Technical The snowball effect
Discussion in 'The Hokey Ass Message Board' started by Sandgroper, Mar 17, 2021.
  1. Sandgroper
    Sandgroper
    IMG_1337.JPG IMG_1338.JPG drove the Vedette to work the other night, 10% chance of rain the forecast said. It started raining at midnight and was still drizzling at 0600 when I knocked off.
    Off I went on the 50 km drive home, big clunk under the dash and wipers stopped working right in morning traffic. Got home and headlights would not turn off. :(
    On investigation it was simple, linkage fell off the back of the wiper motor and just needed a circlip.
    That's where it started........
    Took dash out to access rear of wiper motor and replaced clip (I have my doubts if there was one there at all). Found a broken wire to the dimmer switch that was obviously hit by the linkage but couldn't find where it was from. Spent the better part of the day trying to trace the abortion of wiring under the dash and ended up completely rewiring the headlights. Problem solved?
    Went to put the dash back in and found a hot piece of wiring by chance. Traced it and discovered the thermo fan had been wired direct to power and a switch without a fuse or relay. Spent another half day rewiring that correctly.......
    Thought (what was I thinking ?) that I would take off the the wiper motor and have a look at it as it had a bit of slop in the shaft and I was curious as to how it had been adapted to the car. Found this setup.
  2. Sandgroper
    Sandgroper
    IMG_1334.JPG The rubber gear on the bottom was the cause of the slop, I am amazed it worked at all.
  3. Sandgroper
    Sandgroper
    Looked around for something similar size to make one out of and thought nylon would be better than rubber so the wife lost a cutting board :eek: :D That we will never speak of again.
  4. Sandgroper
    Sandgroper
    IMG_1335.JPG IMG_1339.JPG IMG_1342.JPG Then I was looking for a spanner (storey of my life) and found this in one of my tool boxes. It's a radiator donut from a late model GM.
    Jigsaw and the wife's bread knife (shoooosh I did wash it and put it back) and came up with this. Works like a dream.
  5. Sandgroper
    Sandgroper
    Anyway, to finish my tale of woe and unplanned fix its, I then noticed a few drops of coolant on the garage floor. Yep radiator has a small leak. :(
    Now saving for a new one as this ones aluminium core and can't be soldered.
    Has anyone else (most I guess) gone to fix a small issue and ended up fixing a lot more..
    Post it up and make me feel better lol.
    chryslerfan55 and scotty t like this.
  6. cfmvw
    cfmvw
    Been down that road many times! In my case, it started out simply enough, but then I said, well, as long as I'm at it...and a simple project took on larger-than-life proportions.
    Sandgroper likes this.
  7. 1-SHOT
    1-SHOT
    from Denton
    Join the Club
  8. To borrow a phrase from a former boss, working on old cars is; "Like wiping your *** with a hoop. There's no end to it!""
    Wanderlust and Sandgroper like this.
  9. stillrunners
    stillrunners
    from dallas
    good job there !
  10. The cars we play with are as old as HELL!
    chryslerfan55 and Sandgroper like this.
  11. That's how we end up with these cars... The owner gets tired of doing or runs out of money for these 'little fixes'.... LOL...
  12. jetnow1
    jetnow1
    from CT
    There are two aspects to this, the first is what happened to you. You fix one thing and as you do that you see something else that needs fixing. The other is the while I am at it I might as well add this such as adding A/C to
    the car while you are changing that radiator
  13. Roothawg
    Roothawg
    It's called "Mission Creep" or "Project Creep". I am the King. Bow to me.
    BJR, hotrodjack33, Tim and 2 others like this.
  14. Sandgroper
    Sandgroper
    Strange you should say that, it's already crossed my mind. Lol. :p
  15. hotrodA
    hotrodA
    “Project creep”. You’re right Root.
    Sometimes it’s a runaway train.
    Welcome to the club.
  16. Sandgroper
    Sandgroper
    Its happening........got the front panels off and in to it. Decided if I'm going to change the radiator I might as well make a shroud, new fan etc. lol
  17. gene-koning
    gene-koning
    If that is all the bigger your snowball has grown, you need to come and hang around me for a few weeks, you obviously need more training.
    chryslerfan55, Truck64 and Sandgroper like this.
  18. A23
    A23
    from Hollywood
    Six weeks ago I went to put a new mech. fuel pump in...
    I've now got the car up on four jackstands and I'm re-doing the entire steering system, fixing some body rust, and painting the interior.
    Fuel pump's still not in... :confused:
  19. Sandgroper
    Sandgroper
    Lol, I try to resist that. Every time I take the instrument panel out I have to stop myself from removing the whole dash and redoing it.
    I'm waiting for winter to do that, weathers too nice at the moment.
  20. jetnow1
    jetnow1
    from CT
    I love mission creep, as a remodeling contractor it made me a lot of money over the years, I loved to hear while we are at it might as well....
  21. alanp561
    alanp561
    Yep, I know you even though we've never met. You're the guy I wouldn't leave my wife alone with after she and I had already agreed on a color for the dining room walls.;)
  22. jetnow1
    jetnow1
    from CT
    :D:D:D
  23. jetnow1
    jetnow1
    from CT
    I have been guilty of doing it to myself. Went to move a light switch that was installed on the wrong side of the back door. To get at the wiring needed to cut an access hole in the ceiling. Discovered the previous owner had installed a 2nd ceiling over the original. Tore out both layers, discovered the wiring in the ceiling was knob and tube. Tore all that out and replaced it with new. Since ceiling was open put in 6 recessed lights for better lighting. Replaced ceiling and
    finally moved switch. Turned on lights, now the cabinets looked really shabby. Refaced cabinets and made new doors and drawer fronts. Now the counter top really looked bad, tore off and made new counter tops and backsplash.
    At this point the floor was starting to bug me - so I moved.
  24. Truck64
    Truck64
    from Ioway
    This is one reason that ordinary repair shops many times don't want to mess with older cars. Everybody wants a quote, and they can't do that. Everything takes longer, and they are never quite sure what they are going to find. Lots of customers try the "just fix what's broke, don't mess with anything else" routine, and that isn't always possible much less safe.
  25. gene-koning
    gene-koning
    And to finish that statement, "just fix what is broke and nothing else" isn't what they want at all, its just what they want to pay for. They expect everything on the car to be perfect for 10 year after any repair you have done.
    I'm so happy I've retired and now only fix my junk. At least I know why I stopped when I did. Gene
    chryslerfan55 and Truck64 like this.
  26. Truck64
    Truck64
    from Ioway
    And anything else that just happened to break or fail while in their shop, or shortly thereafter, is also your fault too, and should of course be replaced on your dime and time.
  27. BrandonB
    BrandonB
    from nor cal
    All I started to do was prime the carburetor.
    alanp561, chryslerfan55 and Truck64 like this.
