Projects My 1935 Ford Five Window build.
Discussion in 'Traditional Customs' started by emil, Jan 11, 2021.
  1. emil
    emil
    from sweden
    Thank you! Yes, I really do!
    Luckily I have the state of mind to use the cars to do fun stuff with the family once they are done.
    I drive my cars pretty much daily so we see a lot of quality time when I’m not building.
    Skickat från min iPhone med H.A.M.B.
  2. emil
    emil
    from sweden
    So today I got some pieces in place.
    So first I made the top of the door, after fitting the wood template properly.
    Then I cut out the entire top part of the door jamb, and made a new piece that got ****welded in place before I started fitting the roof piece and screwed it down in place.
    Then the magic cookie cutter came out and I cut along the edge of the roof piece and welded as I went along, lifting up the edge with a flat screwdriver to align the metal.
    Still have some fitting along the drop rail and some more work along the roof insert before I can finish weld and hammer it all.
  3. Awesome build. Keep the updates coming.
    emil likes this.
  4. reverend-heat
    reverend-heat
    from Germany
    Emil,
    this is high speed. Almost as fast as on the ***embly line. By the amount of body work it´s almost as you used the car as a mold and built it again (if you know what i mean).:)
    BTW: I´m still searching but prices are insane.
    Good luck
  5. emil
    emil
    from sweden
    Thank you! I try to be effective, but sometime life comes in between.
    Yeah there was a lot of work to be done, which is usually the case when you buy cheap [emoji16]
    Yeah, I found this through @thunderbirdesq here on hamb.
    I got lucky, and found it at a price I just couldn’t say no to.
    Good luck! Your dream is out there man [emoji16]
  6. reverend-heat
    reverend-heat
    from Germany
    chryslerfan55 and emil like this.
  7. emil
    emil
    from sweden
    I saw the ad, but don’t know the guy or car from before.
    I know who built the engine for it tho.
    The ch***is for that car seem really nice.
    He lives on the other side of the country from me [emoji16]
  8. Rockson
    Rockson
  9. emil
    emil
    from sweden
  10. Gahrajmahal
    Gahrajmahal
    You do great work and do it fast! I can’t wait to see you roll it outside to see the new profile. Do you have any finished cars you are using for inspiration?
  11. emil
    emil
    from sweden
    Thank you! I try to be efficient and still do the car justice.
    Not really, I had a sketch that mr eBlack made of a 36 and the 36 Cole foster made for kirk of Metallica.
    The latter is a 5 window rebuilt into a 3 window.
    I just tried to study the curves of the roof and wanted to make it feel more slick and make it flow like jazz down the back of the car.
    So I cut and pasted on my drawing board a bunch so I knew where to cut it before I even had the car at home.
    The chop changed a bit when I finally cut it apart tho, took an extra inch off the rear.
    brEad and chryslerfan55 like this.
  12. emil
    emil
    from sweden
    Got both sides of the roof welded in, started making some fill pieces for the surround of the roof insert and the inside of the door jamb.
    Here you can see I still have some m***aging to do on the drip rail before it’s done.
    My phone gave out the other day so the camera doesn’t focus anymore, so my photos are more **** than usual.
    I Will order a new phone tomorrow but til I get it this is all I can offer up.
    Sorry.
  13. emil
    emil
    from sweden
    At this point progress is slow, a lot of welding, cooling, grinding, cooling, hammer and dolly, and then rinse and repeat.
    Everything needs to be worked over properly so I don’t have to dip the car in bondo when I’m done.
    Photos are still ****.. but the work looks better.
  14. emil
    emil
    from sweden
    Today I got the top of the roof finish welded, nothing too exciting to look at but this **** tests my patience which I don’t have a great deal of.
    I’m dragging a welding rod along the contour of t he roof to detect any low spots, before hammer and dollying.
    Turned out pretty good!
    Won’t need a lot of bondo to make this paint ready.
    I don’t know if I’m going to do any more updates until I have finished off the welding on the roof.
    Doesn’t seem too exciting to look at photos of that small a change.
  15. McTavish77
    McTavish77
    Awesome work man!! Love those old 5 windows! Keep it up brother!
  16. nor6304
    nor6304
    from Indiana
    Really nice work Thank you for the thread
    emil likes this.
  17. emil
    emil
    from sweden
    Today I got to roll it outside and look at it from a distance.
  18. Greg Hammond
    Greg Hammond
    You have some skills. Those 35's coupes are a**** some of the best looking fords produced.
    BTW. Did the holes in your wallet match the holes in your coupe? Har, har... Nice job.
  19. emil
    emil
    from sweden
    Thank you!
    Haha sadly I think the holes in my wallet are bigger [emoji38] it’s harder to fix a car and tool addiction than it is to repair rust, that’s for sure.
  20. sodas38
    sodas38
    If you're born in Sweden do they just hand you a hammer and dolly as you leave the hospital, it seems like every one from Sweden can master metal work.. Your work is excellent!
  21. emil
    emil
    from sweden
    Thank you!
    I dont know, cars are rare and its expensive to get work done over here I think.
    So everyone just have to learn.
    We also have had a great American car culture here, so most everyone is interested or know someone who are into old cars.
    I have been to America quite a bit and I see more old cars here in the summertime than anywhere I have ever been.
  22. buckwild27
    buckwild27
    Looking good really like the look of that body style
    emil likes this.
  23. gsnort
    gsnort
    One heck of a lot of work, and it appears to be first cl*** work, at that. Congratulations, and continue to keep us posted.
    emil and chryslerfan55 like this.
  24. emil
    emil
    from sweden
  25. emil
    emil
    from sweden
    Here’s some photos, it’s slow and tedious to finish weld all this but today I made some good progress.
    I also had to make a tool today to be able to hammer in some hard to reach spots, so put a piece of round stock up in my lathe and turned this lil baby.
    Chisel for comparison.
    Worked pretty good.
  26. emil
    emil
    from sweden
    Here’s another photo from when I had it outside.
    Will try and post a few more angles later.
    I think I will be able to finish up most of the welding on the roof today.
  27. Chief 64
    Chief 64
    Nice looking chop Emil!!! The lines flow nicely!
    emil and greaser like this.
  28. emil
    emil
    from sweden
    Thank you!
    I think it turned out good!
    Not too slippery so it looks skinny but enough of a slide to pick up the lines of the side windows and the trunk.
    Chief 64 likes this.
  29. emil
    emil
    from sweden
  30. Phil 41 Chevy
    Phil 41 Chevy
    awsome work
    emil likes this.
