Projects Model A 283 dual quads
Discussion in 'Traditional Hot Rods' started by Naki boy, Mar 30, 2021.
  1. Naki boy
    Naki boy
    Hi All
    I've just sold my 57 and I'm planning my next build a model A coupe.
    I've got a 1957 238 220hp P/G engine which came with a set of 270hp dual quads.
    If I used the 283 and dual quads I guess I'm building post 55/57, would the dual quads be a popular route for guys back then or is a 3, 4 or 6 carb set up closet to what people used? Or am I over thinking it?
    Chris
    LCGarage and tractorguy like this.
  2. Almostdone
    Almostdone
    Depends on what your goal is and how much of a stickler you are. If you plan to build a period-correct car for pre-57 or whatever then that won’t do. Many people go for a period-flavor car... not so exacting on the period details, but still cool and a lot of fun.
    I think the 2x4 on a 283 wold be great.
    John
    olscrounger and Naki boy like this.
  3. tb33anda3rd
    tb33anda3rd
    dual quads are the way to go
  4. Mr48chev
    Well, in the 50's as soon as that setup was available guys who could afford them were running them on hot rods.
    I had that setup on my T bucket with the 283, power pack heads and 098 cam and it ran pretty decent.
    I'd go with a good hydraulic cam though, lifter rattle and adjusting valves on Saturday mornings is over rated.
    1975 photo
  5. Atwater Mike
    Atwater Mike
    Agreed...but if AFBs or Edelbrocks are used, there may be some 'critics'... (always are)
  6. Dean Lowe
    Dean Lowe
    Nothing wrong with dual quads.
  7. Bob Lowry
    Bob Lowry
    Hot rodded first-hand in the 50's and 60's, and at that time the ultimate cool was a set of Corvette dual
    quads. And, Corvette valve covers made it go even faster, haha! My vote is in.
  8. belair
    belair
  9. AngleDrive
    AngleDrive
    from Florida
    Traditional 1961
  10. jimmy six
    jimmy six
    A 220 hp 283 is a 245 hp with dual quads. A 220 hp 283 with FI is a 250 hp and was available with a power glide just like the 245 hp. Dual quads on any engine, stock or not, car I p*** at a gathering will always get a look.... an LS did at one time now, never.
    I’ve run dual quads on a stock, no cam/head change non-GM engine for 6 years and have no reason to remove them. GM perfected the progressive d-q set up on the 265-283 and I guarantee it works on other engines just fine. 82035F1B-E675-4488-9EF0-1A5E3B0136BA.jpeg
  11. D2Denny
    D2Denny
    In 1965 I bought a 270 hp 283 complete with a cracked block for $200.. Went to the junk yard and picked up a standard 283 for maybe 50 bucks. Honed it out, bought new rings and swapped everything else including the dual quad manifold with WCFB's. Pulled the 265 out of the coup and dropped it in. Ran like a ****d ape. Too bad it didn't steer or stop for ****. Cant find a photo with the hood off. Den's Model a coupe.jpg
  12. Naki boy
    Naki boy
    Thanks guys that's great news, I do like the dual quad set up it looks neat.
    I've all the factory engine parts too so I hope to have a real nice looking engine when done.
    Is the 098 the Duntov cam?
    I've no issue setting valves got had a bit of practice on 2 stroke Detroit's and ***mings.
    I guess a model A will need a bit of m***aging to fit engine and I'll need a gear box of some sort 3 or 4 speed??
    In the mean time I'll get busy building up this 283 :)
    Cheers Chris.
  13. Hows the linkage set up on a dual quad? Is it progressive ? Does the second carb come in before the 1st carbs secondaries,or with them?
  14. If they are real 270hp carbs the vete guys will pay big bucks for them. You could buy some real pretty “clones” already done for for less probably
    kidcampbell71, loudbang and Bob Lowry like this.
  15. swade41
    swade41
    from Buffalo,NY
    Maybe research parts availability for the wcfb vs AFB's before you get to deep into it, with air cleaners on 95% percent of people looking at it wouldn't even notice unless you said something, of course you would need a new intake for AFB's.
    This is an Edelbrock C26 with 500 cfm Carter compe***ion carbs
  16. Naki boy
    Naki boy
    There the real deal WCFB 270 hp carbs, dual point dizzy and intake, no linkages, hard pipes or air cleaner.
    Yeah I've seen the price of them not cheep! It will be hard to sell them too :)
    A 4 or 6 carb set up would be cool and that's what I was leaning towards but I do like the look of the WCFB's.
    Thanks for the pic swade41 I've had a bit of a nosey for parts on the WCFB's and there's a little bit of stuff around.
    tb33anda3rd, bchctybob and swade41 like this.
  17. Taboo56Chevy
    Taboo56Chevy
    you can get most everything for the wcfb's. If your set on running the little air cleaners like a factory setup, you are stuck on the wcfbs anyway. They have a smaller air horn diameter than later afb's or edelbrocks.
    scotty t and bchctybob like this.
  18. Taboo56Chevy
    Taboo56Chevy
    your dual quads would pay for a 6x2 setup and still have a little change left over. The dual quads though are much less h***le and run really good and still have the wow factor. We have 2 sets of 6x2's, one a 327 small block and another going on a 348 w motor and they can get spendy quickly. I have a partial 245hp dual quad setup (missing the rear carb) and been trying to piece it together and by the time I buy that one carb then rebuild both and then pick up any other missing parts I would could have a chrome plated tri power.
    kidcampbell71 and bchctybob like this.
  19. 56sedandelivery
    56sedandelivery
    If you use the factory dual quads, you're pretty much stuck with using the WCFB's (unless you don't mind ugly *ss adapters), and that's if you can even find the correct WCFB's, or as already mentioned, "clones". Plus, the factory manifolds are very porous, and the heat crossover can actually burn out/through, causing an engine internal fire, pressurizing the engine causing gaskets to blow out/leak, and really ruining your day. With a factory manifold, always remove the tin oil deflector pan on the bottom of the intake and inspect the heat crossover thouroughly. Aftermarket manifolds are machined better, use better and thicker aluminum, and the carburetor spacing is such that carbs, other than the WCFB's, can be used. A lot of the early Vette owners had their dual quads/fuel injections removed, and went with a single 4 barrel for simplicity (after messing around with them for a while, so there are complete setups still out there). I have the early 56 (225 HP) manifold, and clone WCFB's, plus all the other pieces for a complete swap. I had a couple of other dual quad intakes, one an Edelbrock, and the other a Wieand WC-327 (I think that was the number), that I should have kept; it was their earlier style with the "dog-bone" mounting ports. Dual quads on a 283 done up old school would be right on the "traditional money". I am Butch/56sedandelivery.
  20. swade41
    swade41
    from Buffalo,NY
    He lives in New Zealand though
  21. swade41
    swade41
    from Buffalo,NY
    Here's just a couple more photos showing the difference in carb spacing between the Edelbrock C26 vs. the Offenhauser, something else to think about if you don't use that stock GM piece.
    kidcampbell71, loudbang and bchctybob like this.
  22. Do not underestimate the value of the factory Chevy dual quad setup, sold one for HUGE money at the March Meet a few years ago to a Corvette restorer! Seems he had a 56 Corvette that was missing its carbs to be worth the Bloomington Gold....
    kidcampbell71 likes this.
  23. Bob Lowry
    Bob Lowry
    Original pair on an unrestored 1961 Corvette ...
  24. bchctybob
    bchctybob
    Since you already have most of the stuff for the dual WCFB set up I would set it up and run it. You shouldn't need a lot of hard to find hard parts just a couple of good carb kits from Carbking. If you want a 6x2 setup just start collecting parts and build one up slowly and try it out once its complete. Nothing wrong with having two cool old timey set ups.
    High test 63, Fordors and Bob Lowry like this.
  25. Bridenour
    Bridenour
    from oklahoma
    Early summer of 1960, I traded a Chevy dual quad setup for my first T roadster body which was mounted on a Model A roller frame. The duals were going in a 37 Ford. In our area flathead engines were being phased out in favor of Chevy V8's and flathead parts were as common as dirt and almost as cheap. 97's & 94's were a dime a dozen and not nearly as ***y as a dual quad setup. The big v8's with multiple two barrel carbs were still in dragsters, etc. but were kind of awkward and overkill in a street rod.
  26. Naki boy
    Naki boy
    Thanks guys I like the sound of having two set ups for the 283.
  27. jimmy six
    jimmy six
    On the Corvette/Chevrolet 245-270 you don’t need to run the individual air cleaners if you don’t want to. The 1961 had a single base with properly spaces holes and. GTO filter also fits if you want a taller filter element. My base had a Danchuk sticker on it when I bought it off e-bay. The spacing of the stock Chevrolet and the Edelbrock Y-Block are within 1/16”.
    The repo small air cleaners are way to much $$$. Charlie Price offers the top adapter and an EMPI VW air filter fits. I used aluminum pan lids for tops. I posted a photo of them earlier. This photo is of the 1961 Corvette base; the pvc elbow is part of my PCV system. C68531EE-2383-4983-B500-98D07833E284.jpeg
  28. Fordors
    Fordors
    Money is sometimes overrated, if I had the original carbs and distributor I would keep that setup.
    I have often looked back and regretted letting go some of the rare parts I had over the years.
    dogwalkin and olscrounger like this.
  29. olscrounger
    olscrounger
    Love the look of the factory dual 4's. Played with a few sets back in the 60's. A 283 with those and an 097 solid cam is a snappy little setup-sound can't be beat. My 57 fuely (283/283) had the 097 12 and 18 cam and I drove it a lot. Did not require constant adjusting of solids unless you really leaned on it a lot. With factory progressive setup they run great!
    427 sleeper likes this.
  30. Jay Here
    Jay Here
    from Illinois
    Are you going stock style carbs?
