Projects 33 3 Window Coupe
Discussion in 'Traditional Hot Rods' started by pennafxu, Mar 4, 2021.
  1. pennafxu
    pennafxu
    from Kentucky
    Really digging this look!
  2. pennafxu
    pennafxu
    from Kentucky
  3. pennafxu
    pennafxu
    from Kentucky
    Engine stand bolts... 7/16x14
    Will mount the engine when I get time this weekend
  4. The37Kid
    The37Kid
    chryslerfan55 and pennafxu like this.
  5. alchemy
    alchemy
    Gospel.
    So many guys do patches and piecing together with a part laying on the bench. Then they wonder why stuff doesn't fit when they bolt it up to the body. It's cause they are doing it backwards.
    Other day I saw a post with a guy putting patch panels on the bottoms of his 34 doors before he even had the body shell attached to the floor and ch***is. Ridiculous. The hard parts to move are the floor, rockers, door jambs, and roof. Let the small parts like upper doors and lower patches be fine tuned to fit the opening in the body, not the other way around.
    Outback, Tman, Thor1 and 8 others like this.
  6. pennafxu
    pennafxu
    from Kentucky
  7. pennafxu
    pennafxu
    from Kentucky
    IMG_1377.jpg need to chase out the threads on the Merc block...
  8. alchemy
    alchemy
    Do NOT tap the threads for the head studs. You will be fighting seeping studs forever. Henry designed those studs to have a tighter tolerance on the block to prevent the coolant from seeping through the threads. If you run a regular tap in them you will ruin that.
    You can cut a slot lengthwise in an old head bolt and run that in there to clean the crud out of the threads. But not a tap.
  9. dumprat
    dumprat
    from b.c.
    Or you can buy a proper thread chaser.
    Outback and chryslerfan55 like this.
  10. pennafxu
    pennafxu
    from Kentucky
    This is actually for the mounting holes on the side so the engine stand bolts will attach... they are rusted.
  11. rusty valley
    rusty valley
    If you are mounting to the exhaust port bolts, only the front two are 7/16. the backs are 3/8. really, an 8ba can be mounted from the bellhousing end safely, unlike the earlier blocks
  12. pennafxu
    pennafxu
    from Kentucky
    It’s these bolts here... they are 7/16 x 14... I could barely get 2 threads to bite...
    chryslerfan55 and rusty valley like this.
  13. J'st Wandering
    J'st Wandering
    You might want longer bolts. I would not feel comfortable with two threads holding. I have had a flathead drop on the floor and they do not bounce.
    chryslerfan55 and lurker mick like this.
  14. pennafxu
    pennafxu
    from Kentucky
    That's why I'm chasing the second block/ I ended up using a 7/16" bolt on this one but it was a bear...
  15. Dick Stevens
    Dick Stevens
    If you are trying to clean up existing threads with a tap, be very careful as the tap will cut new threads, not just clean up the threads and leave you with bad threads. The correct tool to use is a thread chaser not a tap!
  16. the-rodster
    the-rodster
    Don't you have a 27 T build thread on this site?
    It's been going for over ten years, and isn't half way done.
    Is this coupe on the same schedule?
    Just saying :)
    Tman and chryslerfan55 like this.
  17. pennafxu
    pennafxu
    from Kentucky
    Frame rail boxing plates came in yesterday... pics to follow. Degreasing engines today and general shop cleaning/putting up tools. It’s gotten ridiculous with all my tools everywhere working on so many projects! My kids have 3 cars I’m helping them with... then the 3 Jalopies... I’m also rebuilding 2 more starters this weekend.
  18. pennafxu
    pennafxu
    from Kentucky
    This engine is a cobalt blue... very pretty in the sun. I started the teardown. IMG_1400.jpg IMG_1401.jpg IMG_1402.jpg IMG_1403.jpg IMG_1404.jpg IMG_1405.jpg
    chryslerfan55 and kidcampbell71 like this.
  19. pennafxu
    pennafxu
    from Kentucky
    Off with the heads, water pumps, oil pan... IMG_1407.jpg IMG_1408.jpg IMG_1409.jpg IMG_1410.jpg IMG_1412.jpg IMG_1413.jpg IMG_1414.jpg IMG_1415.jpg
  20. pennafxu
    pennafxu
    from Kentucky
    I started on the bottom end with the mains IMG_1416.jpg IMG_1417.jpg .
    I will be using the Tremec on this powerhouse, and the C10 on the 28.
  21. pennafxu
    pennafxu
    from Kentucky
    I removed the cam and timing cover and all of the tappets and valves. Unfortunately the engine is seized. I have been working it with pb blaster for 3 days, and also shocked the pistons with a large iron pipe. Still no dice. Next up is the heat wrench for some hot cold cycles. I obviously don’t want to damage the block or the Merc crank...
    Careful extraction is necessary here, however, worst case scenario will be destruction of the pistons...
  22. alchemy
    alchemy
    Sometimes you can sneak a few pistons out the top if they aren't all seized. Then you only have to worry about the couple that don't have clearance around the crank, and the seized ones.
    Check for a ridge at the top of the cylinder first and remove it with a cutter so you don't accidentally crack it pounding a piston upward out of the hole.
  23. rusty valley
    rusty valley
    A guy over on the barn puts diesel fuel in all the holes and lights it on fire! Might not go over well in your neighborhood.
    pennafxu likes this.
  24. junkman8888
    junkman8888
    A trick I use when dis***embling a stuck engine is to s****e the debris and rust out of the cylinders using a box-knife blade, the pointed ends of the blade get down between the edge of the piston and the cylinder so whatever rust juice you use can get to where it can do some good. That and whenever I take off a rod cap I put a piece of rubber hose over the rod bolts, helps prevent damage to the crank.
    Outback, chryslerfan55 and pennafxu like this.
  25. junkman8888
    junkman8888
    The 16" small pattern Ford wheels were used on 49-51 Shoebox Fords.
  26. pennafxu
    pennafxu
    from Kentucky
    Are you referring to cutting the piston?
  27. rusty valley
    rusty valley
    cut the ridge out of the top of the bore with a ridge cutter, is what he ment
  28. pennafxu
    pennafxu
    from Kentucky
  29. pennafxu
    pennafxu
    from Kentucky
    So I followed your advice... I think it might be working! IMG_1457.JPG IMG_1456.JPG IMG_1458.JPG IMG_1459.JPG
    I poured a serious batch of witches brew down again... every damn grease I could find! Liquid wrench, gas, pb blaster, wd 40.... something’s gotta give.
  30. pennafxu
    pennafxu
    from Kentucky
    I also leveled off the block and focused on one side. I purchased a cylinder fly cutter, as there is definitely a ridge! Thank you alchemy for saving my **** for the hundredth time... I will work the other side tomorrow. I figure having full coverage is better than some weird angled variant.
