Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. Just Gary
    Just Gary
    I wanted the alternator as low as practical.
    This simple mount combines ideas from @D-Russ , @scotty t , & @alfin32 . Thanks, guys.:cool:
    A double sheer "pivot piece" is made of 1.5" x 1.5" angle. It attaches to the motor mount/frame bolt.
    1/4" thick pivots added. One tapped with a 5/16"-18 threaded hole
    A slotted "belt tensioning piece" is 3/16" plate.
    The alternator is from a Suzuki Samurai; ACDelco #335-1271, generating 55 internally-regulated amps.
    Belt is a Dayco #15460.
    Lightening holes make everything look faster & cost just a little time.
    They also improve quarter mile ETs, gas mileage & reduce carbon emissions. ;):rolleyes:
  2. Tim
    Tim
    from KCMO
    Something satisfying about hand filing a slot like that in metal.
    looks great!
  3. Magfiend
    Magfiend
    LOVE the headlights Gary - something about fluted Model A lenses that just do it for me. I also have to say, the orange turn signal bulbs flat out WORK behind those lenses! I have always liked that look!
  4. AHotRod
    AHotRod
    Great job Gary, YOU are the man .... but you already know I love your Hot Rod brother.
  5. Just Gary
    Just Gary
    "IT'S ALIVE (again)!" :D
    I was shocked when the Hemi instantly fired up. The Edelbrock 650 was spot-on, right out of the box. No leaks in the headers or exhaust. We did find a minor coolant leak where one header bolt threads into the water jacket.
    @Dino 64 provided the sanity check.
    Background: The engine was rebuilt and started up ten years ago. Afterwards, I poured several tables****s of oil into each cylinder & manually turned it over every month with a ratchet on the crank hub. Specs are in an old engine-specific thread:
    https://www.jalopyjournal.com/forum/threads/’28-tudor-update-5-“yeah-it’s-got-a-hemi”.575141/
    This restart got delayed; first by two leaking freeze plugs, then an annoying flexplate/starter misalignment: :confused::rolleyes:
    https://www.jalopyjournal.com/forum...rference-problem.1228726/page-2#post-14058993
  6. gnichols
    gnichols
    from Tampa, FL
    Well, that will blow some dirt around the fairgrounds.
    Stogy, Dino 64, mad mikey and 4 others like this.
  7. Tim
    Tim
    from KCMO
    Heck yeah man! That’ll bring the neighbors around the corner lol
  8. Deadbird
    Deadbird
  9. AHotRod
    AHotRod
    WAY TO GO GARY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WAHOOOOOOOOO !!!!!!!!!!!!!!!!!!!!!!!!
    Man I'm so excited for you brother, it's been a long haul.
    Stogy, Dino 64, Just Gary and 3 others like this.
  10. mad mikey
    mad mikey
    Congrats Gary. Sounds great, a job well done. You are getting close now brother.:):):)
    Stogy, Dino 64, Just Gary and 2 others like this.
  11. Dino 64
    Dino 64
    from Virginia
    Congratulations ! You did a great job of prepping that beast. It sounds wonderful :):)
  12. catdad49
    catdad49
    Wow, that’s a Burble!
    Stogy, 26hotrod, loudbang and 3 others like this.
  13. Just Gary
    Just Gary
    2000 rpm B&M "Holeshot" :rolleyes: torque converter.
    Joe Blow, -Brent-, D-Russ and 9 others like this.
  14. Dino 64
    Dino 64
    from Virginia
    Looking good Gary :)
    loudbang, mad mikey and Stogy like this.
  15. Just Gary
    Just Gary
    Thanks! :)
    The "Otie's Automotive" Fiat Fuel Altered inspired my shifter... with help from some '60's G***ers' B&M "Series 60" shifters & @toxictom 's console.
    otie 05.JPG otie int2.jpg 013 studebaker lark gasser shifter.jpg b&m series 60 04.jpg pedal moon 99.JPG diamond hrxp-1205-1941-willys-coupe-restored-gasser-003.jpg vanderhook 02.jpg toxic 02.jpg
    But I'm limited to ~2.5" max width due to the close-together, tip-forward seats & huge trans tunnel.
    Also, comfortable ergonomics & a gear position indicator are must-haves so Wifey can drive it.
  16. Just Gary
    Just Gary
    The results:
    A homegrown 1/8" steel bracket attaches to the trans tunnel.
    The bracket is slightly offset toward the driver, raising & rotating a new B&M shifter so it's within easy reach.
    A traditional-ish housing encloses it.
    The guarded toggle switch enables 4th gear lockup.
    Paint & powercoating will follow later.
    :cool:
  17. Dino 64
    Dino 64
    from Virginia
    ….so wifey can drive it !!!:eek::rolleyes:;)
  18. brianf31
    brianf31
    Looks and sounds great! Are those Porter or Smithy mufflers?
    loudbang, mad mikey, Dino 64 and 2 others like this.
  19. Tim
    Tim
    from KCMO
    I could see the sides with a pinstriped panel with engine turning in the panel itself. Looks good man
  20. mad mikey
    mad mikey
    Love the shifter Gary.:) Very nice.;)
  21. loudbang
    Looks good :)
  22. chevy57dude
    chevy57dude
    Nice work as always!
    M/T knob is cool.
  23. mad mikey
    mad mikey
    Yea! The M/T knob is killer!;) Are you almost ready for a test drive? :)
  24. Just Gary
    Just Gary
    2.5" exhaust with 24" Thrush gl***-packs.
    They're quieter than I remember :confused:
    But give 'em time...:cool:
  25. Dino 64
    Dino 64
    from Virginia
    You were focusing on the engine sounds, it was loud, believe :rolleyes::rolleyes::)…. It was a wonderful sound too;);)
    Stogy, loudbang, mad mikey and 2 others like this.
  26. Just Gary
    Just Gary
    There was no room for my stock pistol-grip E-brake. :(
    But this Lokar unit fits under the driver's knees.
    Will connect the cables when the tires are down off the cribbing.
    I also whipped up a license plate bracket that hangs from the spare tire mount holes.
    A racing buddy's expired license served as a template. :cool: 20210225_162013_2.jpg
    Joe Blow, shortypu, TFoch and 15 others like this.
  27. Tim
    Tim
    from KCMO
    Looks heavy lmao
    Stogy and Just Gary like this.
  28. brianf31
    brianf31
    Nice license plate. Nitro!
  29. rbrewer
    rbrewer
    Incredbile build, thanks for posting!!
  30. mad mikey
    mad mikey
    Hey Gary! I have the same e- brake in the coupe, works great. :)Excellent choice my friend .;)
    Stogy, loudbang and Just Gary like this.
