Technical attaching wood to fiberglass coupe interiors
Discussion in 'Traditional Hot Rods' started by Genek, Mar 31, 2021.
  1. Genek
    Genek
    Hi guys. I am new here. Can you recall anyone posting info on bonding or attaching wood to the inside of fibergl*** coupes? And if they used an epoxy what was the brand name.
  2. HOTRODPRIMER
    HOTRODPRIMER
    The problem with that is if you bond wood to the gl*** itself it was distort the gl*** and you will see where the wood is when you paint the car.
    I am not a authority on this but I am speaking from experience.
    I have heard or read somewhere if you lay gl*** mat in the area you want to add the wood and the gl*** the wood it would not cause any distortion. HRP
  3. G-son
    G-son
    from Sweden
    (Ply)wood is often sandwiched inside the fibergl*** laminate during the manufacturing process, to make stronger areas where things can be screwed to the part. Not sure if that's what you are after, or if you just want a wood inside for looks.
    Not sure I'd want to do the latter.
    /Former fibergl*** boat builder.
  4. Splitbudaba
    Splitbudaba
    Check out my thread Gl*** 32’ 5w. I did a lot of bonding, metal and wood. Used several different products. I think they are mentioned in the thread. The one two part adhesive is used in building high end interior for aircraft. The others are from the boating industry! So far so good! I don’t think they imprinted on the gl***, but if it did the primer and body work will hide it!
  5. tubman
    tubman
    I am into the looooong slow build of a "T" touring with a fibergl*** body. When I cut out the firewall for clearance for the bell housing, I ended up with a big chunk of fibergl*** from the body to work with. When I first joined the "H.A.M.B." over 10 years ago, one of my first posts was this same question. When I didn't get a definitive answer, I decided to do some experimentation. I cut about 10 strips of the oak I was using to reinforce the body and used just about anything I had to make test bonds. I used regular fibergl***, two-part epoxy in a "double hypodermic", JB weld, and a few others. The winner? "Liquid Nails" that carpenters use everyday. When I posted the results, I was warned that over time, the "Liquid Nails" would react chemically with the fibergl*** and discolor or deform it. Over the next couple of years, I checked my test panel a number of times and never saw any adverse reaction.
    When I get back on this project, I'll be using the "carpenters friend".
    dana barlow, clem, loudbang and 2 others like this.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    I bonded wood reinforcements into my fiberglas T body nearly 23 years ago with short strand polyester body filler , the car now has 50k miles on it & believe ms , Illinois rods are NOT smooth . There have been NO failures with bonding & NO " imprinting" or distortion problems that I can see & no one b*** ever pointed any out to me . Epoxy is a better chemical bonding agent but is ( to me) cost prohibitive & unwarranted .
    Nicholas Coe and loudbang like this.
  7. rwrj
    rwrj
    from SW Ga
    WEST System epoxy is pretty standard in boatbuilding. They usually sell it at West Marine stores. Probably other marine stores, as well. System 3 is another good brand. You can thicken epoxy with sanding dust, tal*** powder, and all kinds of specialty powders. It is expensive, but I don't know of anything readily available that will fill gaps and make a stronger joint between fibergl*** and wood.
  8. KJSR
    KJSR
    from Utah
    I would use epoxy to bond it and then lay up over it with gl***. This seems to be a decent instructional video on how to work with the epoxy's....
  9. Splitbudaba
    Splitbudaba
    A little tip , when you prep the area to be bonded, sand the gl*** or wood lightly with 80 grit to make a fuzzy texture, helps in the bonding process!
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    "Marine-tex" is one brand name of epoxy putty that works very well & has very thick consistency , will easily fill 1/4" + gaps .
    Splitbudaba likes this.
  11. I'm going with the construction adhesive myself. But i wonder if the vette panel adhesive that is used to bond Corvette panels on would work in this situation? It's awesome stuff, no mapping, but I'm not sure how good it would adhere to the wood o_O
  12. Genek
    Genek
    Thank you, I will check it out.
  13. Genek
    Genek
    Got it, thank you.
  14. Genek
    Genek
    I need to duplicate the wood that was in a coupe from the factory. To install upholstery.
    G-son likes this.
  15. Genek
    Genek
    I spent years doing Corvettes at a place called Corvette World, San Antonio. When we attached panels we mixed up the resin with a little bit of milled fiber. Milled fiber is fibergl*** powder. I was like a paste when we used it. The panels where located and clamped with clecos. Remember, if you drill holes that are visible 0n the outside, don't use bondo to fill in the holes, the bondo shrinks with age. Use fibergl***.
  16. Oh I'm not building anything fibergl***, i use the bonding agent when i replace fibergl*** panels in my bodyshop. I meant that i would try the construction adhesive to attempt to bond the wood. I use the same vette adhesive to fill any anchor holes.
  17. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    fibergl***ing wood on wont do anything bad, its how many bodies are done by pros.
    however DONT use liquid nails. someone did that to my T body before I got it. I did a LOT of sanding to get those marks out, and they are still there somewhat.
  18. TCTND
    TCTND
    Epoxy mixed with microballoons works well as does urethane construction adhesive. Be sure your wood is absolutely dry and seal it well with West epoxy when installed. Bare wood absorbs moisture and expands and contracts with changes in humidity. If it's well sealed it will be dimensionally stable.
    X38 likes this.
  19. 210superair
    210superair
    from Michigan
    West system is good stuff and I've used it extensively, but in its natural form it's pretty thin and runny. They make additives to make it thicker, easier to sand, etc. But it's stong as can be when cured.
    Nicholas Coe likes this.
  20. Just say the hell with it and get a steel car, problem solved :D
    da34guy and clem like this.
  21. Atwater Mike
    Atwater Mike
    My former team race partner used micro balloons for filler with West System. Thickened it right up, ready to stir and use! (Amazon, 15 bucks a quart!)
    I also used the same mixture on my '23 T for some metal tubing bracing...Thin skin of Bondo applied to the tubing where fibergl*** was to adhere to it. ('Secret trick' of **** Williams, of Polyform Industries)
    Funny, we used the stuff on our 110 MPH control line team race airplanes, never a crack, never an engine mount failure. Balsa to Maple, West was 'Church'!
  22. rwrj
    rwrj
    from SW Ga
    WEST makes all kinds of fillers, from micro-balloons that make an easy sanding fairing compound, to a high density filler that dries hard and strong enough to drill and tap for cleats and deck fixtures on boats. In between is colloidal silica and such for bonding. Like I said, you can also just use wood sanding dust for bonding. Usually ends up a little lumpier than the commercial products, but makes strong joints and fills gaps well. Epoxy is a much stronger bonding agent than polyester gl*** resin or liquid nails.
  23. Genek
    Genek
    Wow ! That is one that I never thought about. Well done on the testing. I am going to try Liquid Nails. Thank you.
  24. Genek
    Genek
    Thank you that was pretty good.
  25. Genek
    Genek
    That seems like good advice, thanks.
  26. Genek
    Genek
    Thanks for the good advice.
  27. Genek
    Genek
    Got it, thanks for the info.
  28. clem
    clem
    How does it stand up to the vibrations from road use ? Thanks!
  29. X38
    X38
    That stuff turns dry and brittle over time.
    clem likes this.
  30. Splitbudaba
    Splitbudaba
    Mix up your resin, take a piece of fibergl*** mat and cut it into 1/4” to 1/2” strands and mix that into the resin. Thickens it right up and it will stay where you put it! Another idea would be to purchase all the interior metal and wood from United Pacific , make your own using their pieces as a template and then return them to get a refund! Sneaky but it would make it easy!!
