Technical Large shear. Any good for sheet metal?
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Mar 20, 2021.
    any good for the stuff we do?
    stanlow69 likes this.
  2. Paulz
    Paulz
    Looks like powered Throatless shear... Neat.
  3. Yep. Just wondering if it’s good for the thin metal we use
    I’ve never seen one like this.
  4. For scale - how big is it?
  6. I want to see a video of it running
  7. I don’t think the owner knows much about it.
    Looks like the something is missing
  8. Marty Strode
    Marty Strode
    Don't see the motor, looks like the handle on the right is a clutch.
    kidcampbell71 and anthony myrick like this.
  9. bigdog
    bigdog
    Looks like a rotary throatless shear. If I had a chance to get it I'd have another tool I don't have room for in my shop.
    anthony myrick likes this.
  10. fastcar1953
    fastcar1953
    I would try it for a couple hundred dollars. How much could it be bought for? The stand and other parts could be repurposed if it didn't work out.
    Scrap price would be close to $200 I would think.
  11. Asking 300
    tb33anda3rd likes this.
  12. fastcar1953
    fastcar1953
    I would buy it if you have the room for it. Yes it would work great in hot rod shop. It should cut up to 12 or 14 gauge metal. $300 not that much considering it's size and uses.
  13. Russco
    Russco
    from Central IL
    So it’s like a powered Beverly shear?
  14. stanlow69
    stanlow69
    Why haven`t you bought it yet.
  15. gimpyshotrods
    gimpyshotrods
    I have a Marshaltown rotary throatless shear. Mine is smaller and hand powered. Kept sharp, it works well.
    I can get speedy cut on it on 18ga. I use my Beverly B3 for anything thicker.
  16. I guess I was interested because it looked cool
    I think I would rather invest the $ in a bench mounted throatless shear.
    I still going to see how good a deal I could get on it.
    It does have a cool novelty quality.
    Pist-n-Broke likes this.
  17. Jethro
    Jethro
    Buy it for $300 and sell it to a hipster in a coffee shop for $2000:D
    Tman, anthony myrick and Budget36 like this.
  18. Budget36
    Budget36
    I’d buy it, probably never use it, but I’d still buy it!
  19. A throat less sheer that size typically is used for thicker sheet stock. There fore cutting way thinner stock may require the cutting edges be sharpened and adjusted . Otherwise this could just bend the cutting line on the thinner sheet stock and not cutting.
    Vic
    lostone and flatford39 like this.
  20. I was also working out how ya use it.
    Looks like you feed with one hand and work the clutch handle with the other?
    Seems awkward unless it turns super slow.
    If you could work it with a foot pedal than that would be much easier to use.
    At least in my brain
  21. Marty Strode
    Marty Strode
    If you look at the pulley size, they do turn quite slow. I ran one similar, only it was a large C-frame, heavy casting.
  22. "artisanal"
    Here’s ya a 48x1/4 shear.
    Also missing the motor
    Budget36 likes this.
  24. stanlow69
    stanlow69
    I`d think it is at least a 2 man operation.
  25. Mr48chev
    That may have been converted from belt drive some time in it's life. A local machine shop has some old belt driven units outside that are probably more in line with the idea of it being a decorative piece.
  26. Yep. Owner said it was there when they bought the property.
