Technical Can a 1932 Ford drive train survive a 283 sbc
Discussion in 'The Hokey Ass Message Board' started by AZdeuce, Mar 20, 2021.
  1. AZdeuce
    AZdeuce
    If you have a stock 2 barrel 1962 283 sbc and:
    If you gently shift into first gear, and gently engage the clutch, and only then, slam the gas peddle to the floor, will the stock 32 gears (in a 39 case), or the driveshaft, or the rear axles break?
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    From my experience, the spider gears will give up first:eek:
    TCATTC likes this.
  3. Guys have been doing it since the 50"s with bigger OHV engines than that.Trick is to take it easy. Good
    trick if ya can do it.
  4. Deuce Daddy Don
    Deuce Daddy Don
    Haaaaa!!!------Be prepared to "Shear the cob" in that '39 box!!
  5. Sure.
    Unfortunately there are very little replacement parts to be found in junk yards if you drive it like a hot rod should be driven.
  6. woodiewagon46
    woodiewagon46
    from New York
    As others point out, that swap was common back in the '50s and '60s. The only drawback are the weak links once you get too crazy with your right foot. Once you break something in the trans or the rear, it's quite a repair job.
  7. jaw22w
    jaw22w
    from Indiana
    I see a propensity here, so.... No!
    TCATTC likes this.
  8. Mr48chev
    If or how many parts will break all depends on the amount of lead in the right foot.
    I've known guys who you could put in that rig with a 400 hp 327 in it and they wouldn't tear up a thing and the rear tires would probably last more miles than what the maker said they were good for. On the other hand I know a few people and have been related to a couple that can tear up steel balls with a rubber hammer in the middle of a sand pile.
    It's all on the driver as far as tearing something up goes not what engine is in front of what transmission.
  9. 302GMC
    302GMC
    from Idaho
    My money's on the cluster hitting the ground before the gear lube ...
    Budget36 and TCATTC like this.
  10. larry k
    larry k
    “ NO “
    TCATTC likes this.
  11. Truckedup
    Truckedup
    what fun is a hotrod that can't be flogged
  12. J'st Wandering
    J'st Wandering
    Yes, it will last if you want it to. What you put on the back for tires will help also.
    I do not know much about 283's other than I had one in a pickup. It wasn't much different than a flathead that I have in a Model A. The model A has a flathead with 39 transmission and Model A rear end. As traditional as it gets and it has stood up fine.
    Anything can fail. I had the axle key shear in a stock Model A.
  13. fastcar1953
    fastcar1953
    Just don't get traction.
    Tim likes this.
  14. bobd1976
    bobd1976
    from Illinois
    I was a p***enger in a 41 Ford pickup with a 307 Chevy in front of the stock 3 speed on the floor when second gear was selected the aforementioned ****** self destructed! lol
  15. 2935ford
    2935ford
    I ran a stock 265 SBC and stock restored '32 trans and rear axle in my '32 pickup. I had no issues but, I was never a lead foot!
    Algoma56 likes this.
  16. Pete1
    Pete1
    from Wa.
    Maybe, but no if you make a few simple mods to things.
    The weak point is the transmission with stock 28 gears. You maybe have 200 hp and there were a lot of flatheads that made that back in the old days when stock parts were all there was.
    Don't side step the clutch and don't go WOT till you are rolling and the drive train will last fairly well.
    I went 3 years on one 39 transmission and a 32 rear end. However, I did have 25 tooth gears, lapped axles and saftey hubs. That was weekend drags, 2 times at Bonneville and a couple of road races.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    I put a 331 Caddy in my 40 with the stock trans and rear end about10 years ago. I have not had any trouble. I run 8.20-15 Bf Goodrich silvertown bias plies on the back, the tread width is something like 5 inches, I have spun the tires dozens and dozens of times with no problems.... I am pretty sure you won't have trouble if you run skinny tires... traction will be the enemy..
    Packrat, Lil32, warbird1 and 3 others like this.
  18. LOU WELLS
    LOU WELLS
    from IDAHO
  19. Wheeliedave
    Wheeliedave
    I had a 1937 Lincoln Zephyr coupe in the mid 60’s with a mildly warmed up 265 Chevy. I recall replacing synchronizers in the Ford/LZ trans but I also recall breaking at least one rear axle.
    It worked but I would suggest a better trans and rear end.
  20. tub1
    tub1
    from tasmania
    Check my avatar pic 283 35 trans same as 32 trans and yes I drive reasonably steady but have confidence to drive it any were only killed one trans in 20 years and that was a 39 trans the shyncro blocks popped out but no gear damage
  21. Fogger
    Fogger
    I built my 3W as a Hot Rod, so if I flog it I'm not worried about breakage. On the other hand I built my '32 Roadster as a cruiser, '57 283, '39 trans with a 25 tooth gear set and a Columbia rear axle. Been driving the Roadster for 15 years with no breakages or problems. So as others have stated, it all depends on how you treat the old trans and rear ends. EP1120539_JPG.jpg
    draggin49, A Boner, harpo1313 and 3 others like this.
  22. My roadster has a 265" SBC with tri-power, driving through a 1932 ford transmission and rear end. I jump on it once in a while, but not totally stupid launches. I can chirp the tires in first and second gear if I want to, but I usually just behave myself. Drive modestly and you shouldn't have any problems.
  23. AZdeuce
    AZdeuce
    Thanks for all the great feedback.
    I hadn’t considered the spider gears. I have a spare set and they do look fragile.
    I drove the 32 for 8150 miles over 13 years, and then the driveshaft sheared at the weld.
    I think it was a fatigue failure; since I wasn’t pushing it at all.
    I replaced the driveshaft and have driven this shaft 7019 miles for 34 years (so far).
    I have two backup driveshafts, two spare axles, one set of spider gears, a 1939 case full of decent 1932 gears (I remember that the bearings need replacement).
    I guess I will continue to drive like a little old lady.
    AHotRod, Lil32 and warbird1 like this.
  24. AngleDrive
    AngleDrive
    from Florida
    20190811_100013.jpg The Ford drive train acts as a very good rev limiter (but YOU have to control it)
    warbird1 likes this.
  25. jimmy six
    jimmy six
    Skinny rear tires, 32 psi recommended..
    Lil32 likes this.
  26. Blake 27
    Blake 27
    My good friend Sam owned and drove this deuce for three years. HPIM0113.JPG HPIM0114.JPG HPIM0115.JPG Rebuilt 283, 39 trans, and stock 32 rear end. He sold it around 2005, and the currant owner still has the same set-up without problem.
  27. ronnieroadster
    ronnieroadster
    Just be very gentile with the transmission and you will be fine. Now about the 32 spider gears just a little axle chatter caused by the clutch chattering and you will find that weak link. Good luck.
    Ronnieroadster
  28. rob-redm
    rob-redm
    have 39 Ford box behind my 283 and banjo... Had a one issue with a coupling.. other than that no issues.. stock 6.00 X 16 Firestone Deluxe Champions ..
  29. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    You should be fine as long as you put an egg between your right foot and the gas pedal;)
    Budget36 likes this.
  30. jaracer
    jaracer
    I remember the rear hub keys being a weak point.
