Projects HotRod Rebuild
Discussion in 'Traditional Hot Rods' started by ModelARon, Mar 18, 2021.
  1. Love it Model A Ron! K-Code or not, a solid little 289 /4-speed is a great motivator. I’m subscribing. Make sure you post a video of it up and running here at some point. FWIW, I think I remember that a lot of stock ‘65 parts have casting numbers that are also “correct” for a K-Code, so that’s not always the best way to tell. I think that’s maybe where @anothercarguy was coming from with his comments, but, then again, I have forgotten more than I actually remember about this stuff. Thanks for sharing.
  2. Aaron D.
    Aaron D.
    It's more than likely Frank bought the K-code Cobra motor, then used whatever accessories that made it fit better in the car.
    indyjps, loudbang and Budget36 like this.
  3. ModelARon
    ModelARon
    From what i can have seen i think this grill is form a 1932 commercial truck or van.
    It fits the radiator and was in with the parts that came with the car. Some one did a nice job
    of welding the filler hole in the top of the grill. Can someone confirm what the grill and radiator are from? IMG_1560.jpeg IMG_0520.jpeg IMG_1559.jpeg
  4. 31Apickup
    31Apickup
    Grill shell is commercial 32 ( pickup or truck), radiator looks like a modified original 32.
    winduptoy, loudbang, slv63 and 2 others like this.
  5. guitarguy
    guitarguy
    Man, Cool find. I love cars like this. Subscribed.
  6. Stogy
    Stogy
    Congrats on this Hotrod acquisition @ModelARon...it's great that you have so many period pics to help with where you want to go with it...the 70s look is going to the Moon...great to hear!! Have fun with it...
  7. Stogy
    Stogy
    He probably got it for $25 and wrote the bill up for $50 just not to look to obvious he got a steal of a deal...:D
  8. ModelARon
    ModelARon
    Frank bought the dropped axel from a speed shop. How do i figure out how many inches the axel was dropped? Did they bend them different sizes? What do the stamping mean? #3 and the F in the triangle. Just like to know what this is. IMG_1952.jpg
  9. ModelARon
    ModelARon
    thanks for that info
    chryslerfan55, loudbang and Stogy like this.
  10. ModelARon
    ModelARon
    Here is the set up that he built. If i were 17 and back 1954 I might roll the dice with this set up.
    The holes in the rear bumper bracket to hold the top shock bolt were made with a torch.
    He loved the torch , seems like the torch was his go tool. He made brackets and Gas welded them to the axel. Frank told me he became a certified gas welder. This car must have been his first go at it. The swing arms he cut off an old car in the junk yard . He could not remember what car they came from . It's only been about 65 years ago. And the shock bracket looks like some thing from and old impala. IMG_1933.jpg IMG_1936.jpg IMG_1981.jpg
  11. ModelARon
    ModelARon
    Cutting the brackets off the axel was taking forever and i could not get the grinder inside the bracket to cut the inside weld so i went to the torch. After i torched them off i noticed the tubes were bent.
    I think that was from the heat but i am not sure if they were bent before . Also the axel is too long and the tires are too many inches away from the body of the car. I decided to get a new housing.
    I had Pete and Jakes make me a new set up they welded the spring mount and shock mount.
    I liked the look of the ladder bars so i now have ladder bars. IMG_2246.jpg IMG_2245.jpg IMG_2244.jpg
  12. Stogy
    Stogy
    Could that be a symbol of Forged...that's a pretty uniform drop it seems...I gonna guess 3"...
  13. ModelARon
    ModelARon
    I took the 9" ford rear apart and found an opened differential . After counting the teeth on the ring and pinion gear it has a 4.57 ratio. At first i though i would leave the 4.57 , but it might be too much for a beer getter. So i installed 3.89 set. I could always pop the old set back in if i need to.
    After watching a few videos ( many times) I installed new bearings, seals and the gear set.
    Also installed a Detroit Truetrac diff. IMG_0454.jpg IMG_2362.jpg IMG_0519.jpg IMG_0513.jpg IMG_2392.jpg
    The housing had a red paint so i cleaned it up and used the same color. and gears.
    Told the wife I need to buy a dial indicator so i can save some $ installing this my self. Ha Ha
  14. 282doorUK
    282doorUK
    Great find! Subscribed for the ride..
    Stogy and loudbang like this.
  15. neds29
    neds29
    New Wilton vice. Nice.
  16. ModelARon
    ModelARon
    well its a few years old . I just keep telling the wife this stuff will save me $$
  17. ModelARon
    ModelARon
    Working on the rear brakes i had a problem with the spring mount . The brake cylinder was behind the spring mount. I had no clearance to attach the brake line. So i welded the holes on the plate. Drilled new holes and rotated the rear plate so i could screw in the brake line. I clamped a copper s**** behind the hole as i welded the holes. The best i could tell the brakes are from a 1961 Galaxie IMG_2559.jpg IMG_2558.jpg IMG_2557.jpg IMG_0504.jpg
  18. ModelARon
    ModelARon
    After installing the stock spring the car seemed too high. So i went with a reverse eye spring that will bring the rear down . Installed the ladder bars IMG_2071.jpg IMG_2964.jpg
  19. ModelARon
    ModelARon
    The tunnel ram had some mice living on it and they made a mess that i could not clean off.
    I had that part bead blasted. The engine was clean inside so i installed new water pump, oil pump , gaskets . I rebuild the holly carbs , they are 4160 390 cfm . I though the Hilborn style scoop would fit this 60's hotrod IMG_1427.jpg IMG_1428.jpg IMG_1562.jpg IMG_1706.jpg
  20. ModelARon
    ModelARon
    I took the old drive shaft to a shop to have a new one made . The guy told me the old shaft was out of phase. The yokes should line up. I am learning all the time on this project. I don't think it was balanced. IMG_0588.jpg
  21. ModelARon
    ModelARon
    Talking with Frank one day i asked him if he had any other items from the car.
    He told me he had some old trophies in his garage that he almost tossed in the garbage last year.
    IMG_3051.jpeg IMG_3050.jpeg IMG_0730.jpg IMG_3052.jpeg IMG_3053.jpeg He said he would give them to me but he would not ship them.
    I was surprised he kept these for so many years. So i drove up to New Hampshire one weekend to pick them up. I cleaned up the trophies . Two of the trophies are in the picture from 1965 at the show in the New York Colosseum . He won the blue trophy that year. Drivin Deuces was an old car club in North Jersery.
  22. 31Apickup
    31Apickup
    Nice update in the rear suspension. My A pickup had a similar setup, with all flame cut brackets, nothing ground down, they used what they could find at the time.
    chryslerfan55, Stogy and loudbang like this.
  23. sidevalve8ba
    sidevalve8ba
    Subscribed! If yours is anything like my Model A you can eliminate a few plies out of that rear spring. I found that the car rode better and it also lowered the rear of the car some.
    Vic Walter, Stogy and loudbang like this.
  24. ModelARon
    ModelARon
    Thanks. This car has some parts that were just cut with a torch . Build by a kid in the 1950's.
    I plan on keeping as much of this as i can but make it safer. I think it keeps the history of what was done back in the day . IMG_0493.jpg IMG_0624.jpg IMG_0560.jpg
  25. KJSR
    KJSR
    from Utah
    Awesome thread. Thanks for sharing!
  26. oldiron 440
    oldiron 440
    Very cool mid 60s hotrod!
  27. ModelARon
    ModelARon
    Glade you said that because the after putting the new spring on i felt it was too high and stiff so i think i took off two leafs . I will see how this works as i get this on the road.
  28. ModelARon
    ModelARon
    I had the flywheel cleaned up. The old clutch look good but I wanted something better. I installed a Center Force Dual friction clutch. IMG_3073.jpeg IMG_0496.jpg
  29. ModelARon
    ModelARon
    The front brake cylinder must be real old, i have never seen one that was made by Lockhead.
    Checking the rims to make sure they fit. I am keeping the drum brakes look great. I am thinking about installing Lincoln style front brakes because i read they have better stopping power . IMG_2848.jpg IMG_0512.jpeg IMG_0680 2.jpeg IMG_0679 2.jpeg IMG_0411.jpg
  30. ModelARon
    ModelARon
    I cleaned up the dash and gauges. I didn't want to strip the wood and lose that patina and the cracks in the finish . I just gave it a coat of tung oil finish IMG_3083.jpeg IMG_0792.jpeg
