Projects Gasser / Fenderwell Header Help
Discussion in 'Traditional Hot Rods' started by C1/C2Guy, Mar 30, 2021.
  1. C1/C2Guy
    C1/C2Guy
    from Utah
    Looking for header help for my 56 Corvette G***er. I am mocking up the suspension / engine etc. I had some headers that I bought at a swap meet but they are too wide. They measure 66" from outside of collector to outside of collector. Needs to be 61" or slightly less for the Corvette. Patriot makes a SBC Tri 5 header #H8034. Anyone know what the width of those are? Also Dougs makes a #D329 header for a Chevy II. As near as I have been able to tell, I think they might be too narrow. I would like to have the collector just barely inside the fender. I guess the next option is to build some. Possibley Speedway kit #41865600 or? Anyone have some experience in this area? Thanks!:)
  2. blue 49
    blue 49
    from Iowa
    The ones I have on my Henry J are fairly narrow. They are from Advance Adaptors and are to put a SBC in a Toyota Land Cruiser.
    Thor1 likes this.
  3. Bob Lowry
    Bob Lowry
    I believe these are the Patriot ones you mention. Had them on my '46 Chevy. Don't recall the exact part number,
    but I found them listed as fat fender headers... on the web it shows dimensions(?) to
    be 39" L, 21" W, 11" H. ?
  4. Mike Colemire
    Mike Colemire
    Might look at chevy II headers also.
    Tickety Boo likes this.
  5. Jalopy Joker
    Jalopy Joker
  6. wvenfield
    wvenfield
    Nice ride. The headers you have look like they wouldn't be too difficult to shorten.
  7. squirrel
    you need to build some, so they look right. Spend lots of time looking at old pictures of race cars, to see what they need to look like.
    Fortunately fenderwell headers are relatively easy to make, they are not as constricted as normal headers that have to tuck inside the frame.
    I think it took me two or three days to make the headers for my Chevy II, they turned out fine and make a big difference in how the car looks, compared to buying some that would be a compromise.
    Just Gary likes this.
  8. swade41
    swade41
    from Buffalo,NY
    The Speedway headers should have a diagram with the measurements on it.
    I have some old Mr. Gasket fenderwells
    And those fat fender type, the left header isn't bolted in the back because of steering box interference
  9. 56sedandelivery
    56sedandelivery
    Not to hi-jack the thread, but what is the alternator on your Henry J meant for? I am Butch/56sedandelivery.
  10. C1/C2Guy
    C1/C2Guy
    from Utah
    Thankyou to all for your input and ideas.
    I googled the ****** Super Comp # and Dougs # for a 56 Corvette but nothing came up. Maybe they are discontinued?
    Squirrel... When you built yours for your Chevy II, What kit did you use?
  11. swade41
    swade41
    from Buffalo,NY
  12. SNS FAB
    SNS FAB
    Instead of buying a kit, just get a set of flanges, a pair of formed collectors and some u-bends or j-bends and build your own. My experience with the pre-bent kits is that I have to cut the tubes up to make them work, so I just start with u-bends. Here is a set that I just built for a '41 Willys. I was into this set for about $400 in materials. LYNN'S WILLYS (42).jpg LYNN'S WILLYS (43).jpg LYNN'S WILLYS (44).jpg LYNN'S WILLYS (45).jpg
  13. oldolds
    oldolds
  14. Just Gary
    Just Gary
    @SNS FAB, that's a beautiful set of headers. What did you coat them with? White paint or ceramic coating or??:confused:
    Thanks!
    Sorry for hijacking the thread. Carry on as you were.:)
    Thor1 likes this.
  15. squirrel
    I got a dyno header kit from speedway, but the suggestion to get a pair of flanges, and a bunch of u bends, is a better one.
    The hard part about making headers that look right in an old drag car, is that it's hard to find bends with a large enough radius. They don't make things like they used to.
    Thor1 likes this.
  16. SNS FAB
    SNS FAB
    I had Jet-Hot coat these.
  17. C1/C2Guy
    C1/C2Guy
    from Utah
    Thanks again for ALL the suggestions. You guys are great! :)
  18. SNS FAB
    SNS FAB
    I have a couple suppliers that I get my u-bends from and most diameters are available in 2 1/2" to 6" radius. I usually use the 6" radius to do zoomies. The headers I posted pictures of are 3" and 4" radius bends.
    C1/C2Guy and squirrel like this.
  19. C1/C2Guy
    C1/C2Guy
    from Utah
    Swade41... Where did you get the fat fender ones on your car? do you have a part number? do you have a measurement from outside of collector to outside of collector with them bolted on the engine? I'm guessing about 60". Those or the "Speedway Stock Clip" might work. That would be the cheap easy way out. Maybe I need to put my big boy pants on and build some. I've done that before but remember the long hours it took:confused:
    I talked to CARiD this morning about the ****** Super Comps. I'm not getting the warm fuzzies about them.
    In the Pic above, looks like the Dougs #564626745 are BBC
  20. swade41
    swade41
    from Buffalo,NY
    I bought those fat fendered here locally used for $80 bucks but I think Ebay has some that are cheaper than Speedway.
    I used those stock clip headers on my Henry J, they were stepped from 1 5/8 - 1 3/4, I did redo the lead pipes right off the flange to get the collector where I wanted it on the other end.
    I don't have a total width measurement on any of them, I do know that those Mr.Gasket headers interfere with my tires turning radius on my 57 p/u. I think I have those bolted to an engine on a stand, if I think about it I'll measure those next time in the garage but I'm not interested in unbolting both sets of headers and swapping them around to measure then swapping them back lol
    Here's Speedway's fat fender measurements off the website, you only need to measure your engine to figure out the total width.
  21. sdluck
    sdluck
    upload_2021-3-31_11-4-43.png Sanderson for a 1955-57 chevy
