Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    I literally looked for 10 mins for a 7/16” and then saw an 11mm flash before me!
  2. pennafxu
    pennafxu
    from Kentucky
    Final primer coats and then engine enamel...
    brEad, kidcampbell71 and LAROKE like this.
  3. pennafxu
    pennafxu
    from Kentucky
    Starter body flipped... looks like the Swiss flag!
    Ready for more coats...
    Started re-***embly... what a nightmare!
    Using the 3 P’s technique.
    Plenty’o
    1. Patience
    2. Pins
    3. Profanity
    I gave up last night. I had 3 brushings over the commutator and the last was just ****ed... I slowly tried to raise the ***embly and everything went ***s up. Back at it today.
  4. pennafxu
    pennafxu
    from Kentucky
    Plugs came in... one step closer... need to look up the torque specs.
  5. pennafxu
    pennafxu
    from Kentucky
  6. pennafxu
    pennafxu
    from Kentucky
  7. pennafxu
    pennafxu
    from Kentucky
    IMG_1357.jpg I used pins to pull back the springs, then completely pulled out the brushings on 2 sides and installed them through the hole while pulling the spring out the way IMG_1357.jpg IMG_1358.jpg
    brEad likes this.
  8. pennafxu
    pennafxu
    from Kentucky
    I bolted on the bell housing attachment and finished painting... IMG_1359.jpg IMG_1360.jpg IMG_1361.jpg IMG_1374.jpg
  9. pennafxu
    pennafxu
    from Kentucky
    12mm gasket seat... In aluminum heads... so I went with 15 ft/lbs.
    I test fit the plug cables on the old distributor following the correct firing order. IMG_1363.jpg IMG_1365.jpg IMG_1366.jpg IMG_1367.jpg IMG_1368.jpg IMG_1370.jpg IMG_1371.jpg IMG_1372.jpg IMG_1373.jpg
    I will need the Oil fill tube correct?
  10. pennafxu
    pennafxu
    from Kentucky
    This is a great little book...Will be getting my alternator from him and using an internal ballast coil. What Electronic ignition works well with this set up? Will change to 12 volt system so a bunch of changes going on there... IMG_1376.jpg
  11. pennafxu
    pennafxu
    from Kentucky
    Starter oiled up...
  12. pennafxu
    pennafxu
    from Kentucky
    Like the look of this...
    IMG_1378.JPG IMG_1379.JPG IMG_1380.JPG IMG_1381.JPG IMG_1382.JPG IMG_1383.JPG IMG_1384.JPG
  13. Outback
    Outback
    from NE Vic, Oz
    Coming along nicely!
    kidcampbell71 and pennafxu like this.
  14. pennafxu
    pennafxu
    from Kentucky
    This is my steering linkage... I’m going with cross steer. My question is what happens to the hook on the drivers side that on the p***enger side goes in the hole with a castle nut I ***ume?
    kidcampbell71 likes this.
  15. patmanta
    patmanta
    from Woburn, MA
    Unless you want to spend a bunch of money on screw in ball studs to use that Model A tie rod, just get a new tie rod and new drag link with later style ends and be done with it. I would shelve the Model A stuff for another project; I don't think the hook (which is indeed the steering arm for the Model A, similar to a F1 setup) will be of any use to you.
    pennafxu likes this.
  16. pennafxu
    pennafxu
    from Kentucky
    Is this a custom set up from scratch, or does someone sell a kit?
  17. rusty valley
    rusty valley
    Back to starters, actually the shaft on the starter drive should be clean and dry, not oiled. Oil will collect dirt and eventually the drive will stick
  18. pennafxu
    pennafxu
    from Kentucky
    I used gun oil... Is that too
    Much? It was sticking
  19. rusty valley
    rusty valley
    Clean and dry is all i can say. maybe in your case, just wipe it down with paper towel, that would leave some level of rust protection as opposed to washing it with a solvent.
  20. patmanta
    patmanta
    from Woburn, MA
    This is all just catalog parts and an original 35-48 Ford cross steer box.
    My particular setup is a So-Cal dropped axle with some stainless drop arms with tie rod and drag link I ordered from Speedway off the measurements once I set the car up. My tie rod is stainless but the drag link is just painted steel.
    You can order them as kits:
    https://www.speedwaymotors.com/Plain-Tie-Rod-Drag-Link-Kit-with-11-16-Tie-Rod-Ends,3306.html
    However the last one I put on my AAV8 build, I just ordered the components and saved myself $20
    https://www.speedwaymotors.com/Spee...-Rod-Drag-Link-Tubing,27189.html?sku=91634-46
    https://www.speedwaymotors.com/Speedway-Ford-Outer-Tie-Rod-End-11-16-18-RH-Thread,32859.html
    https://www.speedwaymotors.com/Speedway-Ford-Outer-Tie-Rod-End-11-16-18-LH-Thread,6958.html
    https://www.speedwaymotors.com/Speedway-Plain-Steel-Jam-Nut-11-16-18-RH,35642.html
    https://www.speedwaymotors.com/Speedway-Plain-Steel-Jam-Nut-11-16-18-LH,35643.html
  21. pennafxu
    pennafxu
    from Kentucky
    Thanks for taking out the time to post this...
    patmanta likes this.
  22. patmanta
    patmanta
    from Woburn, MA
    Sure thing, I hope it was helpful. You can PM me any time if you have questions and I'm subscribed to this thread so I follow along regardless.
    What do you have for Spindles?
  23. pennafxu
    pennafxu
    from Kentucky
    I believe Ford... but I would have to look up the exact ones.
  24. patmanta
    patmanta
    from Woburn, MA
    Well if you pulled that Model A tie rod and steering arms off them, put those on the shelf too and just buy some repops from Speedway with the kingpins and bushings installed and reamed to save time and keep it simple. Alternately you could shop around for a nice set of 37 up spindles and recondition them. What are you doing for brakes?
    https://www.hotrod.com/articles/hrdp-1304-scroungers-guide-early-ford-spindles/
  25. pennafxu
    pennafxu
    from Kentucky
    I should clarify, these are juicers with finned Lincoln covers from a speed shop in Nebraska that fit Ford. They were like 1700 duckets. I need to look at my old posts... All the other stuff is new also... this was the monkey run. When I do the final ***embly I'm sure you will chime in.
  26. pennafxu
    pennafxu
    from Kentucky
    This is my alternator pulley that was bent... does anyone know the part number off hand?
  27. pennafxu
    pennafxu
    from Kentucky
    Or can it be straightened?
  28. Colton Leigeb
    Colton Leigeb
    Sorry for the late response, but yes you are right, I had a sport coupe that was chopped into a roadster for about a week, it just didn’t look right. Haha. Still a fun car but sold it too my buddy because I didn’t have the extra money at the time to buy actual roadster quarters and doors. But I may be buying that car back soon and finally putting correct roadster quarters on it. I may have some pictures if you’d like
  29. pennafxu
    pennafxu
    from Kentucky
    Would love to see your ride.
  30. pennafxu
    pennafxu
    from Kentucky
    IMG_1596.JPG IMG_1601.JPG IMG_1602.JPG IMG_1603.JPG IMG_1604.JPG IMG_1605.JPG IMG_1606.JPG IMG_1607.JPG
    One rail done...
    brEad and patmanta like this.
