Holley choke opens, but fast idle won't kick down
Discussion in 'The Hokey Ass Message Board' started by Automotive Stud, Aug 31, 2011.
  1. Automotive Stud
    Automotive Stud
    I have a 600 cfm Holley 4 barrel with electric choke. The choke fuctions correctly, but the fast idle cam won't kick off when I kick the throttle. I have to push it down with my finger and it comes off. Is there another adjustment on these I should look at? Everything is clean and lubricated I don't see why it's sticking. Thanks!
  2. Ole don
    Ole don
    When the throttle is opened just a bit, the wieght should pull the fast idle cam down. It not, something is binding it or the throttle hasnt released it yet.
    Boneyard51, mad mikey and jimmy six like this.
  3. railroad
    railroad
    I have seen the fast idle cams with the weight broken off. If that is not the case hold the throttle open and move the cam by hand. It should move freely and fall to the lowest position when released. Check the steps on the cam for burrs and the screw for adjustment. A slight amount of lube might help, but normally not required. Use something light, like a spray silicone, so it will not gum up.
    good luck,
    Boneyard51 and jimmy six like this.
  4. ClayMart
    ClayMart
    I can't visualize the exact choke linkage for this carb, but I'd start by trying to find the fast idle cam. With the choke open, it should pivot freely. Maybe it's supposed to be attached with a shoulder screw so it can't be overtightened, but maybe someone's used a regular screw and caused it to bind up. Maybe a spacer or washer missing somewhere.
    There's probably a rod that connects the choke valve to the fast idle cam. Some carbs might allow you to install this rod backwards or upside down. It might fit together OK but stll not allow for full, free travel of the lever, cam or linkage rod. Any chance of interference with the intake manifold or base gasket?
  5. gas pumper
    gas pumper
    I got one that does that, too. but I have another that's OK. and I can't see the difference between the two. I tried enough and have given up. I release it manually, too.
  6. 50sboy
    50sboy
    How did you fix it? I have the same problem. Thanks
  7. arkiehotrods
    arkiehotrods
    Traditional hot rods have manual chokes! :D
    Boneyard51 likes this.
  8. Dennis D
    Dennis D
    Isn't the fast idle screw under the choke ***y. on these? Been a while since I fooled with one. If so, maybe it needs some attention instead of the idle screw.
  9. Boneyard51
    Boneyard51
    You have linkage binding or sticking , as mentioned. If it moves by hand and not by itself, it is sticking! Find the bind or cause of the sticking. It should show itself under close inspection. That part should be “ rattle “ loose!
    I prefer manual as most of the time a properly set automatic choke is bothersome!
    Bones
  10. saltflats
    saltflats
    from Missouri
    Don't know what you used for lube, but that fast idle cam should be a dry fit. Lube can attract dirt and cause problems.
  11. The fast idle cam can break (somewhere close to the line in the picture) and the weighted part falls away so the fast idle speed doesn't drop off when it should. Also they should be dry, not lubed. Lube attracts dirt that can cause it to stick.
    Foot and jimmy six like this.
  12. 54vicky
    54vicky
    with 10+ years having past I think he solved problem or is living with it
  13. Boneyard51
    Boneyard51
    That is not the first time I have fallen for that! Lol:rolleyes: I don’t always check dates!
    Bones
  14. If none of these fixes work, you may consider calling Holley. I have found them to very helpful when I had problems.
  15. That's quite likely, but 50sboy asked how to fix the problem yesterday. Now he has more information than was here before.
  16. Dennis D
    Dennis D
    I usually look at the date also, missed it this time, oh well.......
  17. nunattax
    nunattax
    is the part in the picture upside down., i think it is.im refitting a electric choke to a demon 625 4 barrell vc at the moment very similar to holley.with the choke off you can easily install it incorrectly.im no expert but learning.this evening i had a go.i know how to adjust the flap.its opening and closing.ok but fast idle isnt sorted.if the bimetal element opens and closes the flap the linkage must link to the fast idle.with the red fast idle cam turned upside down doesnt the linkge fit under the fast idle cam in the dogleg at the weighted end and alter the idle speed. tonight i had the linkage over the red cam this must have been wrong tomorrow ill have another try with the link under/ in the dogleg in the cam..i hope im right.ps one vid advised backing of the idle adjustment to make ***embly easier.
  18. saltflats
    saltflats
    from Missouri
    The linkage does go under the fast idle cam.
    Foot and nunattax like this.
  19. nunattax
    nunattax
    thanks man im sure it easy when you know how.learnin .it would be easier off the truck!!.
  20. Yes the picture was upside down. I stole it off the internet and that's the way it was. Sorry for the confusion. Now it's right side up. :)
  21. nunattax
    nunattax
    thanx its left to right now as well as i fit it
