Projects Another AV8 build thread...
Discussion in 'Traditional Hot Rods' started by 65stang85, Dec 30, 2020.
  1. Wheeliedave
    Wheeliedave
    18’s are 1932, 17’s are 1933 and 1934.
  2. 65stang85
    65stang85
    from michigan
    20210214_094226.jpg Modified the radius rods today, setting the caster on the front axle required us to cut and bend the rods up about 6". We ended up cutting a "V" about 3/8" at the top down to nothing at the bottom, we didn't cut all the way through the bottom just heated it up and bent it.
    48fordnut and loudbang like this.
  3. 65stang85
    65stang85
    from michigan
    20210214_102216.jpg Cut and bent left us with perfect area for weld, we chamfered the edges of both ends before bending them into place.
  4. 65stang85
    65stang85
    from michigan
    20210214_113741.jpg End result with about 6 1/2 degrees of caster in the front axle. I finally sourced an F1 box so we will be working on the steering next.
  5. 65stang85
    65stang85
    from michigan
    20210221_112334.jpg Dis***embled the F1 box today and started work on getting it ready to fit in the frame, we decided to go with the new weld on flanges instead of using the Model A flange. This pic was after cutting off the F1 flanges with a porta-band.
  6. 65stang85
    65stang85
    from michigan
    20210221_122923.jpg A little time spent with a grinder and a belt sander, I'm not going to take it any further until I get the new flanges. Pretty happy with how it turned out.
  7. 65stang85
    65stang85
    from michigan
    20210221_112313.jpg "V'd" out the four flat spots on the pitman arm, started them with a hacksaw and finished with a triangle file, a lot easier than I thought it would be.
  8. Carl Gibbs
    Carl Gibbs
    Looking great. I'm following everything your doing.keep posting the pics and the progress.
    38 Hump, loudbang and woodiemike like this.
  9. 65stang85
    65stang85
    from michigan
    20210314_091300.jpg I got the F1 steering box flanges from Millworks Hotrod earlier this week, so we worked on getting the steering column mocked up today.
  10. 65stang85
    65stang85
    from michigan
    20210314_103244.jpg A little more shaping with the belt sander was needed on the steering box snout, I also V'd out the back of the flange for a deeper weld.
  11. 65stang85
    65stang85
    from michigan
    20210314_091847.jpg We used the stock location just moved it down and back as much as we could.
    chryslerfan55, 48fordnut and loudbang like this.
  12. 65stang85
    65stang85
    from michigan
    20210314_170740.jpg Here's what the final setup looks like, I haven't tacked the flange on yet as the body isn't 100% adjusted. The column is pretty close to the rear exhaust port so we may "m***age" the column jacket to gain a little more clearance as the plan is to run lake style headers.
  13. 65stang85
    65stang85
    from michigan
    20210314_170717.jpg We ended up deciding that dropping the column 1 3/8" would be about right, as you can see we will be running most of the stock interior. Now that we've got the column in place we will be installing the trans crossmember and fitting the pedals and master cylinder.
  14. 48fordnut
    48fordnut
    Doing excellent work. Keep on keeping on.
    Are you going to box the inside where the w bone plate is on the frame?
  15. 65stang85
    65stang85
    from michigan
    Thanks, initially we weren't but the more I see it flex the more I want to box it, I've always liked the look of an unboxed frame but do realize there's no comparison in rigidity. Is it acceptable to just box sections? Or do you run in to possible weak spots for cracks to form?
  16. 48fordnut
    48fordnut
    I would box 1'' fore and aft of the plate you are connecting the bones to. That is what I am doing on mine. My footprint is smaller than yours.
    loudbang and 65stang85 like this.
  17. 65stang85
    65stang85
    from michigan
    20210328_124416.jpg Got the pedals mounted and bent around the steering column, brake pedal looks weird but that's because its just laying down, they're both the same distance away from the column.
  18. 65stang85
    65stang85
    from michigan
    20210328_175606.jpg The final location of the pedal ***embly, pay no attention to the swiss cheese holes....
    loudbang, 48fordnut and chryslerfan55 like this.
  19. 65stang85
    65stang85
    from michigan
    20210328_175515.jpg The front side of the original crossmember will be cut out and a new lip welded on to accommodate for the master cylinder.
  20. 65stang85
    65stang85
    from michigan
    20210328_172028.jpg Had a little helper tonight while dis***embling everything, anybody seen my 1/4" Snap-on wrench?
  21. Wild guess, the boss ( her mother) insisted didn’t she.
  22. 65stang85
    65stang85
    from michigan
    Actually she asked to "go up to the shop" when she woke up from her nap, mostly because she knows there's junk food up there to snack on, mom was out volunteering.
  23. Well now, I’d say she’s got potential. I mean, she’s clearly interested in hot rods. [emoji56]
  24. 65stang85
    65stang85
    from michigan
    Out of all her matchbox cars her favorite is a '32 roadster, she's on the right track
    chryslerfan55, loudbang and 48fordnut like this.
  25. Jacksmith
    Jacksmith
    from Aridzona
    Excellent! My 40 year old daughter got started the same way... she's the gearhead of the 3. Her 2 brothers aren't nearly into it as she is. Her '68 455/4-speed Cutl*** is her baby that she does all the work on!
    65stang85, loudbang and chryslerfan55 like this.
  26. 65stang85
    65stang85
    from michigan
    Been a while since we've been in the shop, now that the weather has been decent we're building a cabin on our family's property but we got rained out today so we spent some time fitting the master cylinder and modifying the trans crossmember. 20210328_175515.jpg The square represents the master cylinder and the arch is a 6in dia portion to be cut out.
  27. 65stang85
    65stang85
    from michigan
    Bent a piece of flat stock and tacked in place
    What it looks like with everything in place
  28. 65stang85
    65stang85
    from michigan
    As most of you know the F1 crossmember is taller than the A frame so we cut a V out of it and heated it up and bent it to match the frame.
    Where we left off for today, still some t******* to do on the ends and some filling to do at the old master cylinder hole.
  29. Carl Gibbs
    Carl Gibbs
    Looking great.
  30. Hotrodder28
    Hotrodder28
