Technical 241 Hemi starter questions
Discussion in 'The Hokey Ass Message Board' started by 53 hemi, Apr 3, 2021.
  1. 53 hemi
    53 hemi
    I'm starting a 12v conversion on my '53 Coronet.
    It was my intention to use the original 6v starter, but I have a question concerning wiring.
    This starter only has a heavy battery cable connection. My new starter relay has a "sol" connection point which would normally go to the starter. Do I need an external solenoid?
    And are there any aftermarket starters that fit the 241?
    Sent from my SM-G950U using The H.A.M.B. mobile app
  2. jaracer
    jaracer
    I'm a little confused, you say you are going to use the original starter, but also have a new one? A picture of the "new" starter would help.
  3. 53 hemi
    53 hemi
    I have a new starter relay. I'm wiring the car up similar to an early 70s mopar.
  4. Rusty O'Toole
    Rusty O'Toole
    Old Chrysler products used a starter relay but it was set up a little different from a Ford. You could get a 12v Dodge relay, or use the sol connection to byp*** the ballast resistor for starting.
    53 hemi likes this.
  5. 73RR
    73RR
    I wondering what trans and flywheel/converter is in the mix.
  6. 53 hemi
    53 hemi
    It's the stock trans and flywheel. I think 146 tooth and 3 speed stick.
    stillrunners likes this.
  7. 73RR
    73RR
    If the engine starts quickly then the 6v starter will be ok with 12v. If it is hard starting then the starter will over heat and soon die.
    stillrunners and 53 hemi like this.
  8. 53 hemi
    53 hemi
    Yes, I understand this. At this point I just want to run the old starter until it fails. Then go through the painful process of adapting a modern starter to fit.
    I'm currently trying to get the starting circuit wired up.
  9. 73RR
    73RR
    IIRC there is a 'new' 12 volt starter available from Promaster as a direct replacement.
    53 hemi and stillrunners like this.
