Technical 1940 Ford Tudor - Front Suspension
Discussion in 'Traditional Hot Rods' started by P Green, Mar 20, 2021.
  1. P Green
    P Green
    Hello... first post here.
    I recently bought a 40 Tudor... it's an Old Hot Rod that I was told was built in the 90s,,, but I would guess in the 70s. It has a 402 BigBlockChevy / TH400. The first thing I addressed after purchasing the car was the stock wishbone rubbing a hole into the ATF pan. The "ball" on the wishbone was not mounted to the frame ( the seller was driving it daily this way ). I found two ball caps with the rubber bushing and spaced it about 1.25" away from the frame to clear the wishbone from the ATF pan. It worked, for a little while... then it started rubbing again. I found the motor mounts were collapsed, so I replaced them... resulting in the engine lifting about 1/2". I also put a 1/4" spacer in the trans mount and that lifted the ATF pan about 1/4" off of the wishbone.
    Long story short, I've determined the front spring and shock(s) are not set up correctly which is causing the car to sit too low.... the current ride-height looks cool, but the "rubbing" is not worth the cool aesthetics. Along with the ATF being damaged, so is the steering box from the pitman arm.
    I have a 48" axle.
    Please view pictures and advise me if replacing the spring with a Poise #2040 and the Shackles/Shock Mount with a Pete & Jake #5001 is the right thing to do.
    Thank you.
    20210319_144042.jpg 20210319_143934.jpg 20210319_143826.jpg 20210319_143641.jpg 20210319_143428.jpg 20210319_143328.jpg 20210319_143309.jpg 20210319_142738.jpg 20210319_142310.jpg 20210319_142233.jpg 20210307_214605.jpg 20210304_133452.jpg 20210305_124332.jpg 20210220_101357.jpg View attachment 5012293
    chryslerfan55 and VF-1 like this.
  2. Well, your spring looks like it's well used, and flattening out. New spring should give you more ride height, and clearance at pan. Spacing the rear wishbone mount helps, but you should check caster with this in place. I have no experience with those specific parts you're suggesting, but just observing your pictures.
  3. lothiandon1940
    lothiandon1940
    The wishbones probably should have been split when the later drive-line was installed. A kit to do that would likely solve your issues. You would then need to heat and bend the front ends of the wishbones to re-align them at the shackles or do small pie cut reliefs on the wishbones. This all should have been done by whoever did the engine/ transmission swap to allow for clearance. There should be some threads on here regarding splitting the bones.
  4. VF-1
    VF-1
    Not relevant, but certainly a beautiful location (backdrop) in the photo with your two pups! My kind of backyard!!
    lothiandon1940 and P Green like this.
  5. P Green
    P Green
    Thanks. I've seen the split wishbone kit and considered it... but the fenderwell header exhaust system gets in the way of any split wishbone. Maybe later I will reroute the exhaust to accommodate a split wishbone.
  6. P Green
    P Green
    Thanks... been here 51 years... kind of take it for granted... :)
    VF-1 and chryslerfan55 like this.
  7. P Green
    P Green
    Thanks. Spring is definitely flat.
  8. Sorry, I commented above, but half asleep. the Split wishbone kit for 35-40 frame only moves the ball out from centerline a bit. The wishbone arms pretty well follow the x-member after splitting. You shouldn't have much of an issue with your exhaust, or easily rectified if so. This should give you the clearance needed for transmission pan.
  9. 48ford
    48ford
    Will longer shackles give you more clearance?
    P Green likes this.
  10. 48ford
    48ford
    I split the wish bones, look at speedway motors for the kit, that cleared the transmission
    It’s been a long time, but I remember I used shocks with overload springs on them( I think Chevy 1/2 ton)
    I really would like to send you pictures but car is still in winter storage.
    Picture in your mind, you can’t keep lowering the rear on the wish bones as that rotates the axle
    chryslerfan55, P Green and Algoma56 like this.
  11. BJR
    BJR
    Longer shackles will lower the car more giving less clearance.
    P Green likes this.
  12. mcsfabrication
    mcsfabrication
    Spring is "done". Doing a split bone and new spring should sort you out. Split the bone first, then measure for the length the spring needs to be if you have to heat the spring perch to get it straight after splitting the bone.
    Then, you can do the axle drop to get your ride height back. Haha, it's never easy. Cool car.
    P Green, Algoma56 and lothiandon1940 like this.
  13. Weedburner 40
    Weedburner 40
    What you have there is a pretty good mess. With the shock set-up, you have lost the sway bar, which is a big help on these cars. The Posie spring is too low. You should split the wishbone, we have a kit that would work real well and is not a lot of work. I would rebuilt the original spring and put liner in it, replace the shock kit with one that will allow you to replace the sway bar, both of which we carry. A dropped axle will allow you to keep the ride height and still have plenty of ride and clearance. Check out our website.
  14. Tim
    Tim
    from KCMO
    @Weedburner 40 is your go to expert in this situation.
    if you’re new to navigating this forum here is his website
    http://www.weedetrstreetrod.com/
    If you are on an iPhone turn it sideways for his website, works much better
  15. RAK
    RAK
    X2 on weedetr; have personally used his stuff on my 40 and it is of the highest quality and customer service is too.
    HotRodWorks, P Green and olscrounger like this.
  16. alchemy
    alchemy
    I see that spring is bent in a few places. It needs replacing, not just tuning up. And those headers are not your friend either.
    Use components from Weedeater, along with a new exhaust and you will be much happier.
    And, that car is NOT too low. When set up right, a 40 can look cool as well as perform well. You just need the right combo of parts.
  17. Weedburner 40
    Weedburner 40
    And, those guys are right, get rid of those headers..
  18. bchctybob
    bchctybob
    That’s quite the sleeper! Innocent looking Tudor with big block power, very cool. The advice about the weedetr front end upgrade is right on, it looks like your front spring, shocks, etc have seen better days. If you really don’t want to split the wishbone it may help to install a stock type transmission pan instead of the bulky aluminum one and service the trans while your at it.
    Me, I’d leave the headers on at least until you settle on the ride height and tires. Then if they are an issue maybe change. They are a cool old custom made part, help a BBC breathe better and are way more interesting than run of the mill block huggers or boring stock manifolds. Hey, it’s a neat old build as is, you just need to fix the suspension.
    greener200, chryslerfan55 and P Green like this.
  19. hotrodA
    hotrodA
    Nice Tudor!
    Like others have said:
    New spring with reversed eyes.
    New shocks with mounts
    Split wishbone kit if still needed for clearance
    Sway bar if desired.
    It looks like you have a stock axle. The new spring will raise the ride height back UP. You might consider a dropped axle to get it back down. But, that will require dropping or replacing the steering arms for clearance.
    Like this:
  20. LongT
    LongT
    How does your front swaybar mount, 1939 Ford, attach to the axle? I have a dropped Ford axle with a tubular shock kit. I don't know who's it is. It has a bolt on tower on top with a long spring perch bolt on the bottom. I have a Posie's reverse eye spring also.
    Thanks,
    Bill
  21. Weedburner 40
    Weedburner 40
    Sway bar links to the top of the perch pin. It won't fit with your shock setup. Our shock kit also attaches to the perch pin.
    P Green, lothiandon1940 and LongT like this.
  22. woodiewagon46
    woodiewagon46
    from New York
    First of all you need to replace your front spring. You also need to split your wishbones. I know that Ch***is Engineering is no longer in business, but I heard that someone has purchased their inventory. I don't have a CE catalog, but I used their part number ES-2178 to split the wishbones in my '46 Woodie. If you can get a catalog you can look up my part number and see how it is used. 1940 will be different, but it's the same basic design. The wishbone ball is eliminated and tie rod ends must be screwed into bungs that will need to be welded on the ends once the ball is cut off. The spring purchases will also be heated and bent to compensate for the moving of the wishbone outward.
  23. okiedokie
    okiedokie
    from Ok
    I would buy from Weedburner40 myself but Heidts has the CE inventory and manufacturing.
    olscrounger and lothiandon1940 like this.
  24. Bigmac48
    Bigmac48
    from Dundalk Md
    image.jpeg image.jpeg Yep , check Dale at Weedetr , made me "happy happy " and very road friendly before - after
  25. P Green
    P Green
    Thank you for all the suggestions and pictures!
    I picked up a "Donor" Car on Saturday, it has an SBC with A-Arm Suspension. Going to do a Ch***is swap. 20210322_092556.jpg 20210322_091932.jpg 20210322_091745.jpg 20210322_091757.jpg
  26. P Green
    P Green
  27. 31Apickup
    31Apickup
    What do you mean ch***is swap, hope you aren’t planning to swap that a-arm ch***is to under the 40 std.
  28. Zax
    Zax
    Maybe the pics aren't showing it's true condition. But your donor car looks nicer than what a lot of people on here start with for their project.
  29. P Green
    P Green
    Yes, that is my plan... but would like to hear your reason(s) for objecting.
  30. P Green
    P Green
    Considering how poorly cars age in Hawaii, this shell is extremely salvageable... I plan on putting the shell up for sale
    once I pull the ch***is out from under it.
