Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. john mullen
    john mullen
    Got valve Guida yesterday
    Now I can get the valves in and start the flow bench work on the bowls and match up the ports
  2. john mullen
    john mullen
    Asking for prayers for Jimmy and his wife today as Bernice has some health issues and Jimmy has been gone all week and not able to finish the cylinder head hopefully next week will be better for them.
    We had a good work day at my shop with Dave, Dan, Sam and myself. We worked on the rear suspension to raise the rear of the truck another inch to get more rear end travel. And did some wiring mods to relocate the control panel box for better driver access. 20210320_150307.jpg 20210320_150342.jpg
    Stogy, tdog, saltflats and 8 others like this.
  3. john mullen
    john mullen
    Setting up the crank trigger for precise timing
    This is critical to get it just right 20210322_143732.jpg 20210322_143726.jpg 20210322_143711.jpg
  4. saltflats
    saltflats
    from Missouri
    Curious what you are using the dial indicator for?
  5. john mullen
    john mullen
    Checking top dead center to verify the timing marks
  6. saltflats
    saltflats
    from Missouri
    Interesting, :confused:
    The only way to be 100% is with a degree wheel and a piston stop.
    JC Sparks and loudbang like this.
  7. Essex_29
    Essex_29
    from Finland
    When I built racing engines I used a dial indicator to measure 0,2 mm (8 thou) off top dead center on both sides, TDC is in the middle of these two readings and I'd say this is pretty much exact.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    X2 ^^^, as long as the indicator is centered over the pin bore, to negate the effects of piston rocking.
  9. saltflats
    saltflats
    from Missouri
    Piston stop takes that out of equation.
  10. john mullen
    john mullen
    I used a degree wheel and piston stop to find TDC and marked the harmonic ballancer.. when I first built the engine. I just needed to verify they were still accurate for timing plus I like to know how far down the piston is when it fires. I have found that long rod engines like a little more timing than a short rod engine. This engine has 0.300 longer rods than stock. I look at piston position for the initial setting of timing then let the dyno tell me where to go from there.
    Just need to know the base line as a constant to come back to if needed.
    Everyone has there own way of doing this and this is how I have done it for many years and it works well for me.
    bowlingball, Just Gary, Stogy and 8 others like this.
  11. john mullen
    john mullen
    Stogy, loudbang, Dino 64 and 4 others like this.
  12. john mullen
    john mullen
    Dis***embled the dry sump, cleaned inspected,and installed back on the engine w/new drive belt 20210323_165649.jpg 20210323_165626.jpg
    milwscruffy, D-Russ, Stogy and 5 others like this.
  13. RichFox
    RichFox
    Dial indicator works fine. As long as you know what your doing.
    H380, Stogy, gas pumper and 4 others like this.
  14. john mullen
    john mullen
    Stogy, loudbang, sidevalve8ba and 3 others like this.
  15. john mullen
    john mullen
    Stogy, Dino 64, loudbang and 3 others like this.
  16. john mullen
    john mullen
  17. So you’re saying you’re having your umm, head examined? [emoji6]
  18. john mullen
    john mullen
  19. john mullen
    john mullen
    Got all the intake guides in today, sorry no photos but I'll shoot some once we get all the guides in and Jimmy cuts the valve seats on monday.
  20. john mullen
    john mullen
    Got the ARP HEAD STUDS TODAY, ALL THE GUIDS ARE IN AND ARE BEING FIT TO THE VALVE STEMS 20210330_152221.jpg 20210330_152142.jpg 20210330_152123.jpg
  21. jimmy six
    jimmy six
    Great. I’ve found it pretty easy to get what you want by size once you figure it out. I would have thought the catalog would have them near the back but none I have do. Looking good..
  22. john mullen
    john mullen
    Sorry everyone no photo's today , Jimmy has not been in to work today to work on the head. His wife has been under the weather with health issues
    Maybe later on in the week
  23. john mullen
    john mullen
    Just want to say Thank you to David Voth from Coyote Valley Services LLC Engineering and Design work in Derby Kansas.
    DAVID your generosity in supporting the XO/PP640 is most appreciated.
    Thank You from all of us at team 640
  24. john mullen
    john mullen
    I might add that David is not a first time supporter of the XO/PP 640 Project and has supported us in the past
    Can't thank him enough.
    fegsta, loudbang and chryslerfan55 like this.
  25. john mullen
    john mullen
    Happy Easter everyone,
    Remember why we celebrate ..
  26. pprather
    pprather
    John, thanks for your Easter message.
    Dvoth and loudbang like this.
  27. john mullen
    john mullen
    Jimmy has not been in to work except to keep Patrica and myself lined up with what needs to be done. I am coming in every day to help out not just 2 days a week as before. Jimmy's wife is having health issues and needs constant attention.
    He did come In yesterday afternoon and fit all the valve stems to the guides on the 640 head. It's been really hard for Jimmy and his family so please keep them in your prayers
  28. john mullen
    john mullen
    Dave Russell and I decided to go ahead and install the engine so we could work on some of the other things that need to be done. We will install the top end once the head is finished. Doing what needs to be done as time is running away from us. 20210410_153801.jpg 20210410_153610.jpg 20210410_153741.jpg
  29. john mullen
    john mullen
    Jimmy came in over the weekend and cut the new oversize seats in the head.
    I'll blend in this work this week and then we can finish grinding the valve seats and then it's on to the flow work and runner to runner ballance. Getting closer, I also ordered the new driveshaft to fit the new ******.
    Sorry no photos of the work this weekend as I was not there. But I will photo the results tomorrow and post them
  30. john mullen
    john mullen
