been on there for many years and works great.
    Dave
    joel, Texas Webb and Hnstray like this.
  14. Hnstray
    Hnstray
    from Quincy, IL
    @6sally6
    A bit over a decade ago I built a ‘53 Merc for a ‘47 Ford Coupe and a**** many mods, used a Holley 390 cfm on an Offenhauser manifold. Of course it’s just an opinion, but I didn’t think it was ‘ugly’, but it sure was functional. ;)
    Ray
  15. Bandit Billy
    Bandit Billy
    In my defense Ociffer, I was drinking when I posted that. :cool:
    in-the-weeds and Hnstray like this.
  16. solidaxle
    solidaxle
    from Upstate,NY
    48Fordnut
    Looking at your pictures brings up some questions.
    With your set up, will the belts line up with the pulleys?
    What are you using for the crank pulley?
    Will your fan be to high?
    To make room for the left hand side water outlet, you will also need to fab some spacers and use longer head bolts for the generator mount.
  17. 48fordnut
    48fordnut
    Thanks for the input.
    1 belts line up,
    2. single pulley,
    3 Alumn heads are thicker than stock and have spacers set up in case .
    4, To be determined.
    You have brought up good ? and I hope I am on the way to resolving them. The pics do help.
  18. 48fordnut
    48fordnut
  19. solidaxle
    solidaxle
    from Upstate,NY
    I think Speedway sells a cylinder head water outlet that changes the direction to a more straight up hose connection. You will need one of those to clear the gen.
    Just curious, why use the 48 style distributor and not the 8ba side mount?
  20. 48fordnut
    48fordnut
    I have the outlets.
    I like the crab style.
    The block is a 8cm that I converted to a 59a cam ,ft cover ,intake, and dist.
