Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Elvis100
    Elvis100
    Made a new trunk lid latch support panel, or whatever it’s called
    brEad, kidcampbell71, rpm56 and 9 others like this.
  2. Elvis100
    Elvis100
    Got the trunk latch bed panel formed, now to drill all the mounting holes and install the captive D-nuts
  3. Elvis100
    Elvis100
    I spot welded some 5/16-24 captive nuts on the back of the support panels. I had welded some fixed nuts on my coupe and they worked pretty good. Without these you have to lay down on the floor with both arms outstretched to install these bolts once the quarter panels go on.
    Still a few more holes and the D-nuts, but all the new panels are clicoed in their final position with everything fitting pretty good
    Ottomotive, brEad, agshelby and 8 others like this.
  4. AmishMike
    AmishMike
    Learned to hate “captive nuts” working on Jeep’s. Try to unbolt & rusted captured nut breaks free & turns. Now drill holes in body or burn off to get out bolt then cut access to re-bolt. Hate them. Old age & rust killing us all... smile
    dumprat, Elvis100, loudbang and 2 others like this.
  5. neds29
    neds29
    You make it all look so easy. Nice work.
  6. Elvis100
    Elvis100
    Thanks
    Stogy and loudbang like this.
  7. Squablow
    Squablow
    Your work is excellent as always, but can I ask why you made a new section in post #452 when it looks like the original is in excellent shape? Is that other one borrowed from another car, or was it damaged in a way that isn't obvious?
    Elvis100 and Stogy like this.
  8. Elvis100
    Elvis100
    Thanks. Yeh, I’m planning on using both the original trunk panels on my 33.
    Stogy, loudbang and Squablow like this.
  9. Elvis100
    Elvis100
    Finished up the D-nuts and holes for bumpers. The bumper hole has a lip on the underside, I undersized the hole and used some improvised tools and it worked great!
    Started on the rear corners now that I have a good foundation
    Ottomotive, brEad, loudbang and 3 others like this.
  10. Squablow
    Squablow
    Are those quarter panel end pieces the ones that Howell's sells? I was thinking about using those but wondered what kind of quality they were. I've got enough sheetmetal bits to make up the rest of the quarters if I had those pieces.
    loudbang, Stogy and Elvis100 like this.
  11. Elvis100
    Elvis100
    I got these from SAR, but they are the exact same as the ones from Tom Bay and Howells. I’m not sure who is actually making them, but they are all made by the same company/person. They seem okay, we will see once I get them installed.
  12. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    You’re a great instructor, plus this thread is invaluable to all model 40 enthusiasts. Especially me!!!!!! Thank you again my friend ;).
  13. Rocky
    Rocky
    Classified Editor
    wow...I had no idea the roadsters and phaetons had so much wood! Nice work.
  14. rusty valley
    rusty valley
    So, you have a tool to crimp the D nuts in place, or you tac them ?
    Elvis100, loudbang and Stogy like this.
  15. Elvis100
    Elvis100
    I use the ball end of a tie rod stud and a hammer. The round end pushes the flange out and then clean it up with a hammer. I use the same stud in the press when there is clearance.
  16. hotrodA
    hotrodA
    Your talents are waaaay beyond a mere mortal’s.
    Thank you for the tutorial. It’s inspirational to us BFH wielders.
  17. Elvis100
    Elvis100
    Thanks
    Stogy, loudbang and Cyclone Kevin like this.
  18. Elvis100
    Elvis100
    Made a die for the toolbox dimples on the forward quarter panel support. Made the right hand support, my original is a little lacy. The left one will be a lot easier without the dimples.
    Stogy, brEad, loudbang and 4 others like this.
  19. nuppi
    nuppi
  20. Elvis100
    Elvis100
  21. Elvis100
    Elvis100
    A little side project, Turning this heavily modified closed car dash into a 33 roadster dash
    brEad, Stogy, loudbang and 2 others like this.
  22. Elvis100
    Elvis100
    Stogy, loudbang, el Roach and 6 others like this.
  23. uncle buck
    uncle buck
    That explains why you have one in post 459. You are very thoughtful and creative and your work is always amazing
    continentaljohn, Stogy and loudbang like this.
  24. Elvis100
    Elvis100
    Thanks, I have several sizes of those and seem to use them often.
    Cyclone Kevin, Stogy and loudbang like this.
  25. Elvis100
    Elvis100
  26. el Roach
    el Roach
    Great job!
    Stogy, Elvis100 and loudbang like this.
  27. Elvis100
    Elvis100
    Finished up the Frankendash. Did an experiment using vinyl wrap woodgrain. I think it came out pretty good for my first time. The nice thing is you can just peel it off if you don’t like it.
    orbitup, heavydumper, Stogy and 12 others like this.
  28. Elvis100
    Elvis100
    Stogy, el Roach and loudbang like this.
  29. Elvis100
    Elvis100
    I started on the left quarter panel. Tack welded the new corner and offered it up to the car...it fit terribly. I offered up a SAR quarter to double check that there wasn’t something wrong with the under structure. The SAR quarter fit beautifully. I do need to adjust the b-pillar a little, but it was almost a drop fit. The gaps on the door were almost perfect and the height adjustment on the b-pillar should fix. I think I’m going to go with the SAR quarters on this car, and maybe use the original quarters on another car.
  30. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    I can’t even begin to tell ya how fascinating this build is. You’re living my dream in doing this particular project. I’m looking forward to the next installment of this highly educational technology in bringing a dream to reality & doing it in a way that utilizes the old when usable and the craft of metal fabrication when/where necessary.
    Thank You Again.
