Hot Rods 1934 Ford original frame
Discussion in 'The Hokey Ass Message Board' started by Beezer, Mar 21, 2021.
  1. Beezer
    Beezer
    from Michigan
    Found an original 1934 Ford frame.
    Any ideas as to what a frame like this might be worth??
    It’s been sitting for years which is evident by the trees growing through the frame.
    34 GAZ likes this.
  2. captainjunk#2
    captainjunk#2
    maaan thats nicer than anything ive ever found in the woods ,
  3. Beezer
    Beezer
    from Michigan
    Any idea what it might be worth to buy?
  4. oldiron 440
    oldiron 440
    Start low and don't drool!
  5. Squablow
    Squablow
    Those front shock mounts are later additions. Is there anything else hotrodded on this? Does it have hydraulic brakes? It looks decent from here. It really depends on condition and whatnot, but I could see this frame having a retail value of $1500 to someone who needs one. The front wishbone and axle add quite a bit of value over just a bare frame, same for the wavy rear spring that is a 33/34 only thing. That's ***uming it's not rotted out badly anywhere. Maybe more, maybe less depending.
    Of course, if I was buying, I'd offer $500 and go up from there. Do you have a need for it?
  6. 31Apickup
    31Apickup
    RICH B likes this.
  7. Beezer
    Beezer
    from Michigan
    Thought I’d scarf it up if the price was right.
    He’s had it for 50 years, outdoors no less. It’s not pristine by no means because I see some old cobbled up welding that was done on certain places on the frame, but thought it was kind of a nice ole piece to have I guess. Came out of Texas to Michigan in 1961 before he got it.
    QUOTE="Squablow, post: 13996135, member: 5943"]Those front shock mounts are later additions. Is there anything else hotrodded on this? Does it have hydraulic brakes? It looks decent from here. It really depends on condition and whatnot, but I could see this frame having a retail value of $1500 to someone who needs one. The front wishbone and axle add quite a bit of value over just a bare frame, same for the wavy rear spring that is a 33/34 only thing. That's ***uming it's not rotted out badly anywhere. Maybe more, maybe less depending.
    Of course, if I was buying, I'd offer $500 and go up from there. Do you have a need for it?[/QUOTE]
  8. alchemy
    alchemy
    I see rust holes on the inside of the rear kick up. But it does have a dropped axle, intact wishbone, and later brakes and spindles. Probably $1,000 worth around here.
  9. Squablow
    Squablow
    If it's a good price, it's definitely worth getting, it needs to be dug out of the dirt and brought inside. Definitely some hotrod value there. Hard to pin down a dollar amount based on limited info, but if it's only a few hundred bucks or something, you're nuts not to jump on it.
  10. Speed Gems
    Speed Gems
    I don't know what it's worth too buy, but it's worth getting out of the woods before the tree between the rear axle and crossmember gets any bigger.:eek: And @Squablow is right about the front shocks.
  11. hotrodjack33
    hotrodjack33
    That would be considered $1000+ pretty good frame in my neck of the woods. Probably the reason it faired so well is it didn't have a rusty body sitting on it, trapping moisture.
  12. Did he show you the old 3 window coupe body that was on there first:oops: , out in the back shed :D?
    Pitbullgoingpostal likes this.
  13. millersgarage
    millersgarage
    Where in Michigan??
    That's a worthy frame
  14. Beezer
    Beezer
    from Michigan
    Ironically, that was what sat on this frame back in the early 70’s. Sadly, that 3 Window Coupe is long gone now.
    34 GAZ likes this.
