Projects The Gin Runner 1926 T Gow
Discussion in 'Traditional Hot Rods' started by Blackbob, Jan 8, 2020.
  1. Blackbob
    Blackbob
    I had it running quite well using this carb and a 90º bend onto the updraft manifold, that wouldn't fit under the bonnet so this is variation 2 :)
    282doorUK likes this.
  2. Blackbob
    Blackbob
    I had considered that, and it may happen yet ;)
  3. 282doorUK
    282doorUK
    My attempt at an SU on my '28 Chevy, the manifold got ice cold, covered in condensation, but that velocity stack looked cool. It may have been due to the lack of an exhaust hot spot to warm it up, so I rigged up a warm air feed to it and it ran worse, gave up then.
    Blackbob likes this.
  4. rwrj
    rwrj
    from SW Ga
    I've tried a single 1 3/4 SU, and now duals of the same size on a slightly modified Model A with what I feel like is a little success. No icing, but I had to play around with the needle size a bit.
    guitarguy and Blackbob like this.
  5. guitarguy
    guitarguy
    I was thinking coiling copper tubing around the intake if there is a icing of the intake issue and running coolant through the tubing. Hook one side to the water inlet and the other to the water outlet.
    I'm hoping to not need a water pump, but if I do, the inlet of the copper tube can come off of that.
  6. guitarguy
    guitarguy
    That's good to here (although my setup is 1 SU 1-3/4). But what you and @Blackbob have that @282doorUK and I don't have, is the exhaust manifold right next to the intake.
  7. Blackbob
    Blackbob
    Ive got a '28 Chevy four to fit onto a T oil pan and trans in the pipeline, hoping to get it going with a pair of 1.25" SU's
  8. guitarguy
    guitarguy
    Sorry, I missed that. Well, maybe my idea on heating the intake will work if they ice up.
    Sent from my thinks it's smarter than me smart phone using The H.A.M.B. mobile app
  9. carbking
    carbking
    I know SU carbs have been used on British vehicles since just slightly after Noah landed the Ark, but (opinion) you are losing quite a bit of power compared to using an updraft Stromberg or Zenith.
    Jon
  10. Blackbob
    Blackbob
    You are probably right Jon, but I have a big box full of SU spares and no Strombergs or Zenith carbs or bits. Its a low budget farm yard/barn build :)
    Stogy and chryslerfan55 like this.
  11. guitarguy
    guitarguy
    Interesting. Not that either of those carbs are withing my budget currently, but would you be able to elaborate on this? You can PM me if you wish to instead.
  12. 282doorUK
    282doorUK
    I almost agree Jon, I've had this adjustable main jet Zenith 267 on my stock '28 Chevy for a few yrs now and I really can't fault it.
    Had to make adaptors but apart from that very easy to set up, and works very well with the stock vac tank and warm air tube from the exhaust.
    But shipping, customs and other leeches mean they're very spendy by the time they land over here.
    Worse still they just don't have the look I'm after on my pre war racer, everyone knows old racers have to have at least two carbs sticking out to **** in all the rocks, splinters and track debris, right? :D
    Outback, Stogy and chryslerfan55 like this.
  13. carbking
    carbking
    I completely understand (and don't really care for) budgets. Dad always told me I had champagne taste and beer income! ;)
    Introducting the extra bend from carb to intake costs some power. By fabricating a completely new SIDEDRAFT intake manifold, you could recover some of the lost power. The updraft comment in my previous post is because the original intake was updraft, but the S.U. is sidedraft; gasoline molecules like straight lines, not corners.
    Past that, if one looks at the design of the Stromberg and Zenith carbs (round venturi areas, with boosters) versus the variable area, more or less constant air velocity but no boosters of the S.U., the Stromberg and Zenith carbs just do a better job of mixing and atomizing fuel at all engine speeds.
    Quote: "Worse still they just don't have the look I'm after on my pre war racer, everyone knows old racers have to have at least two carbs sticking out to **** in all the rocks, splinters and track debris, right?"
    As to the multiples, agree completely! Just make sure the number of intake plenums (plenum style intake) are an even divisor of the number of cylinders. There are some good looking (opinion) br*** sidedraft Stromberg and Zenith carburetors kicking around, but then we get back to that budget thingy.
    Jon.
    Tow Truck Tom, Outback, Stogy and 2 others like this.
  14. 64 DODGE 440
    64 DODGE 440
    from so cal
    SU carbs can work very well once you learn how to tune them. Old6Rodder has two slant6 engines running three 1 3/4 inch SUs on each and they run great
    ottoman likes this.
  15. Blackbob
    Blackbob
    I had the motor running significantly better than the stock T manifold and carb by using the same SU carb on a 90º adapter to the unmodified A manifold. This modification cuts the amount of bends the fuel has to go around drastically , will smooth the path and adds a bit of gravity so I'm hopeful it will be more efficient than what I have tried so far. :)
  16. rwrj
    rwrj
    from SW Ga
    My single ran well on a modified stock manifold much like blackbob's in post 57. My duals are running on a homemade deal that shoots just about straight into the ports in the block. Just enough bend to get the float bowls perpendicular.
    I'm still fiddling with the needles, trying to get it a little richer, but it runs well. Got that Jackleg dual header deal, old police head and a mild cam.
    Outback, Stogy, Dannerr and 6 others like this.
  17. sloppy jalopies
    sloppy jalopies
    you gonna call it "GIN LIZZIE" ?
  18. hotrodA
    hotrodA
    Do you know anything about these pistons? I have the same type raised crown piston in my B Sprint engine that once had a OHV Cragar head on it. They seem to be an effective way to fill the combustion chamber.
    FWIW, years ago there was a guy that machined the bevel on 4" 366 Chev truck pistons to achieve the same pop-up.
    Really like the gow build!
  19. rusty valley
    rusty valley
    mr hotrod a, you should not use those old 2 piece valves ^^^, they are known to break the heads off. causes lots of problems then
    Stogy likes this.
  20. Blackbob
    Blackbob
    They came already fitted to the motor, same as the set in my spare motor and i believe they are aftermarket alloy pistons available from Langs
  21. Blackbob
    Blackbob
    Its a pic of the valves I pulled out and replaced with one piece new ones [emoji41][emoji106]
    Stogy, chryslerfan55 and rusty valley like this.
  22. hotrodA
    hotrodA
    Thanks, Blackbob.
    Stogy likes this.
  23. I bought a 21TT ch***is and some 27 panels from Neil Tuckett a long time ago. Nearly there now IMG_20210322_175304168_HDR.jpeg IMG-20210322-WA0012.jpeg IMG-20210322-WA0004.jpeg IMG-20210322-WA0002.jpeg IMG_20210314_144508029.jpeg IMG_20210228_170129416_HDR.jpeg
    Sent from my moto g(8) using The H.A.M.B. mobile app
    jet996, Outback, Stogy and 3 others like this.
  24. Blackbob
    Blackbob
    Looks great Blackjack, whats the motor?
    Stogy likes this.
  25. Blackbob
    Blackbob
    I got a bit more done on the model A manifold on friday. I used a 30mm starret hole cutter and roughed out the inlet stub through into the manifold, did a bit more grinding where the stub used to be and then used a 34mm cutter without the pilot drill to cut out a patch for the hole left in the underside of the manifold.. tbc
    Outback and Stogy like this.
  26. Blackbob
    Blackbob
    Outback, Stogy, Dannerr and 1 other person like this.
  27. 347 Pontiac
    Stogy likes this.
  28. Blackbob
    Blackbob
    Another lunchtime T break.. i decided the cut tube “patch” wasnt going to be thick enough to fill the hole left by the old inlet stub position, so a rummage in the s**** found an old arbor press tool for cutting discs that was the right diameter.. a bit of grinding got the profile right for the inside of the manifold. I cut it slightly oversize and welded it in. Ive a bit of grinding to do on monday and maybe will finish it with some silver solder on the inside but it looks like i have a good seal :) 168479280_4240029476041651_4519565644556362057_n.jpg 168456941_4240029459374986_11726314099971020_n.jpg 168366112_4240029579374974_5348316131131178108_n.jpg
    Kume, 282doorUK, Stogy and 3 others like this.
  29. 282doorUK
    282doorUK
    I reckon that's what John Gerber called a 'swirl dappled' finish, and it's looking period perfect..
    Outback, Kume and Stogy like this.
  30. Duke of Haphazard
    Duke of Haphazard
    from PNW
    Well now, I wonder what happened to this project. Some pretty cool ideas and interesting execution.
