Hot Rods Rearend swap for 47 Desoto
Discussion in 'The Hokey Ass Message Board' started by stoke, Mar 20, 2021.
  1. stoke
    stoke
    from monroe,wi
    Anybody know what later model rear end will fit in a 1947 Desoto without too much trouble? Thanks
  2. Bird man
    Bird man
    from Milwaukee
    Looking to add disks or a limited slip? Or maybe just some more mild gears, what are your goals...
  3. trollst
    trollst
    I would think a ford ranger 8.8 would be perfect, simple, widely available and not expensive.
  4. stoke
    stoke
    from monroe,wi
    Just need a rearend with emergency brake setup and modern hub setup Thanks
  5. Orn
    Orn
    In my previous -40 Plymouth I use a Jeep Cherokee Dana 35 rear. It was a perfect size and I think it had 3.23:1 ratio. plym36.jpg
    mgtstumpy likes this.
  6. Hard to give a definitive recommendation without more information. In doing a rear axle swap, there are several factors to consider- what is the WMS (wheel mounting surface) to WMS? Bolt circle for wheels? Pinion centered or off centered? Desired ratio? How does it attach (coil vs. leaf)? How much fabrication/modification are you willing to do? How available are parts for the axle/brake ***embly? I think yours is leaf spring, so you would want to look in that direction. The Ford 8.8 already mentioned out of Ranger Pickups are a good choice, but will require "flipping" the spring pads, and I think the pinion is slightly off center.
