Hot Rods I finally got an injected 1961 Corvette !
Discussion in 'The Hokey Ass Message Board' started by 31hotrodguy, Sep 24, 2020.
  1. 31hotrodguy
    31hotrodguy
    Now that is more like it! A little heat and using the other king pin the p***enger side came right out. Plus it would appear this one had actually been greased at some time in its life. IMG_4742.JPG
  2. 31hotrodguy
    31hotrodguy
    scotty t and loudbang like this.
  3. 31hotrodguy
    31hotrodguy
    When I hold my driver side lower shaft from the lower control arm up to a straight age the threads are worn. The shaft itself does not appear to be bent but rather the threads seem worn down. Do I need to replace it or am I just being picky. Keep in mind the replacement kit for all the shafts is $575 from corvette central. IMG_4799.JPG
  4. 55 Ford Gasser
    55 Ford Gasser
    Worn or maybe stretched. Either way, probably best to replace it. Yes, the replacement kit is expensive, but in the scheme of things (ie. what the car is "worth" when finished), what's $575? Ron
  5. 31hotrodguy
    31hotrodguy
    Well when you say it like that Ron it almost doesn’t sound so bad. Lol
    The aftermarket bolt on with “modern 50 yr old camaro” part is sounding better all the time. However; definitely not the price.
  6. [QUOTE
    Sent from my iPhone using The H.A.M.B. mobile app[/QUOTE]
    Huh? What aftermarket modern 50 year old camaro part?
  7. 31hotrodguy
    31hotrodguy
    Sorry that wasn’t very clear. I was munchkin wrangling when I wrote that. I was referring to the aftermarket bolt on front suspension that corvette central sales. It uses parts from the second generation camaro ie the 70 to 80 something. They are like $4 grand or somewhere in there. I just get a kick out of the fact that for around $4k we can upgrade to “modern” suspension with tubular control arms but ultimately it is a 51 yr old design. Not knocking it but thought “modern” and 1970 camaro was kind of funny to think of funny.
  8. Budget36
    Budget36
    Is that a hardened all thread stud with a nut on it, or a bolt?
  9. jimdillon
    jimdillon
    Scott, I would replace them and the ones that I have purchased from Corvette Central were actually pretty nice IMO. They run $39.95 each for the threaded bolt and the sleeve. The kits get a bit pricey when you buy the whole kit with the all of the parts. As you can imagine the bolt is under a bit of torque so I would replace it. I have a couple of equally bad ones in some boxes I am sure.
    The other part that you should look at is the upper control arm shafts that go through the cradle which you have removed (the inner shaft in essence). If you can move the upper control arms with ease as it rides on the shaft then it is something to consider. You will have to remove the upper control arms anyways to install new rubber bushings anyways and when you do it will be easy to inspect the shafts. When they are worn the grooves are obvious. If you have to replace the shafts Tom Parsons has a great instructional paper on the topic with pictures. If you have to do that be prepared for a great deal of fun. It is one of the not so fun jobs. Hopefully yours are good.
    You probably will have to make a laundry list and see what you have to replace before buying the kits. I am not a fan of some of the new parts, like the upper control arms. I have purchased a couple that I did not like and sent them back and looked for extras at swap meets. Also when you replace the aluminum shims for caster (that sit on the cradle and against the lower part of the frame) the new shims are supposed to be 2* but the new ones are closer to 1*. I try and buy nice used ones at swap meets or on ebay.
  10. 31hotrodguy
    31hotrodguy
    Budget 36, it has a p***age way for grease from then end part to about half way where it travels through the spindle support. It is definitely not just a big bolt.
  11. 31hotrodguy
    31hotrodguy
    Jim, I got both upper control arms off the cradle but I haven’t inspected the shafts yet. They are still pretty dirty.
    I’m definitely not opposed to buying new stuff but after I got my “new” made in China third arm bearing from corvette central I am a bit leery about just spending a lot of money on replacement parts.
  12. 31hotrodguy
    31hotrodguy
    loudbang and enloe like this.
  13. Ryan
    Ryan
    ADMINISTRATOR
    This thread is rad.
  14. 31hotrodguy
    31hotrodguy
    Ryan, would that be a play on words? Lol
  15. 31hotrodguy
    31hotrodguy
    The threads on the upper control arm shafts look good so hopefully I can leave those alone as some have suggested that they are pure evil to get out! I’m hoping to now start putting things back together!!!
    saltflats, loudbang, enloe and 4 others like this.
  16. 31hotrodguy
    31hotrodguy
    Off to the soda blast guy! Some 60 Pontiac parts hitched a ride too. [emoji6]
  17. 31hotrodguy
    31hotrodguy
    Body work on the corvette has officially started! A local guy I met from Tri5Chevy who has experience with corvette fiber gl*** work has offered to help me with the body. I’m excited but nervous. Body work i know nothing about.....fiber gl*** I know even less about! Lol
  18. 31hotrodguy
    31hotrodguy
    It is hard to tell from the picture but the parts actually sparkle. [emoji16]
    My first time having something blasted with water and gl***. When it’s all done the treated water acts as a rust inhibitor. Or so they told me. It sounded good to me.
    Sent from my iPhone using H View attachment 5018560 .A.M.B.
  19. 31hotrodguy
    31hotrodguy
  20. There’s a local shop that does THE BEST blasting and powder coating work, affordable and quality. When you find THAT guy you stick with him!
    W Kendall & Sons Inc In Wanatah Indiana
  21. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Almost ready for the chrome shop!
  22. AngleDrive
    AngleDrive
    from Florida
    They go just as fast painted
  23. 31hotrodguy
    31hotrodguy
    Well I started sanding a fender! It was super cool for about 30 minutes and then lost its cool fun factor. A body man I am not but I am determined to learn! IMG_5530.JPG
  24. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That reminds me of my '56. It had been 7 different colors, no telling how may coats. I stripped it to bare gl***. I used 10 gallons of military surplus stripper and probably 50 sheets of sand paper of various grits. It'll uncover stuff you wish you hadn't seen, but it's so much easier to fix it right when everything is exposed.
    catdad49, loudbang, bchctybob and 5 others like this.
  25. 31hotrodguy
    31hotrodguy
    Definitely! So far I’ve found dark grey primer, red, the factory fawn beige and some weird stuff!
    The car suffered front end damage and was pieced back together. With the help of a friend I am slowly over coming my body work fears.
    loudbang, enloe, bchctybob and 2 others like this.
  26. guthriesmith
    guthriesmith
    Nice. Main thing to remember when sanding gl*** is that you can sand too much and cause yourself problems if not careful. It keeps going away about like paint and not steel when sanding. Otherwise, I would rather work with gl*** than steel since there is no rust to deal with.
    loudbang, enloe, 31hotrodguy and 3 others like this.
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    What did you use for blasting media?
    loudbang and 31hotrodguy like this.
  28. Crushed gl***
    catdad49, loudbang and 31hotrodguy like this.
  29. bchctybob
    bchctybob
    You know, I still think that front crossmember looks like a two headed slug. Good thing it’s hidden under a hood and two fenders. Lol
    SS327, loudbang, lumpy 63 and 2 others like this.
