Technical 32 roadster seat ?
Discussion in 'Traditional Hot Rods' started by SDS, Mar 19, 2021.
  1. SDS
    SDS
    Anyone have suggestions on a cheap, but workable bench seat for a 1932 Ford roadster?
    ~thanks ahead of time
  2. da34guy
    da34guy
    Mid 80's early 90's Dodge caravan middle row is perfect once all the BS is unbolted off the bottom.
    25/50 bucs in the s****yard
  3. krylon32
    krylon32
    from Nebraska
    I've had most of the seats for my deuce roadsters hand made to fit the car by my upholster. I did do one roadster with a Glide seat from So-Cal which I really liked because of the adjustments, but this seat and cheap are not in the same time zone
  4. 19Eddy30
    19Eddy30
    from VA
    X2 on both post above
    32 = $ & $ & $ & more $!!!!!
    Then = most of time Divorceo_O some time's :)
    Lil32 likes this.
  5. swifty
    swifty
    Early 80's Mazda or Toyota pick-ups. They tilt forward for access behind the seat and have adjustable tracks. I used a Mazda for my 32 coupe, narrowed 8" and have another to do for my wife's 33-5 window. Got them free from a mate so price was right LOL
    Lil32 and stillrunners like this.
  6. THIRDPEDAL
    THIRDPEDAL
    I picked up the dodge caravan seat , had it upholstered with water Buffalo hide, great transformation form”pick and pull seat “ that was like $30.00 my 2ct’s mine is 30 A coupe ATTACH=full]5013103[/ATTACH] IMG_1664.JPG ]
  7. THIRDPEDAL
    THIRDPEDAL
  8. swifty
    swifty
    That looks great @THIRDPEDAL Did you have to narrow it or does it suit a late A OK?
    Much better unit than my Toyota or Mazda pick-up suggestion. I don't think we got Dodge Caravans here in Australia. Pity as they look like a good solution for early Ford hot rods instead of the $2000+ for a Glide or other aftermarket seat and foam.
    Lil32 likes this.
  9. THIRDPEDAL
    THIRDPEDAL
    Fit perfect , just to add some low tabs for attachment ...
    lothiandon1940 likes this.
  10. THIRDPEDAL
    THIRDPEDAL
  11. HellsHotRods
    HellsHotRods
    Why not make your own wood seat frames and then get some stock reproduction springs?
    stanlow69 and Lil32 like this.
  12. my2nd40
    my2nd40
    from Tennessee
    stanlow69 likes this.
  13. stanlow69
    stanlow69
    A 32 roadster deserves better than a mini van seat.
    kidcampbell71 likes this.
  14. sloppy jalopies
    sloppy jalopies
    a few brown school bus seats from ski resort transport bus...
    i intend to run the bus base, cut and add about 9" to top rail...
    then use another base as a back knowing it will leave about 3" between them...
    no recent pix ,
  15. $um Fun
    $um Fun
    from Nor Cal
    I didn't think cheap and 32 roadster went together.
  16. Make your own out plywood and foam. checkout Cory Taulberts roadster build thread for some pointers.
    Al.
  17. ol48
    ol48
    I install the glide fit was good and very comfortable
  18. Ruby32
    Ruby32
    32 33 or 34 fordor seats work great
