Technical Tri Five Fenderwell Headers
Discussion in 'Traditional Hot Rods' started by carnut62, Mar 17, 2021.
  1. carnut62
    carnut62
    Just curious if anyone has found a set of bbc fender well headers that work with the engine set back about 4”?
  2. chevy57dude
    chevy57dude
    The Patriots Speedway sells will miss the tires with the engine set back that far. They might hit the cowl, though.
  3. carnut62
    carnut62
    Thanks I’ll have to look into those. My firewall is set back about the same distance or more so maybe they’ll work. What I was concerned about is the steering box clearance to the header. With the inframe headers it’s pretty tight already.
  4. wvenfield
    wvenfield
    I think anyone would have to guess. The Speedway headers aren't very expensive so even if you have to modify them some that wouldn't be too bad and far cheaper than a custom set and far easier than making your own.
  5. Penetrator
    Penetrator
    from SK CAN
    Patriot H8035. I have a pair intended for my '38 Chevy. I think they'll fit your p***enger side fine, if you relocate the battery. Your driver side looks like trouble. They're supposed to clear the steering, but your placement likely negates that claim. I have some old mock up pics if you'd like to do some eyeballing...
    loudbang and stillrunners like this.
  6. carnut62
    carnut62
    sure that’d be great if you can post a few pics
  7. Penetrator
    Penetrator
    from SK CAN
    OK. I'll dig them up and post shortly.
    @carnut62
    Not great, but the best I have. I had the block as close to the firewall as comfortable, accounting for tall covers and a fat body ignition. If I chose to recess the firewall (which I'm not going to do) it could go back an easy 4" without contacting the cowl corners.
  8. swade41
    swade41
    from Buffalo,NY
    These are the Speedway on my Henry J , clearing your stock column is going to be your issue.
  9. carnut62
    carnut62
  10. carnut62
    carnut62
    Yeah pretty sure those won’t work for the drivers side. I guess they could be modified. Thanks
