Projects Who can build A home made quick change ceter section ?
Discussion in 'The Hokey Ass Message Board' started by 1934calkid, Jan 17, 2021.
  1. Budget36
    Budget36
    I get ya, probably less expensive to put one of those covers on and be done with it;)
    King ford likes this.
  2. RICH B
    RICH B
    @alchemy When I was kid; there was a little old guy that had a small machine shop in an old corner grocery. He had a lot of circle track stuff around and could talk up a storm. He was making a V-8 quick change and if I remember right; he said his measurements started with the pinion, a set of Getz (?) change gears, and a Frankland lower shaft and bearings and developed from there. I think he was making hubs and stuff too; he was always machining raw aluminum castings and Buick drums. Showed me his patterns for the hubs and stuff. Used to enjoy going down there and watching, then one day he was gone.
  3. Kato Kings
    Kato Kings
    from Minnesota
    I used a champ lower shaft and change gears. 10 spline banjo gears. I have it all layed out in cad.
    jebbesen, RICH B and kidcampbell71 like this.
  4. glrbird
    glrbird
    Tim McMastter -y-block guy. Had a guy build him one.
  5. Marty Strode
    Marty Strode
    Pull the rear cover and see if it has bearings to support both shafts. Parham used a floating "Dog Bone" with bearings that slipped over the shafts. Mike Moore does his the same way.
    kidcampbell71 likes this.
  6. hotrodlane
    hotrodlane
    Bob Wilson built a bunch of them in the 90's had a devil head on the rear cover and I think he called them speed demons or something like that. It's not really anything super complicated, Alot of Down Home Dirt trackers built them in the 60's do to the Halibrand 201's constantly breaking in midgets and other dirt track cars. Strip down a Banjo rear and Call Nick up at "Hot rod works" and order a lower shaft and a set of change gears and start measuring and Get-er-done!.. LOL You could try and call Bob at wilson welding. Also John Layne built one recently for his original offset roadster clone. PM me if you want his number
  7. Frames
    Frames
    I built 5. My own design. Much simple than anyone else. sold 3. 2 in my own hot rods. Sold the jigs/fixtures 6/7 years ago. I don't think the buyer ever built one.
  8. Frames
    Frames
    2003-12-31 23.00.00-58.jpg I have one in my 39 Hudson oval track car. Speedway Motors cover.
  9. Frames
    Frames
    GuyW likes this.
  10. Frames
    Frames
    This this the other custom built 201 of my design in my 1930 lakes modified 2013-03-20 14.55.30-2.jpg
    tractorguy, GuyW and kidcampbell71 like this.
  11. Frames
    Frames
    Fixture I made off of a Halibrand to install the front bearing retainer. the wood pattern and misc. stuff to build a custom 201. Sold to a guy in CO. 2012-11-13 08.12.20-1.jpg
    tractorguy, 51 mercules, GuyW and 5 others like this.
  12. Talk to "The Quick Change Exchange" he can fix you up,
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I've never built one from scratch, but I have some pieces that could help a guy get a good start.
  14. Magfiend
    Magfiend
  15. Sending PM
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Parts for someone that wants to fabricate their own QC. IMG_3928.JPG IMG_3929.JPG IMG_3930.JPG IMG_3931.JPG IMG_3932.JPG .
    I believe these are Kolstead (or Kolstadt) from Ohio. The bores are 3 1/2" on center which would enable a guy to use a 10 spline pinion and Champ size change gears. Not for the faint of heart. I would consider selling the castings outright or building a rear up with these pieces, on a time and materials basis.
    PM me if interested.
    tractorguy and kidcampbell71 like this.
  17. Little Terry
    Little Terry
    I have this one under my sprint car. It would be great to find out who bult it.
    jet996 and tractorguy like this.
