Projects HotRod Rebuild
Discussion in 'Traditional Hot Rods' started by ModelARon, Mar 18, 2021.
  1. AHotRod
    AHotRod
    I glad to see that your not changing a ton of the car (so far) so as to not loose the home made character that is was born with, otherwise it becomes just another updated-pretty-car.
    Our Hot Rod history is extremely important.
  2. oldiron 440
    oldiron 440
    I think I could make a concession to disk brakes on the front and get rid of the wheel adapters.
    impala4speed and loudbang like this.
  3. ModelARon
    ModelARon
    My goal is to keep as much as i can that Frank built, but make it safer. I love the character this car has.
  4. ModelARon
    ModelARon
    I replaced part of the rain gutter under the back window and the curved trunk panel. IMG_3080.jpeg Also the two running boards are shot . IMG_1878.jpg IMG_1877.jpg IMG_0697.jpg
  5. ModelARon
    ModelARon
    Here is a pic of me and Frank when i drove up to his place. I hope to finish the car and trailer it up to his place so we car take it for a ride. IMG_0628.jpeg
  6. ModelARon
    ModelARon
    I was thinking about installing disk brakes but i plan on keeping the drums. I just love the look.
  7. 32 hudson
    32 hudson
    Following and subscribed.
  8. AHotRod
    AHotRod
    So glad to see that you have a picture with Frank, that is awesome.
  9. ModelARon
    ModelARon
    Yes i wanted a pic with Frank . I am keeping the lower bracket he cut with a torch and welded to the axel. I could have just cut that off and install the typical shock mount . This just adds interest to the car. I installed new shocks the same style he had on the car. IMG_3093.jpeg IMG_3095.jpeg to the car.
  10. alanp561
    alanp561
    Dammit, life just isn't fair. I've moved 22 times in 53 year of marriage and NEVER found anything like this left behind by the previous owner. This really ****s, man!;)
  11. Budget36
    Budget36
    Oh my, if it was me I’d quit unpacking after about the 5th move;)
  12. ModelARon
    ModelARon
    Just to be clear i did not buy the house. I just bought the car. My friend the realtor would call me to look at fixer uppers that i might want to fix and sell. Also i told her if she sees any old cars let me know about them.
  13. DrJekyllMrHyde
    DrJekyllMrHyde
    This is a fantastic story!
    You preserve and refine some HotRod history, and the vealth of informations from Frank`s life with the car is invaluable!
    Perfect, it came to the right person . :)
    Stogy and loudbang like this.
  14. ModelARon
    ModelARon
    Frank had a new headliner and side panels installed in 1958. Here is the bill. He paid $85 labor and materials. IMG_3106.jpeg
  15. ModelARon
    ModelARon
    The master cylinder was missing from the car. I had a hard time finding the correct one.
    Frank could not remember what car it came from. After 60 years i don't think I would remember. IMG_3111.jpeg
    After looking at lots of pictures of old cars and trucks I found a match. An old international truck.
    It bolted right up to the holes he drilled.
    Half of the fluid reservoir is for the brakes and the other is for the clutch slave cylinder.
    I don't have the luxury of telling the guy at the parts counter that i need a part for a 1930 Model A. It's part of the fun to chase down the mystery parts.
  16. ModelARon
    ModelARon
    The clutch slave cylinder came form a 1959 Ford F100. I picked up a new one. He made the bracket with his torch and bolted to the inside of the frame. IMG_3109.jpeg IMG_3108.jpeg IMG_3107.jpeg
  17. ModelARon
    ModelARon
    With out the old pictures frank gave me the master cylinder would have been much harder to find.
    Denns1989, Okie Pete, Stogy and 2 others like this.
  18. Onemansjunk
    Onemansjunk
    from Modesto,CA
    chryslerfan55, Jrs50, Stogy and 2 others like this.
  19. ModelARon
    ModelARon
    The old Sun Tach transmitter box was mounted under the dash. I found two corroded batteries inside the box. Not sure why they could not use the 12Volt power from the car to work the Tachometer. IMG_1657.jpg IMG_1661.jpg
    I found a place to install modern electronics in side the box and calibrate the tachometer.
    The Tach is mounted under the dash. I am not sure if i will leave it mounted there or find a better place up closer to the steering column. I need to figure out where i have room as i put this car back together. I think i might be nice to have it more visible in side the cab.
  20. ModelARon
    ModelARon
    The steering wheel is a Superior 500. The chrome is in poor shape and i would like to clean it up.
    I am thinking i could give it a light sanding and some " chrome paint" . Any one have ideas on how to make the wheel look better? DSC02465.jpg IMG_0011.jpg
  21. ModelARon
    ModelARon
    The old wiring will need to go. This is all inside the old gas tank. IMG_0546.jpeg IMG_0545.jpeg IMG_0548.jpeg
  22. Stogy
    Stogy
    A Hamber just polished up some grungy center caps and they look fantastic...don't use sandpaper yet... @RiffRaffRoadster had pitted chrome and he used Coke or something seriously...his steel slots were real ****ty looking and they came up very credible...
    Heres his slots and air cleaner at the links below...Man that fella brought back so many things back that looked nasty...
    https://www.jalopyjournal.com/forum/threads/model-a-body-on-‘32-ch***is-with-fenders-help.1133905/page-43#post-13233353
    https://www.jalopyjournal.com/forum/threads/model-a-body-on-‘32-ch***is-with-fenders-help.1133905/page-41#post-13065390
    Grungy Caps 2 posts on this page at this link below...
    https://www.jalopyjournal.com/forum/threads/37-38-chevy-g***er-and-i’ve-got-the-pink-slip.1220246/page-5
    Now it's up to you Coke or #7...:D
  23. alchemy
    alchemy
    If it's was my car I'd cut out a lot of that inner gas tank baffle and underside to give me more room for the wiring. None of it shows, so you won't be hurting the looks.
    loudbang and Stogy like this.
  24. Stogy
    Stogy
    :rolleyes:...love that torchwork on the inner tank...even some Smoke effects...mine was cut entirely out underneath including baffles with the gas axe and maybe a hatchet here and there...period correct indeed...:D
  25. ModelARon
    ModelARon
    Thanks. I will cut some of the bottom tank to make more room to install the wiring.
    chryslerfan55, loudbang and Stogy like this.
  26. ModelARon
    ModelARon
    Thanks i will read this info
  27. Stogy
    Stogy
  28. wheeldog57
    wheeldog57
    Man-O-Man that car is so cool!! Great job bringing it back to it's original shape. You have made some smart decisions on safety upgrades as well. Keep on keeping on bro
    chryslerfan55, loudbang and winduptoy like this.
  29. 1971BB427
    1971BB427
    from Oregon
    I'd not use the chrome paint on the wheel. Just never looks that good. Instead I'd carefully sand and polish just the rusty areas and then buff all the metal to a high finish, and then spray it with clear. That will save the patina, and improve the looks of the rusty areas, without making it look bad. I've polished out steel before and cleared it, and it looks a lot better than paint.
  30. ModelARon
    ModelARon
    Thanks. I will practice that on some other old chrome part i don't need first.
