THE oldsmobile rocket 303 324 371 394 post to end all other posts, (lasalle related )
Discussion in 'The Hokey Ass Message Board' started by RocketDaemon, Dec 19, 2006.
  1. Thanks for bringing back those memories. I've done that twice. Not fun.
  2. gonzo
    gonzo
    Yep, bore to 4" and then use 371 pistons. That's the set up in my 32. C8EB42F1-B54A-4735-85D7-E40BCE036ACD.jpeg
  3. jakespeed63
    jakespeed63
  4. jebbesen
    jebbesen
    from Winona, MN
    These are probably a little rich for most guys but I just thought I'd post a link here in case anyone really wants some. Not mine, just an auction I thought someone might be interested. Pretty rare and not repopped to my knowledge. From what I understand this is how Olds upped the compression in the legit J2 engines. @Paul is this true? They sent me an offer of $140 for the 3 gaskets so if you're interested send them a message and they might make you a deal.
    https://www.ebay.com/itm/144203231455?&_trksid=p2060353.m570.l47448&_trkparms=gh1g=I144203231455.N59.S2.typeSellerInitiatedOffer.R2.TR16&ul_noapp=true&autorefresh=true&fbclid=IwAR2_qXhC_1N_2rQ1mKb5PqpKvSbRXFSg8xdTQplUXT3egplCXs7SOmJk4IY
  5. Paul
    Paul
    Editor
    Yes, this is what I have heard from several sources.
    I'll have to watch that sale, I may consider selling some of mine ;)
    jebbesen likes this.
  6. jebbesen
    jebbesen
    from Winona, MN
    In my mind it would probably make more sense to just mill the heads during a rebuild but I guess given machine shop rates it might be the cheaper option for some.
  7. Paul
    Paul
    Editor
    And a lot easier for do it yourself hot rodders
    saltracer219 likes this.
  8. LS1
    LS1
    from us
    Is there any difference between 1954-1956 324's besides the #10 heads. I was looking for a full gasket set for a 1955 324 and the felpro FS 7725 S-2 application lists only 54 and 56 NOT 55.
  9. Paul
    Paul
    Editor
    Gasket sets are the same for all 324s
    curbspeed likes this.
  10. vtwhead
    vtwhead
    I thought you could get a gasket set thru a Best Gasket dealer as well, fwiw.
    Paul likes this.
  11. Dago 88
    Dago 88
    Longshot, but would any one out there have pic's of a distributor drive fuel injection pump for early Olds ? thanks in advance.
  12. vtwhead
    vtwhead
  13. nochop
    nochop
    from norcal
    My 2 cents 3C33EBBC-AD27-4A63-A523-C893CCD7B065.jpeg D0957E4A-1C55-426B-9482-5FCC7D259998.jpeg
    rod1, 36 ROKIT and saltracer219 like this.
  14. Dago 88
    Dago 88
    Cheers @vtwhead , exactly what i was looking for. ;)
  15. saltracer219
    saltracer219
    Dago 88 likes this.
  16. oldfordtin
    oldfordtin
    Thats not a good thing is it?
  17. 57JoeFoMoPar
    57JoeFoMoPar
    There is probably no better feeling in the world than getting your Olds unstuck so you can take the hydro off without having to saw every rod off.
    #7 Rod left the chat many years ago
    bchctybob, jebbesen, rod1 and 6 others like this.
  18. I know what you mean. Had to flip one, pull all the caps and separate the hydro with the crankshaft still attached once.
    If you're s****ping the Hydro, I could use the yoke!
  19. gonzo
    gonzo
    Just picked up this 56 324. Check out the cast double water pump pully.
    I heard it was out of a fire engine.
  20. cabong
    cabong
    I've been partial to the "Rockets" since rebuilding Ak Miller's El Caballo. It had a 303 originally that was out to 370 ci, so when looking for a mill I bought a complete '58 Olds with the 371 ci, sincee it was close. Larry Spengler in San Pablo, CA put the engine together, and it wasn't that radical. Al Blazic did the balance, and I believe it was one of the last he did. Ak Miller and Ed Iskenderian reground the original camshaft, and he they never would tell me what the spec's were. Carburetion was similar to original, a Weiand Wo4D, with adaptors for the 4 97's. I used 48's i.l.o. 97's, just for size.... Needless to say, the engine ran great, and I tortured it for 10 years of vintage racing before giving the car to the NHRA Museum.... 371olds (2).jpg
    warbird1, don colaps, BigRRR and 5 others like this.
  21. Paul
    Paul
    Editor
    interesting, that lower pulley is different too with additional smaller groove at front.
    bchctybob, saltracer219 and gonzo like this.
  22. Paul
    Paul
    Editor
    love it
    my current hot rod is also running a '58 but with two 4 barrels (probably very similar to the 4 2's) and slightly warmed up stock cam.
    just right for a light weight hot rod ;)
  23. jebbesen
    jebbesen
    from Winona, MN
    @cabong I remember you saying that about the cam before. Last fall I had Isky on the phone so I asked him about it but it must have been too long ago. I hoped I could jog his memory about it but he wasn't sure. Crazy the details he could still tell me about stuff on the engine in his roadster. That guy is amazing. If we all could be around that long and still be that sharp just think what we could get done!
    Paul likes this.
  24. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I was rooting throught a junkyard years ago, and found a Chevy medium duty truck with an Olds in it with pulleys like that.
    gonzo likes this.
  25. bchctybob
    bchctybob
    When you punch a 324 to use the 371 pistons which head gasket do you use? They both seem like they would work, looking at Best composite gaskets.
    Gasket sealer? No sealer? What works best with the Best composite head gaskets?
  26. gonzo
    gonzo
    Cool. That backs up what I heard about it being in a fire truck.
    I used 371 head gaskets to match the bore.
    bchctybob likes this.
  27. curbspeed
    curbspeed
    Paul, What brand are the valve covers in this top pic? I just scored a pair. I think they are the same. Have NN 65 I think cast on the underside.
  28. Paul
    Paul
    Editor
    cast by Holmes for Moon.
  29. bchctybob
    bchctybob
    Holy smoke Paul, I just re-examined the pictures via Curbspeeds quote, I think you win. What an amazing collection of Olds stuff.
    I’m too short sighted, the few times I’ve run across stashes, instead of grabbing some cash and making a bee-line for it, I just think, where the hell would I put all that stuff? There’s always room for Olds stuff!
  30. Paul
    Paul
    Editor
    most of that stuff is gone now
    used in a few projects and
    sold off to fund other others.
    fun to see it all in one pile.
