Hot Rods Lincoln King Pins
Discussion in 'The Hokey Ass Message Board' started by mcbay, Apr 4, 2021.
  1. mcbay
    mcbay
    We have here a 32 Ford axle with Lincoln spindles which have larger king pins. Has anyone used this combo..? and how did or would you handle the spindle bushings?
    It is interesting that the Ford bushings fit inside the stock Lincoln spindle bushings but not sure this is a good idea.
  2. 19Fordy
    19Fordy
    What year are your Lincoln spindles?
  3. seb fontana
    seb fontana
    from ct
    ""It is interesting that the Ford bushings fit inside the stock Lincoln spindle bushings but not sure this is a good idea.""
    I knew there was a difference but not that much! If the fit is reasonably good a good cleaning, scuffing and mild knurl on od of Ford bush; Loc***e and press together?
  4. mcbay
    mcbay
    They have the deep backing plates. Its been a while but I think they are later 42 -46
  5. mcbay
    mcbay
    I am concerned about doubling the thickness of the bushings.
  6. Fordors
    Fordors
    A Ford axle uses spindles that have an 8 degree king pin inclination, and while I’m not sure about your later ‘42-‘46 Lincoln spindles the earlier Lincoln spindles are only 4 degrees KPI.
    If you do somehow complete this swap you will need to have the axle bent to correct the camber.
  7. X38
    X38
    ^ I was wondering about this.
  8. drtrcrV-8
    drtrcrV-8
    If the Ford / Lincoln kingpins are that close, why not bore(hopefully in a mill) the axle for the Lincoln pins/bushings? I've never liked adding "Mickey Mouse" to something that needs to be kept "KISS"!! ("Keep It Simple Stupid", for those who ask...)
  9. mcbay
    mcbay
    Yes the KPI is different. I thought about using Lincoln king pins....
  10. mcbay
    mcbay
    I was hoping someone had done this....
  11. X38
    X38
    If you hog out the axle, you loose material strength there. Why not sleeve the spindles then use Ford bushes?
  12. mcbay
    mcbay
    The KPI has been set up for the Lincoln spindles. I may just leave the old larger bushings in an Loc***e new Ford bushings or use the Royal needle bearings.
    jackandeuces likes this.
