Projects I'm 18 and building my first flathead 59AB+merc crank for my chopped 34 4 door sedan
Discussion in 'Traditional Hot Rods' started by Jesse Borba, Nov 20, 2020.
  1. Jesse Borba
    Jesse Borba
    Sorry for the lack of progress I've been super busy, last night I pulled the front end out of the 34 hoping I could easily get the king pins out of the f1 spindles on the axle since they wouldn't fit my hubs and they were welded to the backing plates. The king pins were super stuck so it took me until tonight with the torch and air hammer to drive the king pins out of the dropped axle. I then put my square back spindles and wide five hubs on for mock up. The wheels I had laying around had 6.00s on them so they kinda work but I think I'm going to go for 5.50s when I get new tires. Next step is to put my 46 to 48 truck rear end with 4.11 gears. 1616811982879.jpeg 1616812033894.jpeg 1616812080141.jpeg
    Sent from my SM-J727V using The H.A.M.B. mobile app
    Jeff34 likes this.
  2. warhorseracing
    warhorseracing
    from cameron wv
    Looks to me that you have been super busy.;) On your project. Anything that you get done is progress.:) No matter how long it takes. It looks like you are doing a good job along with school and anything else you got going on.:cool: Keep at it. Slow and steady wins the race, even if you take a little break now and then.:p
    Desoto291Hemi and Jesse Borba like this.
  3. mike bowling
    mike bowling
  4. sloppy jalopies
    sloppy jalopies
    since you are slicing and dicing what about your firewall...?
    a '35-'36 ford truck firewall looks very much like the '33-'34 but is about 4" shallower...
    buys you extra engine bay... they are almost the same outer size as the '34...
    '37-'39 trucks were the same size but had a handy built in batt box... DSCN1843.JPG
    Jesse Borba likes this.
  5. Jesse Borba
    Jesse Borba
  6. Jesse Borba
    Jesse Borba
    I'll keep this is mind, thank you!
  7. oliver westlund
    oliver westlund
