6x2 Carb Set Ups - Pics and Information?? - who made them?
Discussion in 'The Hokey Ass Message Board' started by arkracing, Aug 1, 2006.
  1. arkracing
    arkracing
    I was going to ask you about the set up on your truck. What type of intake is it??? and what's in the motor?
    Straight linkage and it runs good!!! Nice!!! When you "punch it" does it give you the same effect of secondaries opening up or is it more of a "smooth" acceleration?
  2. SinisterCustom
    SinisterCustom
    What size of powervalves are you running in the 94's??
  3. Durod
    Durod
    from DFW, Tx
    there's some serious motor **** in here. ****in' a... nice pix and info, thanks for the good read.
  4. displaced_kiwi
    displaced_kiwi
    from Olathe KS
    I like this thread as searching for 6x2 info was what lead me to the hamb in the first place. I have a wieand dragstar for a sbc with 6 holley 2100 carbs on it. All carbs are hooked up. I bought it cause I thought it was just too damn cool. I recently bought a car to go with it.
    Heres a pic (bigger version of avatar)
  5. beatnik
    beatnik
    Here's another style blower top from an Aussie Truck.
  6. tommy
    tommy
    Some of the bolt holes are inside the intake. You can just see 1 bolt hole under the carb base. Edelbrock used a long bolt. Socket head cap screws work well. (allen wrench)
  7. jawdrpn36
    jawdrpn36
    from bay area
    here is my set up
  8. jawdrpn36
    jawdrpn36
    from bay area
    thats the same intake i do have and i used a regular bolt and used a distributor wrench
  9. SAVAGE
    SAVAGE
    Alliance Vendor
    here is a shot of flips 55 with a 6x2 setup. . Most people like the look of them Staggered better. I like them either way..
    Its a ton of work to make a blower tops . I have made a couple by hand.
    I realized it was better to make a mold and cast them in the end. Especially with the price of aluminum..
    Aaron Von Minden
  10. 1951mercury
    1951mercury
    from Illinois
    don't know what it's worth but i think its an old edlebrock crossram.
  11. Insane Rob
    Insane Rob
  12. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    The intake is just your basic Offenhauser, the engine is less than mild, its a 327 bored .030, 10.34 compression, real small Isky stick, .464 lift with .221 dur. @ .050 on a 108 centerline. Stock camel hump heads 2.02 / 1.60 valves. I did not even gasket match the heads or intake, I plan on doing that this winter, she is in need of a rebuild, its short life has been brutal, but still running strong. I also run the plain jane msd box with it, I think it helps burn the fuel better..................................When you punch it.it just goes, it does not feel like it has vacuum secondaries at all, it is very responsive......it marches hard....Littleman
  13. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I blocked all six power valves, people will argue about too block or not to block...............I blocked them, saw no pupose to try them unless I could not get it to work without them.......................the time slips I have do not lie................then again I have no idea what I am doing, I just try my best....Littleman
  14. daveyboy56
    daveyboy56
    `OK DOES ANYONE MAKE ONE FOR A 350 SBC WITH vortex HEADS??
    Thanks Dave
    I would love a 6 by 2
  15. yeah i was told edlebrock you can find them on summit for like 300 and some change
  16. daveyboy56
    daveyboy56
    Can you give me a link to a 6X2 i cant find it on summit or any where for Vortex heads
  17. arkracing
    arkracing
    Offy Intake???
  18. jawdrpn36
    jawdrpn36
    from bay area
    its an edelbrock ml intake[​IMG]
  19. Nekronomicon
    Nekronomicon
    Got any close up shots??
  20. LORYDER
    LORYDER
    Here's an Offenhauser set up l have and l took some pics for you when l run them l use the center 2 for primaries and the out side 4 for the secondary.
    As for the power valve thing l usually put in 3.5 in.
    l have run a few setups with good success.
    l have a few different 6 carb setups and l also have the one from EELCO for the 671 that lm building right now for my A.
    Some times l even end up making my own linkage's up.
    But half the time its easier to buy the linkage from EELCO.
    l have to still go through the carb's before l can use them, so l will install longer throttle shafts in carb base's when l redo the 97's
    This is a setup lm using right now on my 27 Roadster pickup its a 4x2 setup with 4 Holley 94's. lm really happy how this setup works on the small block l made up the progressive linkage up out of a few old sets l had kicking around and added a couple of rods.
  21. arkracing
    arkracing
  22. LORYDER
    LORYDER
    Just think about it my friend.
    Look at the lay out of the intake and its runners
    The front two are the primaries and the back two are the secondaries...:)
  23. LORYDER
    LORYDER
    Ok l dug up some photos when l was still trying to get the linkage setup happening, before it was just about l finished.
    Here is a side view of the linkage.
  24. arkracing
    arkracing
    ok I see you used a regular 4x2 Crossram and put something like the "Vintage Speed" adaptors on it. That is really cool - I like it!!!
    I was thinking it was more like a "Man-a-fre" SetUp - which if you ran it progressively it would seem to be "unbalanced"
    Nice Work!!
  25. jawdrpn36
    jawdrpn36
    from bay area
    here is 1 one i just took [​IMG]
  26. Dat Dirty Rat
    Dat Dirty Rat
    If your interested in my x-1 then send me an e-mail at DATPACKRAT@YAHOO.COM
    Its in mint shape and was polished back in the day...
    From what i was told it ran on a old altered in Cali...
  27. Tudor
    Tudor
    from GA
    had to dig this one back up - way too many cool pictures in it to let it get lost just yet
  28. God, I love the 8 x 2's on the blower.....way cool.
  29. Nekronomicon
    Nekronomicon
    Good call! I would of thought more people would have a 6x2 setup. Maybe we should start seeing some 8x2 pictures...
  30. arkracing
    arkracing
    Thanks guys - great pics and information.
    Anybody got more Pictures???
