Customs What Diameter Tube for Sunken Antenna?
Discussion in 'The Hokey Ass Message Board' started by BJR, Mar 14, 2021.
  1. BJR
    BJR
    Like the ***le says, what diameter tube do you use for a sunken antenna? I have a power antenna that I want to sink into the rear fender of my 49 Buick.
  2. What is the diameter of the base?
    BJR likes this.
  3. fabricator john
    fabricator john
    from venice fl.
    find the antenna you wanna use, get your hardware sorted , wont need the swivley parts because angle will be fixed, slide a deep socket on , a tube size that gives you just enough on that socket ... dont forget to add a drain
    fabricator john,
    miss you dad
  4. traffic61
    traffic61
    from Owasso, OK
    I have a hazy memory of an old customizing article where a guy cut up a shock absorber to use as the recess for a sunken antenna. Never have tried it, but for some reason I had that weird tidbit stored in the back of my brain.
  5. I use 2" take a cheap socket that fits the nut then weld some s**** metal to the outside so you can slide it over the stalk I use 1/4" brake tube for the drain . IMG_0173.JPG IMG_0174.JPG
    Maniut, BJR, Cooon and 3 others like this.
  6. goldmountain
    goldmountain
    I've done it with small diameter tubes and large ones. I think the large ones look the best; about 1 1/2"
    BJR and Jim Bouchard like this.
  7. fastcar1953
    fastcar1953
    shock tube works great.
  8. saltflats
    saltflats
    from Missouri
    Guessing placement would determine the diameter of the tube.
    BJR likes this.
  9. mgtstumpy
    mgtstumpy
    I recall 2" exhaust tubing with 3/16" drain tube?
    BJR likes this.
  10. Mr48chev
    As long as the diameter is big enough to clear your socket to tighten the nut life is good. Location does do a bit in determining the diameter. Drain hole and tube are a must.
    If you aren't using an electric antenna one of those that goes down flush or almost flush works pretty good as a frenched antenna. You can pull it up to the height you want to show and push It down if you are parked where you don't want it screwed with. You need room below the tube to use one though.
    What ever tube you use turn it so the weld seam in the tube is to the outside so it doesn't show when you are standing looking at it from the side or at an angle.
  11. chopolds
    chopolds
    from howell, nj
    I do mine with 1 1/2 or 1 3/4". To me, 2" looks too big.
  12. 55blacktie
    55blacktie
    BJR likes this.
  13. 55blacktie
    55blacktie
    Why would you want to cut a big hole in the body to accommodate a non-OEM antenna?
    BJR likes this.
  14. TrailerTrashToo
    TrailerTrashToo
    Sunken (a.k.a. "Frenched") antennas were a common item on the 1950's customs. I saw them all the time in the little car magazines.
    As far as the "non-OEM" comment, either you are a troll or you accidentally wandered into the wrong website...
    Kiwi 4d, RICH B, BJR and 4 others like this.
  15. lostone
    lostone
    from kansas
    I remember the old shock body being used too.
    Yeah its hard to remember a popular custom back in the day that didn't have a frenched antenna to go with the headlights and taillights. Heck I remember a few had a 2 or more frenched antennae...
    BJR, Jim Bouchard and egads like this.
  16. rudestude
    rudestude
    A 49 Buick ...Cool...this article should give you a idea..and its a "Traditional" custom modification.
    Buick on Buick...Cool. 20210315_102125~2.jpeg 20210315_101452~2.jpeg 20210315_101526~2.jpeg 20210315_101549~2.jpeg 20210315_101606~2.jpeg 20210315_101616~2.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    Maniut, Jim Bouchard, egads and 4 others like this.
  17. 30dodge
    30dodge
    from Pahrump nv
    Here is a double set. The tube size is not all that critical. Alien Antennae.JPG
  18. goldmountain
    goldmountain
    BJR, Budget36, egads and 2 others like this.
  19. 49ratfink
    49ratfink
    the best opening for an antenna is about 1/4" so just the ball on the end shows. I can't picture a car where it looks better with big holes for an antenna
    BJR and rudestude like this.
  20. Roothawg
    Roothawg
    Yeah, for those of us that are OCD, that is a deal breaker....
    BJR and Just Gary like this.
  21. 3340
    3340
    If I remember I believe mine was 1 1/2 washer welded in bottom
    Sent from my iPhone using H.A.M.B. View attachment 5007287
    BJR likes this.
  22. Drewski
    Drewski
    11-18-9.JPG Mine was done with 1 1/2" exhaust pipe.
    Maniut, BJR, 210superair and 3 others like this.
  23. 55blacktie
    55blacktie
    BJR likes this.
  24. 55blacktie
    55blacktie
    49ratfink, according to TrailerTrash, you and I either are trolls, or we wandered onto the wrong site by mistake. Maybe I should go cut some holes in my 55.
    BJR and 49ratfink like this.
  25. 49ratfink
    49ratfink
    been trolling here for 17 years. sunken antenna's, dummy spots, cruiser skirts and continental kits all seem to go together. paint 'lost in the 50's" on the quarter panel with some music notes and you are done
    BJR likes this.
  26. I usually sink my antenna's into a tube roughly two feet in diameter ... can be plastic or metal. Every Thursday the town comes around and empties that tube into a big, stinky truck :D
    Honestly, that is one modification I have never understood o_O
    49ratfink likes this.
  27. TrailerTrashToo
    TrailerTrashToo
    I'm going to bow to a better argument. I have a soft spot for a well executed Frenched antenna - Totally agree with dummy spots, cruiser skirts and continental kits. Can I add randomly placed, NON-functional scoops to that list?
    Russ
  28. TrailerTrashToo
    TrailerTrashToo
    I think that 1953-4 Buick headlight bezels are overdone and do not really care for fender skirts.
    2020 05 14 Quarter View.jpg Sometimes you just have to listen to your car and give it what it wants...
    Russ
