Technical TIRES, Make your own Wide White Walls
Discussion in 'The Hokey Ass Message Board' started by Bugman, Aug 3, 2006.
  1. Nixer
    Nixer
    That was awesome..full of enthusiasm. now..tell me how to make a ***** with the same process...HAHA
    tok
  2. Mart
    Mart
    Jeez you made it look a lot easier than when I tried it.
    Great work, excellent video production. Thanks for a very informative post.
    Mart.
  3. fivespoke
    fivespoke
    from Wichita KS
    Great tech, Been wantin to give it a go. Thanks for the encouragement.
  4. Awesome....looks so easy in the video.
  5. skawars1
    skawars1
    from Chicago
    Great Post. I think I know what I'm doing this weekend.
  6. lindross
    lindross
    That's too cool! I've always heard that can be done, but never saw it in action before.
  7. Gotta say, video certainly raises the bar. Now I just need to be fast like Superman and I can grind my own whitewalls.
  8. Flathead Youngin'
    Flathead Youngin'
    and it's on the cheap...
    great job!!! video is very cool for tech.....reading something is NOT the same as watching something....
  9. Thank you for taking the time to enlighten us all. Mark
  10. skyrodder
    skyrodder
  11. Hotrob
    Hotrob
    from DFW, TX
    Yea I gotta say so far this gets my vote!
    Hotrob
  12. 8mpg
    8mpg
    from Texas
    awesome!!!
  13. Bazooka
    Bazooka
    Great tech. Thanks alot. I might have to give this a try...... Best Tech so far
  14. ford.slaughter
    ford.slaughter
  15. KKustoms
    KKustoms
    That Rocks!! I have been wanting to try it for a while, now I have to!!
  16. av8
    av8
    Excellent, Jeff! Thanks for sharing.
    Mike
  17. Bugman
    Bugman
    Thanks for all the kind words. I really didn't expect this big a response. I didn't really think about it before you guys mentioned it, but you're right, this is my teacher side starting to show through once again.
    About my grinding discs, I got them from the now defunct Machine Shop Supply that was a subsidiary of Lab Safety. I got a bunch through school when MSS went under. I think they are now sold by Rotozip, but I'm not 100% sure. Either way, a flexable disk without a backing pad works tons better than a stone disc does.
    I haven't really noticed a width/brand pattern yet. It's pretty inconsistant. I believe a RWL will be wider than a narrow WW, but again it varys. Even within the brands, different style tires are wider than others. I did notice however that Coopers seem to have the smoothest outer edge. The last set of Goodyears I did were pretty wavy. Since I'm perpetually on a budget, I always use new used junk yard take off tires. They range from $10-$15 a tire around here.
    Haring, I was very very close to putting the Benny Hill music in the background. It's hard to use speeded up footage without it(course I didn't speed anything up, I really am just that good...:D )
    Tingler, yes, my real name really is Jeff Tanko
    Tok, you need to start with a thicker chunk of rubber...
  18. zealot9802
    zealot9802
    from SoCal SFV
  19. rebarsfords
    rebarsfords
    Dude, that is awsome! Thanks for sharin the vid. I had heard that was
    possible, but I didn't know all white walls were like that.
    Cool-a-mundo!!!
  20. BigBlockMopar
    BigBlockMopar
    Real good video!
    I might add from experience that General XP2000 RWL-tires are unsuitable for grinding a white wall on them.
    The outer line is very irregular and I also noticed a 'starting line' in the white parts.
    270283
    Much appreciated post. Thanks.
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Well done Jeff!!!!!
  23. mackster
    mackster
    I am amazed at your skills, thanks bugman, I hope others follow your example and show us other neat tricks!
  24. Dirk35
    Dirk35
    A+ Tech!!!
    Well done Video too! Kudos bro!
  25. Dunlop Rover ATs work pretty good, The only thing I did different was I left them on the wheel. It made the sidewall more stable and I felt, less likely to gouge the white.
  26. Gator
    Gator
    from Statham Ga
    Fantastic, I can't wait to grind up a couple of scrub tires for practice.
    Thanks!
  27. Rocky
    Rocky
    Classified Editor
    Cool, Jeff...I'm gonna tackle the skinny whites on my Rambler, now that I know the trick.
    Hey, you oughta be a teacher! Bahahahah...
  28. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
  29. sodbuster
    sodbuster
    from Kansas
    Very cool tech........I can smell the burnt rubber......I also thought of Benny Hill chasing the front sump shaking gals around when you sped up the video.
    Chris Nelson
    Kansas
  30. Bugman
    Bugman
    4t64rd, I've tried it both mounted and unmounted. I found that with the tire unmounted it was easier to get down near the bead, but like you said, the sidewall was softer and gouges easier. I still prefer unmounted though, but it's just my personal preferance.
    Another tip I didn't mention, try to keep the grinder as flat as you can. The steeper the angle, the easier it is to gouge the WW.
