Late Tech, for the ladies, how to build a hot rod
Discussion in 'The Hokey Ass Message Board' started by redbeard, Aug 3, 2006.
  1. redbeard
    redbeard
    This is a post for how my lady built her hot rod.
    Now bear in mind she had never picked up grinder or welder, but she wanted to learn, so I showed her what to do. So anyone can do this, we don't have a shop or even a garage, it just takes determination and a little know how, which is here on the hamb.
    here is what she found to start with
    first off she wanted to chop it, so she braced the body and bolted it to a stock model A frame. and started laying out the chop, which was 5".
    I told her to add up the tape to 5", as in one piece of 3" tape and two 1" pieces, it seems to make a parrallel line even if you are not straight.
    this is a trick I actually saw on the hamb, spray paint the tape and then peal it off, that way when you cut the tape doesn't come off while cutting. Works great.
    Here she goes at it. she is very concerned with safety as she works at the hospital, so she had on all her gear.:)
    volvobrynk likes this.
  2. redbeard
    redbeard
    Here is the "roof Off" manditory shot
    And the roof back on
    Now I figured the chop would be a good place to learn how to weld, well it is not that easy on old rusty metal but she learned alot along the way.
    she had some late night help from her girlfriends.
    these are the releif cuts needed to bring the two parts together. And some cool HF clamps.
    here is our "workshop":) got to clean up some day
  3. redbeard
    redbeard
    Now we started mocking up the front end with the stock frame to see how
    much she wanted to drop it. she was pretty set on the rear tire coming up to the bead on the body,
    so the next step was to draw the frame full size from the side and above.
    I used some cardboard from a sheet of plywood, sorry no pic but you can figure it out even if you draw it on the drive way.
    then she started building the frame, by the time she was done with the chop
    she was decent with the welder, and I watched what she was doing.
    I told her to stack the frame rails to keep them the same and clamped together on a big I beam I have.
    then we pie cut them to create the narrowing of the frame as it goes forward.
    this frame was actually made to fit the subrail as you will see later.
  4. evilone0528
    evilone0528
    Dude,that prety cool.I thought my GF was cool,but yours takes the cake.BTW,you live in HotRod Heaven.
  5. redbeard
    redbeard
    the rails were clamped together, again side by side on the I beam and that way the angles would match and the frame would be symetrical.
    then with a couple of I beams on saw horses and shim to level with each other and not twisted, she attached the new frame to the original model A
    frame horns. this way all you see is the orig frame from the fire wall forward, or at least that was the plan.
    LOU WELLS and volvobrynk like this.
  6. skyrodder
    skyrodder
    Awesome!!!!!!!!!
  7. redbeard
    redbeard
    Here is the pile of parts soon to be a ch***is,
    there is a 9", that she went to pick and pull and pull out of a ford truck.
    and a 40 ford front end with old drop axle.
    and the first mock up, sorry for the late night pic, we had a few beers while putting the body on.
    look like we put the mock up motor in
    next up the channel
  8. evilone0528
    evilone0528
  9. redbeard
    redbeard
    Here is the subrail, she cut it out right at the verticle part just in from the door it drops down.
    My idea was we would just make a verticle piece right where she cut it and put the subrail back in.
    here you can see she just used a piece of tubing clamped to the verticle piece and sitting on the frame as a spacer to set the height.
    the body is sitting on pieces welded to the bottom of the frame sticking out
    so the bottom of the body is flush with the bottom of the frame.
    Here is the sub rail trimmed down and put back it place
  10. Comet
    Comet
    Right on! Man, I wish my wife was into it like that. She's very supportive, but never wants to help or get dirty :D
  11. tysond
    tysond
    That's pretty cool. But if she is really concerned about safety let her know she shouldn't wear gloves while grinding.
  12. redbeard
    redbeard
    sHe bought a wood kit for it, and started putting it in.
    and started making a piece to connect the visor to the side panel, normally they nail to the wood, but she didn't like that.
    Here it is welded in, she actually is pretty good with the hammer and dolly for a newbie.
    then with some help from some freinds we took the body off and turned it so she could weld the channel from below.
    next on to the ch***is with the body off.
  13. evilone0528
    evilone0528
    Thats a sharp body too!The car I mean.....
  14. redbeard
    redbeard
    I agree about the gloves, but she didn't like the sparks hitting her and they were welding gloves, she made it out safe.
    She will be happy to hear your guys responce.
    back to the build.
    since she wanted the car so low, there is a kick up in the front.
    but even with the dropped axle it was not enough to have travel.
    So we mounted the spring off of the bones.
    this is just mocked up, I welded it both inside and out. this is one of the few things I welded, and that was cuz she wanted me to do it.
    you can see it that first pic she made a flat cross member out of some tubing
    with the bottom cut out.
    that ended up being to much, as the spring would hit the frame with travel and she didn't want to notch the frame.
    I should tell you that we moved the crossmember back so the wheel base stayed the same.
    so now we jump ahead in the pics as I was working alot while she did the ch***is and she didn't take pics.
    but basically you can see in this pic the ch***is done.
    she wanted the coil overs in the back for a softer ride and the adjustability, as she has had back problems. my hot rod is too stiff for her so she build her own.:)
    A little more info on the ch***is, she used ladder bars that are actually curtis style hairpins modified. and the steering box is a gemmer, exactly like an F1 ford truck, but reversed. I think it was in a fork lift. any how it makes the pit man arm go up, which worked out well.
    I should also point out the front crossmember, we lowered it and that c notch in it is for the lower radiator hose. it is
    heavy wall tubing, so I am not worried. the xmember is actually behind the radiator, since the spring is behind but the
    axle is in the stock location front to back.
  15. Crestliner
    Crestliner
    Man, you better hang onto her. Not may ladies want to work on old cars, much less build one.
  16. redbeard
    redbeard
    Now this is one thing I did on the car, while she was at work.
    the motor is a yblock,292 and as some of you know, it is the ford with
    the dizzy in the back.
    so some interference with the fire wall and getting the dizzy in and out let alone turn to adjust.
    well at first we thought just reverse the fire wall, but as some of you know
    you lose about 4" from where it was to where it will be when reversed.
    so with the fire wall out, I cut off the flat that has the holes where it screws
    in to the tank. and then reversed it.
    well we can't stop there, I wanted the beads to face forward as they should
    and I thought is has kind of a duece feel as far as depth.
    after this was welded, I bolted that flange i cut off back into the body, reversed. I wish I had a pick of this. but it was just the flat part reversed on the cowl,
    then i welded the new reversed fire wall in front of that, so you end up with
    only a couple of inches of reverse.
    here is apic of it with the hole car sorry I don't have a better pic. but it worked out good, you can still unbolt the tank.
  17. Great project.
    Nice do***entation.
    Excellent post!
  18. evilone0528
    evilone0528
    I am in awe........how cool.
  19. redbeard
    redbeard
    here it is with the grill cut down to fit.
    man she did a lot of welding sectioning that thing.
    and here is from the rear
    here is the new motor in,
    it is a 292 bored .40 over, with a clay smith cam, these are solid lifte motors.
    she actually made motor mounts twice cuz the first one didn't leave room for the generator, it was my fault, but she tried again
    and made some side mounts
    actually this pic is before they were done, there are some gussets added.
    and then she had to notch the frame for the generator.
    the front of the frame is step boxed, so the notch does not cut into the boxing.
    She put a 4 speed t-10 behind the yblock, because "I don't want an automatic, people will just think it is a girls car" hahaha
    god I love this woman:)
  20. Harms Way
    Harms Way
    Really great post,........ nice work!
  21. Enjoyed the hell out of that! Will be keeping an eye on your progress, thanks for posting. The best part is yet to come, the feeling of accomplishment you get on that first trip around the block in a car you built with your own two hands.
  22. redbeard
    redbeard
    She started on this thing last november and wanted to drive it to paso,
    so in the end we had to help her some, i wired and plumbed the thing.
    In the end we left a day late, but she made it to paso and back, with no problems except the old tires on the back splitting, but coker was there
    and she had to buy new ones.
    here she is driving it
    and here is how it sits now at the asphault inv.
    I have to admit I am very proud of her, she put in alot of long hours, rain or shine out in the yard and under that car port. she wanted to say she built and she did.
    and now we are going to drive our hot rods to bonneville next week.
    thanks to all of the hamb, as she looks on here and learned a lot.
    she especially studied leadsledmercs build up of his sedan.
    I know I have learned alot of what I taught her from this place, so I hope this post helps someone else build a hot rod.
  23. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
  24. 54BOMB
    54BOMB
    Thats so rad, good looking car!
  25. repoman
    repoman
    Thanks for the post. Great pics, and tips.
    Damn, I'd trade three women who can dechrome a bumper for one that can chop a top.
  26. Kevin Lee
    Kevin Lee
    Super Moderator
    That rips. Great shot of how you/she handled the floor with channeling. Clean.
  27. Brandy
    Brandy
    from Texas
    That's fantastic! She should be proud of herself..........but I don't think this is a tech just for the LADIES, I think encomp***es anyone who's ever thought about building a hotrod, but was unsure of their skill and knowledge.
  28. creepy will
    creepy will
    from sacramento
    What a kick *** ride, She should be proud!!!
  29. i agree. awesome tech and great pics. now all we need is a youtube video with her doing a big ol' burnout or something.
