Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. guthriesmith
    guthriesmith
    Today was the trip back to Oklahoma from Missouri...so, drive for a few hours.
  2. 33Doll
    33Doll
  3. Russ B
    Russ B
    Starting on a new steering wheel for the 51. Spent the day doing layout for drilling the hub piece. The reduced size rim has been rolled. After the hub is done, I will work on spokes.
    Style is of the 1953 Buick.
  4. guthriesmith
    guthriesmith
    Yep, perfect weather for a drive. We ended up putting about 700 miles on the 56 and T-bird over the weekend. Great time with lots of great friends too. Happy Easter to you too!
    chryslerfan55, Lil32, 40two and 2 others like this.
  5. MCjim
    MCjim
    from soCal
    Put some 35 year old NOS Simpson belts in my pile...not very exciting, I know. IMG_5098 (2).JPG
  6. DuaneBallard
    DuaneBallard
    received_466357797748100.jpeg received_149614697072378.jpeg 20210404_165313.jpg
    Eliminated the lower trim on the driver's side of my 66 300. Now on to the 24 holes on the passenger side.
  7. oldiron 440
    oldiron 440
    Looks like the boss is putting her foot down and saying don't forget about me. Lol
    chryslerfan55 and SEAAIRE354 like this.
  8. Rocky
    Rocky
    Classified Editor
    Mounted my new 4"X15" ET front wheels on a pair of 5.60 skinny radials and swapped 'em out for the fat 14" wheels/tires that were on the car. Took it for a drive to see if I needed any front wheel balancing. Nope, they're perfect with absolutely no wheel weights !!!!! Drove it past Tdog's place and showed him... 34newtires.jpg 34newtires2.jpg he liked them but they show even more of my rotors and calipers. drove it home and completely blew off any work on my new Muncie transmission but I did fire up my new 50 Pontiac coupe project..still has a miss. Gotta do some weed and feed on my yard tomorrow.
  9. 31hotrodguy
    31hotrodguy
    Looking good Rocky!!!
  10. Now THAT is a good looking pooch!!!
  11. TA DAD
    TA DAD
    from NC
    Sometimes it is so repetitive ! after looking at a whole lot of gas tanks, and coming up with one to fit my application ( tank is a 65 Chevy II ) you can get the pick up with a 5/16 or 3/8 line. The bottom straps are for the Chevy II the top ones are homemade. The best part it is all done. studebaker build 004.JPG
    chryslerfan55, Lil32, 40two and 4 others like this.
  12. bchctybob
    bchctybob
    The headlight rings and shock mounts came back from the chrome shop so yesterday I completed the switch from big stock type headlights on a stock bar to smaller hot rod lights on a dropped bar. Part of the ongoing attempt to de-Resto Rod my Model A. I also rewired the front harness to lose a bunch of tacky splices and upgrade the grounds. I removed the stainless conduit and replaced it with black Ford braid that I trimmed from the '36 taillight changeover. Here's the before and after.
  13. bchctybob
    bchctybob
    With the headlight task complete I had to address the spinning ignition switch in the Model A. I guess it's a '64-'65 Olds ignition switch with a '55-'56 Chevy bezel and nut but it's made to fit into a double D hole, my wooden dash has a round hole. I really like the switch but it's all round and smooth. Tighten the nut and a few days later it's spinning in the hole again. I found a 1/8" thick brass washer in my junk, drilled and tapped two holes to 4-40 and put a couple sharpened pieces of a 4-40 screw in the holes. Using a drill I put two divots in the front of the switch housing for the pins to index with. The other end of the pins will bite into the back of my wooden dash. I put it together and no more spinning switch. It's sorta temporary since I really would like to redo the dash with old SW gauges in a steel dash (I'm not a wooden dash guy) but I have to admit, it's growing on me the more I drive it. The finish is well done and reminds me of the finish on an old Les Paul guitar I used to have. If it ain't broke........
    (That's not the car's ignition switch, it's just a spare one I used to fit check everything so I wouldn't have to keep climbing in and out of the car.)
  14. guthriesmith
    guthriesmith
    Got the window channel welded up and the door all put back together on my brothers Buick this evening. Next is to sand and buff it some and raise the front up a little bit to get just a little more ground clearance for the crossmember before the trip up to Michigan in a little over a week.
    1552AA89-6B38-47E6-AE7D-D35762BD81B1.jpeg 5155888F-858A-4DA8-91AB-B9BB121BEC0A.jpeg
  15. LAROKE
    LAROKE
    From the BillyBob Shop log
    April 8th 2021 Started setting up a DIY hot tank for the engine cleaning. Cleaned a plastic trash can the landlord's contractor left behind when he absconded with my fourteen foot step ladder. Found a hole in the bottom which was probably the reason he left it. Ordered one off the intarweb.
    Filled it with water and lowered the nailhead block into it. Placed a submersible spa pump for circulation and a submersible heating element, digital thermometer and a small amount of Dawn dishwashing soap and watched a bit to see that the suds didn't get out of control. Background music was Stone Free, A Tribute to Jimi Hendrix.
  16. 57 HEAP
    57 HEAP
    Put some loc-tight on the threads of that oil filter******* to be sure it stays in the adapter.
  17. 31Apickup
    31Apickup
    Been working on stretching the hood on the coupe. Will have to update my build thread with additional photos [​IMG]
  18. Tim
    Tim
    from KCMO
    Holy***** @Rocky thats a bad man right there! Looks fantastic
    31hotrodguy likes this.
  19. Hamtown Al
    Hamtown Al
    Got a couple of them out for breath of fresh air!
    Dang alt on the 36 doesn't want to work!:eek: Dang thing must have gone to sleep over it's long rest on the lift!:D
    Chrome replacement on the way.:) Opportunities!:D
  20. olds vroom
    olds vroom
    Took my roadster out 25 miles with a fresh engine back for an oil change and put another 50 miles on it.
  21. TigerFan
    TigerFan
    from Athens, GA
    I chopped 2 1/2” out of my ‘32 grille shell.
  22. Dago 88
    Dago 88
    Gave the old truck a bit of a clean up, taking the little lady out for Mexican Dinner tonite. :) 172246990_907101490025049_6655608148739580689_n.jpg
  23. Greg Rogers
    Greg Rogers
    Yea, more color finally, a little more work and I can reassemble for the summer, next stage is next winter. IMG_3217.JPG IMG_3219.JPG IMG_3218.JPG IMG_3217.JPG IMG_3219.JPG IMG_3218.JPG IMG_3217.JPG IMG_3219.JPG IMG_3218.JPG
  24. LOU WELLS
    LOU WELLS
    from IDAHO
  25. guthriesmith
    guthriesmith
    Raised the front up on this about an inch and had to go drive it to see if the crossmember has enough ground clearance to drive. Much better now and about ready for the trip to Detroit next weekend.
  26. warbird1
    warbird1
    Did this today... finally the '31 A project is under way. Now to strip all the little brackets and etc. out of the back end of the body so I can get rid of that mess and start on the frame. Sorry about the wheels... they will go away before it goes back on the road. roadster4.JPG
  27. e1956v
    e1956v
    Alliance Vendor
    My grandson came over and we tackled scraping and cleaning up the rest of the floor boards on the 56 so we could have a clean surface to lay dynamat and the new carpet. Also cleaned and scraped the windshield channel so next weekend we can drop the new gasket and windshield frame back on the body.
    Got the seats back from the upholstery guy so we will be ready to get the interior back together. IMG_1085.JPG IMG_1086.JPG IMG_1087.JPG IMG_1089.JPG IMG_1090.JPG IMG_1095.JPG
  28. HOTRODPRIMER
    HOTRODPRIMER
    I spent a couple of hours laying in the floorboard of the wagon with my head under the dash.
    I have been procrastinating for several years with repairing the windshield wipers that quit in a blinding storm coming home from Knoxville, Tennessee and have been relying on Rain-X ever since.
    We never give any consideration to how difficult making a repair will be in the future when we are running wire, fuse panels, radios, switches & cables, not to mention air conditioning and hoses.
    Add to the fact the wiper motor is very close to the windshield and due to the accident I had a few years ago my range of motion in my right arm is not quite what it was before the accident so I did most of the work left handed, but I managed to get it repaired, this time I used some lock-tite on the set screws, the main problem was that darn double loop spring. :D HRP
    It was a PITA but it's the kind of accomplishment that makes you feel like you did something, I would imagine my back will know I did something when I get up in the morning!
    chryslerfan55, 40two, X-cpe and 10 others like this.
  29. 31hotrodguy
    31hotrodguy
    Looks good Rusty! A beige interior is my favorite for the early corvette!
    chryslerfan55 and e1956v like this.
  30. guthriesmith
    guthriesmith
    Took off some braces and brushed some teeth. The braces (grill guard) was ugly, but sure protected the nice grill.
    chryslerfan55, 40two, LAROKE and 3 others like this.
