Technical 49-52 pontiac steering gear
Discussion in 'The Hokey Ass Message Board' started by Malibu406, Mar 21, 2021.
  1. Malibu406
    Malibu406
    Does anyone know the part numbers to convert the pitman bushings to needle bearings? Not having much luck finding a rebuild kit of any kind.
  2. Hi, I had been told that 1949 thru 1952 Chevy had the bushing design & then for 1953 & 1954 Chevy had the bearing design. I have never confirmed it - but I would think you might check into a 1953 0r 1954 Pontiac/Chevy car steering gearbox. As far as getting a kit for a 1953 or 1954 to put into (if it would work) a 1949 thru 1952 gearbox you would be the guy to confirm it one way or the other. Sorry I can't give you more info on that.
  3. Malibu406
    Malibu406
    Thx I believe your correct on the years. There was an old post I saw here where a guy said a local shop rebuilt hos with needle bearings, but no other information. I have been keeping my eye out for a 53/54 pontiac steering gear, but nothing yet.
  4. Rocky
    Rocky
    Classified Editor
    Well, let me know if you find 2 of them as I'd like one for my 50 Pontiac.
  5. fyrffytr1
    fyrffytr1
    Make that three! I could use one for my 50 as well.
  6. miller
    miller
    from New Jersey
    try Kanters in Booton New Jersey .....miller
  7. Malibu406
    Malibu406
    The option always exists to cut the housing and shaft, install a bearing then use whatever more common steering box or rack I want with a connecting shaft. Thats safer in a wreck too. Easy enough to do just not sure I want too for some reason.
