Projects 1931 Roadster AV8 Build
Discussion in 'Traditional Hot Rods' started by 53studecoupe, Nov 30, 2019.
  1. 53studecoupe
    53studecoupe
    from Eagle WI
    I modified some F1 shock mounts to allow my fenders to clear. Not much room to work with spring perches right in the road and the hoop steering arm. 20210219_112032.jpg 20210219_112022.jpg
    Lil'Alb, Tim, Stogy and 2 others like this.
  2. 53studecoupe
    53studecoupe
    from Eagle WI
    20210225_124325.jpg 20210225_131223.jpg Here is a pic for the rear shocks. Mounted forward of the rear end.
    Tim, Stogy, sloppy jalopies and 3 others like this.
  3. getow
    getow
    Looking great. Im following.
    Stogy likes this.
  4. 53studecoupe
    53studecoupe
    from Eagle WI
    Thanks. Coming from you guys that means a lot. I don't have any pictures just yet but I scored some parts for the flathead. A nice set of 8BA rods and std crank with a single wide groove pulley. It's coming along.
    Stogy likes this.
  5. 65stang85
    65stang85
    from michigan
    Lookin good
    Stogy likes this.
  6. 53studecoupe
    53studecoupe
    from Eagle WI
    Thanks
    I just received my 8BA crank and noticed the clean out holes were 5/8 and not the 3/8 I was expecting. So I did a search on the forum and found it could be a Mercury 4.00 stroker. The counter weights measure 6.00 and the journal offset is 2.0 x 2 = 4.00. What a deal for $250. 8 very nice clean rods $75.
    Just need a cam and I am a set to rebuild. More searching this forum for building info from wiser persons than myself.
    Thanks again View attachment 4995269 View attachment 4995269
    Stogy and warbird1 like this.
  7. 53studecoupe
    53studecoupe
    from Eagle WI
    I guess its a good thing I didn't buy pistons although I don't know what it will take to clean up the bores maybe 3.312????? I have one cylinder with a very deep score but no cracks. What does that make a 287???
    Stogy likes this.
  8. 53studecoupe
    53studecoupe
    from Eagle WI
    20210317_132218.jpg 20210317_134938.jpg Finishing up the little details.
    I went thru my stach of throttle linkages and realized all were too long..the distance between the gas pedal and the throttle linkage.
    I decided I wanted two mounting points because the 3X Strombergs are a little hard on the linkage wanting to always twist it. I just ended up shorting it and welding back together. Cut an access hole in the firewall and the proper length linkage and we are good to go.
    Stogy and Fairlane500 like this.
  9. 53studecoupe
    53studecoupe
    from Eagle WI
    Dug my 34 pedals out and dis***emble them. The bushing for each pedal were completely worn out. I purchased a rebuild kit. It comes with a new shaft, 2 new bronze pedal bushings 1 wave washer and dowel pin.
    I modified the brake pedal like the Tardel book by cutting off the MC arm and welded it 180 degs from were it was. It will end up right where the grease fitting is/was.
    It now will allow a 1940 MC to mount behind the pedal asm. The clutch pedal needs nothing other than a new bushing.
    Re***emble with a good grease and bolt into the 1932 crossmember. Here the pedals will need to be adjusted with a hot wrench to center between steering column.
  10. 53studecoupe
    53studecoupe
    from Eagle WI
  11. 53studecoupe
    53studecoupe
    from Eagle WI
    20210322_145245.jpg 20210322_145302.jpg I purchased one of the mc brackets that bolt to the back of the 32
    k members. I didn't like how low it mounted the mc.
    So I cut it up and welded it directly to the 34 pedal bracket. The mc will be bolted from the backside of the crossmember thru drilled holes into the pedal bracket. They were bolted together here to check the pushrod alignment.
    Stogy, brEad and the pinstriper like this.
  12. 53studecoupe
    53studecoupe
    from Eagle WI
    The floor was clearanced for the pedals and a removable cover was added to cover up the original steering location hole in the firewall. A lot better driving position for me.
    I found a great material for taking up the space between the original drop column and the smaller F1 column. It hold the column very tightly.
    20210326_175720.jpg I might start selling them if there is an interest.
  13. getow
    getow
    Dont forget your jam nut on the draglink....
    Stogy likes this.
  14. 53studecoupe
    53studecoupe
    from Eagle WI
    I have to modify the drag link to clear the bones is why it's off.
    Good eye!!!!
    Stogy likes this.
  15. ol48
    ol48
    Nice build
    Stogy likes this.
  16. 53studecoupe
    53studecoupe
    from Eagle WI
    I took the plunge today. I bolted the subframe down and welded in the crossmembers. Checking width and square corner to corner I welded all the floor pans in. I think I will start with the cowl and work my way backwards. I left the rear crossmember loose just in case I have to move the quarters a bit to hold the door gap. A lesson I learned on another build with huge door gaps. No fun to fix. 20210401_163651.jpg 20210401_163622.jpg
  17. Cool build. Looks like it's coming together nicely.
    48fordnut and Stogy like this.
  18. getow
    getow
    Good choice that you screwed the axle cover in place. Might make something easier in the future. I on the other hand was welding silly..... And i still wonder if i should of did that. Time will tell.
    Stogy likes this.
  19. Dilley
    Dilley
    Really looks great! Hoping to start my own AV8 build soon.
    Stogy likes this.
  20. V8Vic
    V8Vic
    from norcal
    Coming along very well. Keep it up.
  21. 53studecoupe
    53studecoupe
    from Eagle WI
    Thanks guys for the nice thumbs up
    Yeah I stich welded everything. Think about it when you try to take a spot welded panel about. I use seam sealer underneath if you worry about making the joint water tight.
    Next time!
  22. 53studecoupe
    53studecoupe
    from Eagle WI
    I reskined the cowl side using the original frame work. I laid out the spot welds in the same place. Before welding I should have checked the belt line alignment with the door and hinge location. I lucked out. They aligned perfectly.
    Although the lower stanchions do not. After market part adjustment is required.
  23. 53studecoupe
    53studecoupe
    from Eagle WI
    Since my roadster is a late 31 I am using the indented firewall. This one is in very good condition with no stress cracks on the lower feet. The mounting bolt holes helped with the alignment and the subframe extension rivet holes. Also adding the dash rail helped a lot in adding some stiffness to the cowl. It dropped on the frame and bolted up nicely. 20210407_131541.jpg
  24. 53studecoupe
    53studecoupe
    from Eagle WI
    Although the lower stanchions do not. After market part adjustment is required.[/QUOTE]
    No problem. Weld the holes up! Position where they need to be and drill and countersink. Repeat... 20210409_125813.jpg 20210409_133238.jpg
  25. 53studecoupe
    53studecoupe
    from Eagle WI
    Today was a big day for the project. I have some original doors to hang with repo hinges. First thing I noticed was the hardware is different from the door to hinge than cowl to hinge. You guessed it I didn't have any 5/16 fine flatheads. I ***umed they would be the same...
    So I used some cap screws knowing I wouldn't be able to close the door. But they can be test fitted anyway.
    It already appears the top gap is going to be too wide and the bottom too tight. Both sides are the same amount. It looks to me the offset of the top hinge is too much. I am getting used to this aftermarket adjustment.
    oliver westlund, Lil'Alb, Tim and 6 others like this.
  26. 53studecoupe
    53studecoupe
    from Eagle WI
    After looking at the miss alignment closer it appears the cowl to subframe angle is also incorrect. The bottom of the door hits the door sill at the rear. I think the cowl needs to be shimmed up in the rear
    Some. That will raise the rear of the door up to run more parallel to the door sill. Pics coming.
  27. mtb1981
    mtb1981
    Looks great, nice clean work!
  28. NoSurf
    NoSurf
    Looks great so far. Good job!
    I remember heating and bending the pedals for my coupe- seemed to take forever to get them right where I wanted them.
  29. 53studecoupe
    53studecoupe
    from Eagle WI
    20210414_152344.jpg 20210414_152327.jpg Here is where I need some help. I read all the posts about alignment of the doors here but my concern is the big gap I see along the door bottom and the sub frame. It doesn't look right. It is as if the cowl is too wide as it sets on the sub frame. Any ideas?
  30. 53studecoupe
    53studecoupe
    from Eagle WI
    Is there some sort of door sill like on the 28-29? I don't read anything about that for the 30-31.
