Projects Belly Tank Build UK
Discussion in 'Traditional Hot Rods' started by JamieUC, Jan 3, 2021.
  1. JamieUC
    JamieUC
    from Swansea UK
    I did grind a form tool but didn't end up using it, as you say the chatter would be a problem on the little Myford lathe, did this with a rightangle parting tool with the compound slide set to 17 degrees, all done in back gear so nice and slow.
  2. the pinstriper
    the pinstriper
    from duxford UK
    ****** love this, every update has something new to perv at!
  3. 282doorUK
    282doorUK
    I've just widened an alternator pulley groove to fit the larger belt on my '28 Chevy saloon, didn't fancy a form tool with my Atlas lathe so like you I used the compound. I kept the faith 6 yrs before finally giving up on 6 volts!
    Almost got excited when I thought I'd found the holy grail laying in a field a couple of days ago, but nope, not that iconic period shape ☹️
    Jet96, JamieUC, loudbang and 2 others like this.
  4. milosmith
    milosmith
  5. Speedtwin
    Speedtwin
    This is such a great build to follow. Your workmanship is simply outstanding.
    Can’t wait to see this on the Sands and having piloted our club (4 banger)Belly Tank at Pendine in 2019 I can ***ure you that you’re in for a real blast[emoji573]
    Keep up the good work.
    Duncan
    BCBillysCC
  6. Sakke
    Sakke
    from Finland
    Your building skills are just amazing ! Please keep us updated !
  7. JamieUC
    JamieUC
    from Swansea UK
    Finished the tensioner pully, just got it mocked up in place with a bit of bar in the photo so next weeks job is to make a sliding mount for it, proably use slightly shorter belts as well to get max belt wrap and keep the tensioner away from the distributor.
    Got the old Ford distributor in just for mock up but will be machining up this Vertex magneto from a SBC with a couple of hour in the lathe it will be flathead compatable:cool:
    Vertex on the left for the belly tank and gonna do the Mallroy duel point while I'm at it and a stock Ford dizzy on the right for comparison.
    brEad, chryslerfan55, Besty34 and 5 others like this.
  8. roseville carl
    roseville carl
    how in the hell did I miss this?........ great job so far whats your thoughts on engine build???
  9. JamieUC
    JamieUC
    from Swansea UK
    Hi Carl gotta say your FED thread is awsome, I need to pick your brains, couple of questions I have are what blower ratio are you running? think your running a 3/71 blower like I'm planing. Ive set it up for 1 to 1 ratio but was thinking I could make a bigger crank pully to maybe run 20% overdriven, was going to get it all working and see what boost I get, want to keep boost reasonably low to start with.
    Second question is what size injectors are you running in the two port and have you got two or four injectors?
    Ive been studying some of Bob Szabo's books on MFI but stuggling to find much info on blown flathead injection setup.
    Engine build plan at the moment is
    Merc block (havent decided on bore yet its .020" over at the moment but will need at least another .020 to clean up)
    Merc 4" Crank with billet center main and line bore
    Merc heads machined for higher valve lift
    Isky 400jr cam
    Ross forged pistons
    Port job for block
    3/71 blower v belt drive 1 to 1 ratio
    MFI planing a custom built two port ( may well run carbs to start with but long term plan is MFI)
    Well thats about the basics of it, youve obviously got experience with all this so any advise would be welcome.
    brEad, chryslerfan55, Besty34 and 2 others like this.
  10. roseville carl
    roseville carl
    my engine is a 304CI with **** Crank and rods, Ross Pistons, Potvin 425 ground by Pete One on here, ported and relieved, 471 Blower, now with a 650 Holly double pumper
    I have tried 10% under and 10% over on the blower, under not enough boost, over was using copper gaskets as fuses as too much boost, am now running a 6" dia pulley on crank and a 5" blower pulley gives me 7-8 lbs of boost at 5000
    and everything is happy.
    On the two port FI we still haven't gotten the bugs worked out yet that's why I'm going back to gas for Mays Race. I think I am having cavitation problems with the pump feeding from a 2 gallon Moon tank. I need more time to figure it all out and I'm getting impatient so its back to gas for may. Could also be the four port that I made into a two port may be part of the problem, started out with 4- 40 nozzles, to fat went with 4-38's and still no help ...............sent you a pm if you would like to talk...........
    Fusable links
    Jet96, brEad, chryslerfan55 and 6 others like this.
  11. JamieUC
    JamieUC
    from Swansea UK
    Thanks for the reply Carl great info, the state of that head gasket:eek: I'm gonna have a good read through your FED thread when I get time..its long.
  12. roseville carl
    roseville carl
    I know its long, been writing it since 2010 lots of history with me, I'm fkn old..............
    Jet96, brEad and loudbang like this.
  13. Besty34
    Besty34
    wow ! just found this, absolutely brilliant
  14. JamieUC
    JamieUC
    from Swansea UK
    Another full frontal shoot this time with the Vertex mag and idler mount added.
    Got both the Vertex and Mallory casings turned down this week just waiting on a couple of drive gears from speedway so I can put them back together.
    AHotRod, chryslerfan55, RMR&C and 7 others like this.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Nice work. I love the pulley set. Was there a reason you made the idler pulley with Vees and wrapped the belts around them on the outside versus just having the belts inside of the idler and enabling you to have a plain round idler pressing on the outside of the belts?
    brEad, chryslerfan55 and loudbang like this.
  16. JamieUC
    JamieUC
    from Swansea UK
    It would have been easyer to do as you said and would give more belt wrap but this setup allows a bit more space for a Hilborn PG150 fuel pump to be grafted onto the the timing gear cover, I want to keep the pump as tight to the block as possible as there wont be much room in front of the engine. Waiting for an aluminium timing cover to arrive before I graft on a spud bearing and pump mount.
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That make perfect sense. Thanks for the reply.
  18. roseville carl
    roseville carl
    lookin good Jamie
  19. JamieUC
    JamieUC
    from Swansea UK
    Had lots of time on the tank over the weekend and last couple of evenings. Took it all apart as I wanted to lower the front crossmember two inch to give better ground clearence and also to move the axle, engine gearbox back a couple of inches aswell as things were getting a bit too tight.
    All in bitz
    Welding it back together..
    Could definetly do with a good ch***is table, but this did the job....
    and all back together with the fire wall welded in I was finaly able to cut the top rear half of the tank to fit, been dying to do this to get more of a image of what its gonna look like finished.
    Jet96, brEad, AHotRod and 17 others like this.
  20. backwoods96
    backwoods96
    from Mead, Wa.
    I like it - it is coming long niceley
  21. 26 T Ford RPU
    26 T Ford RPU
    Looking good. You run out of room very fast, mine is a 20" extended version of the P-38 Tank and i have a Willys 4 and its still a tight fit. JW
  22. JamieUC
    JamieUC
    from Swansea UK
    Yep its gonna be a squeeze alrght, how our tank coming along JW, any progress pictures?
  23. 26 T Ford RPU
    26 T Ford RPU
    No progress at all over summer but will be making a move on it soon. JW
  24. 8 years or more
    8 years or more
  25. JamieUC
    JamieUC
    from Swansea UK
    Had a JD2 manual tube bender delivered this week, so I had my can of spinich put on my strong man pants and set about bending up the first hoop of the roll cage, this is 1 3/4 tube so takes a bit of effort.
    Also made steering box mount and mocked up colum with a bit of tube. Been trying to think of a away to make the column telescopic one for safety but also so the steering yoke and column could be slid forward for getting in and out of the tank easyer, might just stick with a quick realease on the yoke but would be funky with a telescopic setup. Any ideas on this let me know.
    brEad, RatPwrd, Speedtwin and 13 others like this.
  26. alchemy
    alchemy
    Most all the 70's GM columns we used to use in the 80's had a double D inner shaft with a corresponding D outer tube. The two parts were held together, kept from sliding, with pins made of plastic. In an accident the pins would shear. You could use the same parts without the plastic pins if you could devise a way to keep the wheel in place during driving, but slidable to let you wiggle out. A removeable plastic lock pin?
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Nice job on the roll bar. Compound bends done manually that close together is not an easy task.
    I like the idea of the telescopic column. I think some Fords used flat metal spring clips in a detent similar to the GM plastic devices. I'm sure you can find something that is compact and will work. Maybe Bergeson has an off-t******lf ***embly that will suffice.
    BTW I love the steering wheel. It looks aircraft in origin. Do you know the type of plane? (I hope its HAMB friendly LOL).
  28. 26 T Ford RPU
    26 T Ford RPU
    You shouldn't need a telescopic column for safety as your harness will hold you firmly in your seat but you need a deep steering wheel with a quick release hub so you can get in and out and will need to demonstrate an ''emergency bale out''. JW
  29. 26 T Ford RPU
    26 T Ford RPU
    I took this photo of a Belly tank on my last trip to Bonneville to use as a reference. With the wheel and hub removed it give much more access. JW
    Jet96, AHotRod, JamieUC and 2 others like this.
  30. 26 T Ford RPU
    26 T Ford RPU
    I made this for mine and the hub was a good price. JW
    brEad, AHotRod, Bandit Billy and 3 others like this.
