  1. 1910 UNIC truck, 1927 Chenard & Walcker cut down sedan to tow-truck with fancy Marchal headlights, 1927 FIAT, 1934 Ford Y, mid 1950s Renault Juvaquatre,
    1914 UNIC.jpg 1927 Chenard & Walcker.jpg 1927 FIAT.jpeg 1934 Ford Y type.jpg Renault Juvaquatre.jpg
  2. FalconMan
    FalconMan
    from Minnesota
    Sorry, I didn't take a close look. If I had the time the taillights could of been had for $15 each. Slight pitting.... rare peices.
    Sent from my SM-G965U using The H.A.M.B. mobile app
    Torkwrench, chryslerfan55 and Thor1 like this.
  3. moparboy440
    moparboy440
    from Finland
  4. ozdragnut
    ozdragnut
    from Australia
    Just rescued from a farm in western NSW. IMG_20201210_162913M.jpg IMG_20201210_163110M.jpg
  5. spanners
    spanners
    Dang it. I'd love the tub off that one. I've got a cab ch***is for potential nostalgia drag duty.
    Thor1 and chryslerfan55 like this.
  6. ozdragnut
    ozdragnut
    from Australia
    I,ve got similar plans for my A40. the tub is all aluminium skin with light steel skeleton and wheel tubs.
    Not difficult to build one. Give us a shout if you need measurements.
    mitch 36, chryslerfan55 and Thor1 like this.
  7. spanners
    spanners
    Shall do. Thank you
  8. Torkwrench
    Torkwrench
    Looks like the p***enger side windshield post, and part of the cowl / dash has been cut out. Too bad, otherwise the wagon looks pretty good.
  9. Don,t be fooled by the aluminium ( aluminum :D) tub. It,s a heavy unit, even without the wooden floor. Heres the rock solid A40 ute that i found in Spain about 20 years ago. Became a g***er in the U.K. I also had a A70 Hampshire ute that came from Denmark. Sold that to the U.K. as well :rolleyes:. BTW, every A40 ute i have ever seen has the same angle-iron rear bumber and tailgate hinge.
    VANDENPLAS, Sandgroper, Thor1 and 3 others like this.
  10. Jalopy Joker
    Jalopy Joker
  11. Maverick Daddy
    Maverick Daddy
    In Greeville Alabama, but sitting and rotting no more. My friend saved it this morning . 20210321_195944.jpeg
    Sent from my SM-J727V using The H.A.M.B. mobile app
  12. fourspd2quad
    fourspd2quad
  13. ozdragnut
    ozdragnut
    from Australia
    Nice one 34Gaz, mine has a rusty floor but otherwise solid. Will modify firewall and tunnel for g***er duty.
    Sandgroper likes this.
  14. moparboy440
    moparboy440
    from Finland
  15. 20210323_123341.jpg 20210323_124144.jpg 20210323_131100.jpg Kinda saved this one today. Now it can sit and rot at my place until I figure out a plan.
  16. And I've got a couple more to go back for 20210323_122632.jpg 20210323_122409.jpg
  17. Squablow
    Squablow
    Wow, I never knew you could get bumper wings on a Canadian Dodge, looks like rear only, which makes sense since they wouldn't fit on the Dodge style front bumper. But those rear bumper ends are worth some pretty serious coin. The whole car looks very restorable, in fact.
  18. Barn Hunter
    Barn Hunter
  19. 56don
    56don
    I would use a different frame if I were you....;)
  20. Fabber McGee
    Fabber McGee
    I agree, the wheelbase is a bit short.
    chryslerfan55, Thor1 and Barn Hunter like this.
  21. Barn Hunter
    Barn Hunter
    Ha!! It actually comes with all the original parts including rolling frame, fenders, hood, rad. & shell, etc.
  22. MO54Frank
    MO54Frank
    I like the 67 Chevy pickup that’s on the lift/rack. Hope it gets saved.
    exterminator, 40two, Lil32 and 7 others like this.
  23. moparboy440
    moparboy440
    from Finland
  24. Jalopy Joker
    Jalopy Joker
  25. RMR&C
    RMR&C
    from NW Montana
  26. fourspd2quad
    fourspd2quad
    That's what happens when you run straight water through a flathead. ;)
    RMR&C, Lil32, 33Doll and 1 other person like this.
  27. chessterd5
    chessterd5
    from u.s.a.
    Every couple of months, I tip toe through this thread cause I tell myself that I'm strong enough this time. Then I see the carnage and the waste and I wonder how people can throw away perfectly good things.
  28. 33Doll
    33Doll
  29. MO54Frank
    MO54Frank
    Another Advance-Design 5W pickup rotting away. IF I could I would try to save them all... but I can’t. And really that’s okay. Hopefully someone will rescue it.
