Projects HotRod Rebuild
Discussion in 'Traditional Hot Rods' started by ModelARon, Mar 18, 2021.
  1. ModelARon
    ModelARon
    removed the old gas tank, the fuel was rusty color and wow did it stink IMG_1361.jpg
  2. Just Gary
    Just Gary
    It's a friggin' time capsule- I LOVE it!:cool:
    But lose the braided steel top radiator hose cover that screams 1990.:oops:
  3. ModelARon
    ModelARon
    Yes i tossed the braided hose .
  4. ModelARon
    ModelARon
    I found copper brake lines , trashed them. Surprised too see that.
    AHotRod, kadillackid and loudbang like this.
  5. ModelARon
    ModelARon
    IMG_2926.jpeg IMG_2930.jpeg IMG_2932.jpeg IMG_2931.jpeg Here are some pictures Frank sent me of the car He installed a roll bar and welded a 1/4" steel plate at the fire wall so he could p*** inspection at the drag races. They held races at abandon air strips.
    The car was red at first then around 1960 he painted the car
    Shenandoah green metallic, it was a 1956 ford Lincoln color.
    It looks like a blue metallic with a touch of green. Color looks nice Im planning to keep it. IMG_2926.jpeg IMG_2926.jpeg IMG_2930.jpeg IMG_2932.jpeg IMG_2931.jpeg
  6. sloppy jalopies
    sloppy jalopies
    love the car, gonna be cool, i have an extra steel dash to fit that aluminum insert... pm-ed you a pic. DSCN6485.JPG
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    Woke up and it’s 1960!
    Now you have a gem there.
    Fun project.
    Thanks for sharing.
    Don’t even think about changing the headlights and bar location.
    That initially dates it.
  8. 31Apickup
    31Apickup
    Nice find, along with getting the history. Some ch***is fixes are definitely needed.
  9. Very cool car and project!
    Trying to get a good look from your pictures at your engine vibration dampener...hard to see clearly, but it doesn't appear to be a k-code 271hp 289 (cobra, Shelby, k-code Mustang and Fairlane). If you post a better picture in that area, can provide confirmation.
  10. ModelARon
    ModelARon
    I am keeping the lights and bar location. There are two smaller lights attached to the bar to the right and left of each head light. Here is a picture of the car about 1963 you car see the two small lights attached to the bar. Not sure how i should wire them. Or how they were hooked up.
  11. ModelARon
    ModelARon
    The block casting for the engine is C5ae-6015-e. 65-67 289 HiPo. The top loader has is an early 1965
    289 & 289 HiPo mustang HEH-T code. Dual-point distributor and looks like it has the HIPO exhaust manifolds . He said he polished the cast iron manifolds and had a friend who did chroming for him.
  12. RM209
    RM209
    from MD
    Congratulations! What a great find!!
  13. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Wow. Congrats and best wishes on the rebuild.
    The hipo 289 you have is a high value engine, not for its performance, but for its rarity. Restorers of K code (hipo) Mustangs, Cougars and Falcons will pay top dollar for an engine like you have.
    The toploader decodes as HEH-T 1965 Mustang 289 close ratio box made between 8/20/64 - 10/1/64. As we all know 4 speed toploaders are selling for crazy numbers. That's a gem, the history makes it even better. That the PO was a top drawer guy when he was buying stuff is impressive. Now fix all the bad fab ch***is stuff and you are poopin' in tall cotton. Subscribed.
  14. Tim
    Tim
    from KCMO
    Holy cow!
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Wow! Great car and some amazing history. Keep us posted!
    winduptoy, kadillackid and Just Gary like this.
  16. 40Standard
    40Standard
    from Indy
  17. ModelARon
    ModelARon
    A heavy bracket is bolted to the engine and is bolted to a rubber trans mount that is welded to the front cross member. Was this to keep the engine from twisting? The frame has lots of problems , it's twisted
    I don't like the motor mounts. It's been cut and welded in many places.
    Too much work was needed so i picked up a nice model A frame to work with. IMG_1579.jpg IMG_1580.jpg IMG_1574.jpg IMG_1550.jpg
  18. ModelARon
    ModelARon
    Welded in some plates to boxed the frame . IMG_1762.jpg IMG_1761.jpg IMG_1852.jpg IMG_1837.jpg
  19. stillrunners
    stillrunners
    from dallas
    Cool find....a lot of stuff was done back in the day -just think way before the internet and computers in some one's garage....carry on !
  20. Okay, now that my brain is experiencing sensory overload after reading the story on this car I have to say I love it.
  21. I'm not trying to rain on your parade about the hipo motor...I'm trying to confirm that what you have is indeed a very valuable k-code hipo 271 hp engine. From what I see of the exhaust manifolds on the car, they do not appear to be correct for the hipo (though it's difficult to see a good view of the driver's side...and they could have been changed for regular manifolds for the sake of clearance). Below are photos of k-code hipo exhaust manifolds.
    If you take a picture showing the width of the vibration dampener, that will certainly help to confirm...as will a close up of the valve springs in the heads to confirm whether the heads have the hipo only cast in pockets to stabilize the valve springs at high rpm.
    Once you remove the oil pan, you can look for the football shaped 3/8" connecting rod bolts, the balancing hatchet on the snout of the crankshaft, and of course the larger main bearing caps (same as the "Mexican" 302 blocks).
    Again, I say that is a very cool find and car!
  22. Petejoe
    Petejoe
    from Zoar, Ohio
    I’d guess turn signals.
    Seems to me they’d be hard to see at an intersection.
  23. ModelARon
    ModelARon
    Thanks for the nice comments on this car. As i find all this cool history about this car and
    and this hobby i felt the need to share this with others who love this stuff. Win. Win.
  24. sloppy jalopies
    sloppy jalopies
    love the '63 pic...
    you didn't like the motor mounts...
    i make my own SBF motor mounts, they bolt to the heads [2 bolts right, 3 bolts left]
    i use flat head mounts and biscuits... don't care for any of ford's SBF mounts...
  25. ModelARon
    ModelARon
    No worries this won't rain on my parade. This engine is turning out to be a mystery.
    Apparently frank ordered this from a local ford dealer and installed it in the car in 1965.
    The exhaust manifolds are slightly different. After some researching the engine the damper is the
    thinner one not the "K code." Looks like the water pump , fuel pump , and distributor have the
    "k code" casting #'s all dating correctly for this engine. Not sure if someone would go to all the trouble in the 1960's to find and install all the correct "k coded" and date coded water pump, fuel pump, distributor for an old hotrod. Mustang yes.
    Wow one search on ebay and they are asking crazy $ for these parts.
    What ever it is it puts a smile on my face ever time i work on this car.
    It's my therapy to go and turn wrenches on this car.
    Here is a picture of the water pump with casting #. IMG_3019.jpeg IMG_3018.jpeg
  26. ModelARon
    ModelARon
    Here is a picture of Frank with his car. He lived in Paramus NJ worked as a mechanic for the police and fire department of Paramus. If any one o the East cost has info about this car i would love to hear about it. Also a picture of the car in 1965 at the New York Colosseum . You can see the cobra valve cover in this picture. IMG_3021 2.jpeg IMG_2925.jpeg In the early 1960's he stopped racing the car and turned it into a show car.
  27. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Reminds me of that kid on American Hot Rod who wouldn’t box his frame rails. Boyd offered the kid a dream of a lifetime. I boxed a 40 Ford frame in once, heard nothing but **** from the Peanut Gallery! Good call on boxing your new frame!
  28. ModelARon
    ModelARon
    The GMC was cool. it had dual axel's , a separate gas generator for electricity and some type of power inverter. In poor shape sitting out for over 30 years. It was in front of the garage blocking the model A . A friend of mine had car jacks.
    We had to move the car side ways to get it out of the garage. Then we put plywood on the dirt to get the car around the house to a paved drive way so the flat bed could get his winch on the car.
  29. ModelARon
    ModelARon
  30. Budget36
    Budget36
    Loving it! Well preserved too.
