Projects '34 Coupe Survivor (ish)
Discussion in 'Traditional Hot Rods' started by nutrocker, Jan 31, 2021.
  1. Slick Jimmy
    Slick Jimmy
    from Eden NY
    I love the stance. Overall great job so far!
    Thor1, Stogy and cheddar like this.
  2. saa
    saa
    from Sweden
    Can’t wait to see it finished up
    Stogy likes this.
  3. Great save and great detail shots of the build. Keep the updates coming.
    Thor1 and Stogy like this.
  4. -Brent-
    -Brent-
    Cool car, for sure. Excellent fabrication work. I enjoy all the details. Leaving some original details is a nice touch. Too many folks are quick to erase everything.
    Thor1, Stogy and Tim like this.
  5. He used to be
    nutrocker likes this.
  6. Man—I would love to sit around and listen to this car tell stories.
    Thor1 likes this.
  7. grdra1
    grdra1
    I love everything about this build, f##king awesome.
    JalopyJimbo likes this.
  8. ***Area-51***
    ***Area-51***
    from Ohio
    Great thread! Great build!
  9. Panzerfabrik
    Panzerfabrik
    you make it look easy.
  10. Rocky
    Rocky
    Classified Editor
    34 5_20.jpg Kick**** job so far. You guys across the pond get a lot of respect from me for sticking with a rough project and making a nice car from it. Any time I feel down for running outta money and/or talent while building my car, I read a thread like this and I become very grateful I live where parts are available and reasonably priced. My 33/34 is my 10 year long attempt at making something I've always wanted. Proceed.
    Jet96, RustyBullet, J.Ukrop and 10 others like this.
  11. Panzerfabrik
    Panzerfabrik
    Love your style... Well Done.
    loudbang and Thor1 like this.
  12. 47streetrodder
    47streetrodder
    Wish it was mine. You sure did a nice job cleaning up the frame.
  13. edcodesign
    edcodesign
    Wow, outstanding job !
  14. nutrocker
    nutrocker
    Thank you for all the kind comments
  15. 4ever18
    4ever18
    Wow!! That car landed with the right guy. It could easily have been disassembled and the pieces sold off individually. You’ve taken a once crudely built hot rod and turned it into a masterpiece of a build. The original builders would be so very proud to see how their project has been refined & saved. Wonderful display of craftsmanship & dedication.
  16. So Cal Greg
    So Cal Greg
    Amazing work and attention to detail on this. Awesome car!
  17. KFC
    KFC
    from UK
    Pete’s been slaving away so there’s a few updates
    nerf bars where added, slightly more refined than the original, taillights have been straightened. They where originally cut in with a drill and chisel.
    then we moved on to a roll bar, this will make it legal to 110 on pendine sands but it had to look as period as possible
    next step was get the sectioned grill and bonnet (hood) fitting, it’s now chromed so taped up safely
    The hood needed trimming to fit over the carb set up.
    The grill shell is supported on a frame as we will be running the radiator set back behind the front crossmember, partly for space partly so the grill shell is empty.
    Headlight and shock mounts are next
  18. harpo1313
    harpo1313
    from wareham,ma
    Very nice work, You have a good eye for perfection.
    loudbang, Thor1 and Stogy like this.
  19. Mike Colemire
    Mike Colemire
    You have done one hell of a job, that car looks like it's running 150 mph just setting still!
    loudbang, KFC, Thor1 and 1 other person like this.
  20. Stogy
    Stogy
    Hotrod*****o quadruple x... @nutrocker your Therapy Lounge is full of Positive Ions...thanks for a Daily Uplift to a better place...;)
  21. Stogy
    Stogy
    I'm envisioning a Pairing with Tdogs Omaha Coupe...what a Hotrod Spectacle that would be...
  22. the pinstriper
    the pinstriper
    from duxford UK
    Yes yes yes
    loudbang and Stogy like this.
  23. Squablow
    Squablow
    Excellent metalwork, I especially like the extra efforts used in keeping some of the original bits intact, even when it'd be easier to change them. I understand that some things obviously needed to be changed in order for the car to be safe and to be able to be raced.
    My only question is, why the large engine setback? Was that the only way to clear the hood, or is that another restriction put in place by the race sanctioning body? Looks like in the original build the engine was much further forward and at least some of the original firewall was intact.
    Not complaining, just curious to know why that change was made. I really do like the car. Glad to see it made whole again and able to race as it originally was intended.
  24. KFC
    KFC
    from UK
    The engine was along way forward before and the car just ran a small rad on the front crossmember, you couldn’t have run a grill shell and hood and a rad that would be suitable for the road in that configuration. It did come with a 32 grill shell which I suspect was someone’s plan to solve that.
    And I really wanted a big engine set back, which just made a load of work
  25. Looks like this car has always been treated to the best that the owner could muster. The current owner is sure up to the mustard. It shook me a bit when you cut into that grille, but like the rest of it, turned out great. I’m in on that pairing with the Omaha coupe, very inspiring work!
  26. AHotRod
    AHotRod
    Awesome work
    Stogy and loudbang like this.
  27. KFC
    KFC
    from UK
    Rolled it outside for a good look today 0041A313-C5F4-4AF6-8C45-D8DFB1DA54CD.jpeg 0FDBDE0B-6997-4171-98CA-F028DB0627E6.jpeg 3916788D-3E1B-4DA6-8A8A-A10969C0C2AB.jpeg C473717D-7299-4071-8304-3CE315704CCC.jpeg
  28. 34Larry
    34Larry
    Its a great find and your going the right way with it. The chop looks to be very similar to my 3window.
    loudbang, KFC and Thor1 like this.
  29. hotrodlane
    hotrodlane
    Very nice work! I agree with everything you done accept the hoop sticking out the roof. But it is your car not mine
  30. Magoo motors
    Magoo motors
    love it !!! Thanks for all the photos
    Stogy likes this.
