History Old Chrome Big Car Frame ID
Discussion in 'Traditional Hot Rods' started by Carter, Apr 7, 2021.
  1. Carter
    Carter
    So, I've long wanted to put together a couple three spring cars, one a lakes modified ala Art Gerrick or Bob Giovanine, and the other a Legion Ascot Cl*** B type big car. As such, I've gathered up some parts for these future builds.
    I had narrowed and shortened a 20s Chrysler frame for the lakes car, and had sourced a perfect Es*** frame for the big car.
    However, when a pair of old chrome Es*** frame rails popped up for sale recently, I decided those would make an even better platform upon which to build. Problem was, they were way up in Minnesota, far from Pennsylvania, and I really didn't want to make that drive, despite the good price. I got lucky and was able to find transport for them, so I bought them.
    It took a few weeks to get them in my hands, but as soon as I did, I knew immediately they were not Es*** rails.
    What they are is even better. What they are, as I'm sure most of you were able to deduce from the thread ***le, is a pair of old chrome three spring big car frame rails.
    They appear to be nicely built as well, showing excellent craftsmanship. They've not been modified and have only one old weld repair on the inside of the right rail near the front spring rear hanger. Based on witness marks and discoloration where the shocks, spring mounts etc were bolted, it was an ***embled car at some point, so it's possible that it was a restored/museum car that got pulled apart to use the engine in the restoration of a better known car or something similar. I'm hoping that someone will recognize them one way or another.
    The frame shape, both at the front and rear, as well as the location of bolt holes will be what will identify it if its iden***y is to be found.
    From studying pictures I've noticed some similarities to some restored cars, which might indicate the same frame builder, but nothing close to definitive.
    Thanks in advance for any insight, suggestions, information, etc.
    IMG_20210322_183651714.jpg IMG_20210323_204218819.jpg IMG_20210323_204229521.jpg IMG_20210323_204239362.jpg IMG_20210323_204248207.jpg IMG_20210326_180611787.jpg IMG_20210326_180812743.jpg
    Okie Pete, 2Blue2, Outback and 11 others like this.
  2. alchemy
    alchemy
    Josh Shaw seems to be an expert on these cars. Have you contacted him?
    Or Bobby Green? They are both HAMBers.
  3. Carter
    Carter
    The last pic in the first post and the next pic below show the four holes where the front spring rear hanger would bolt, and if you look closely, you can see the outline of the hanger that used to be bolted there. Just in front of that inverted triangle hole pattern you can see the rearmost hole for the front shock.
    At rear, just before the frame kicks up, you can see where it looks like a Houdaille type shock had been bolted in the pic below.
  4. Carter
    Carter
    alchemy, I've talked to Josh already, and I think Bobby has seen the pictures also. Thanks for the suggestions, though!
    Outback, Deuces and chryslerfan55 like this.
  5. millersgarage
    millersgarage
    the upturned flange on the top rail is unusual.
    Interesting find
    Deuces and Carter like this.
  6. Carter
    Carter
    @millersgarage
    That's fairly common on big car frames from the 20s through the end of the rail frame cars.
    This would obviously not be the case on most frames made from modified production car rails, but for purpose-built racing frames like these, that was the way. As an example, the Miller frames were made this way, as were the frames made by guys like Myron Stevens, Clyde Adams, and others.
  7. Carter
    Carter
    Here's pictures of two Clyde Adams-built cars with similar frames.
    Okie Pete, Outback, 302GMC and 6 others like this.
  8. I don't know what your intended use for the car is once it's completed but a guy I used to work with bought a T-bucket that was clearly an old build. It had a chrome rear end in it. I was absolutely stunned at the number of major repair welds that could be seen on the housing. Not where brackets had once been (my opinion) but welds where the housing or axle tubes had broken/split open ... all obviously done after the chroming process (silver paint attempting to cover welded area). I do not know the history of the car or the history of the rear end (was it always in the Bucket?) but a T-bucket weighs pretty much nothing and this car had a mild SBC in it so I am ***uming the rear end was failing/needed repair because of the chroming process and hydrogen embrittlement. Again, just an ***umption on my part as to the cause.
    Apparently there is a somewhat newer chroming process (post-chrome baking maybe?) that limits or eliminates hydrogen embrittlement but I have no idea if there is a way to determine if the process was done on a finished product.
    Not trying to rain or your parade or take the wind out of your sail, just something you might want to think about as there may be a very good reason why those rails were for sale.
  9. Carter
    Carter
    The seller didn't really know what they were. Can't imagine hydrogen embittlement ever entered into the equation as to their reasoning for selling.
    A great many racing cars of this era and others had a large amount of their components plated, cars that ran hard on dirt tracks, board tracks, asphalt tracks, even the bricks.
    While hydrogen embittlement is certainly a possibility with any old components, especially those that have been plated, I'm not terribly worried about these rails. Any cracking that would occur with future use would likely present long before catastrophic failure.
    If the rails can be identified as belonging to a specific car, I'll do my level best of recreating said car, and if they cannot be identified, I still plan on putting a car together around them. Either way, it won't be a street-driven car, though it will certainly get flogged on dirt from time to time if I have anything to say about it.
  10. Sounds good :)
    I just wanted to make sure you were aware :)
    Carter likes this.
  11. Squablow
    Squablow
    I am not much help, but an overall picture of the rails, along with measurements for scale, might help ID them, over the choppy closeup pics.
    I can't imagine what car went through the expense of having the frame chrome plated and then was parted out later. This thing has to have a history. I will say I'm very intrigued.
    Outback, clem, Stogy and 3 others like this.
  12. Carter
    Carter
    @Squablow
    Fair point on the pictures. I'll try to get some better ones tonight, and some good measurements this weekend.
  13. Max Gearhead
    Max Gearhead
    from Wisconsin
  14. Pete Eastwood
    Pete Eastwood
    from california
    You have a real treasure with those frame rails !
    I know a little about Clyde Adams cars .
    I did a lot of the restoration on the car in this picture .
    The fellow standing behind it is Steve Huntzinger ,
    he did the paint & final ***embly of the restoration .
    Okie Pete, Outback, 302GMC and 17 others like this.
  15. Carter
    Carter
    @Pete Eastwood
    Thanks! I believe I read that you and Steve had done the restoration on that car. It's an absolute beauty!
    Do you have any pictures during the restoration by chance?
  16. alchemy
    alchemy
    This one could use a little chrome.
  17. Pete Eastwood
    Pete Eastwood
    from california
    Lots of pictures !
    deucemac, Stogy, Deuces and 3 others like this.
  18. Pete Eastwood
    Pete Eastwood
    from california
    It's going to get some Nickel plating .
  19. This thread is bad***. I gotta subscribe!
  20. noboD
    noboD
    Hope you find some history, will be following.
    Carter and chryslerfan55 like this.
  21. hotrodA
    hotrodA
    Great find!!
    Tagging along, as I also have everything to build a early sprinter:
    Es*** rails, aluminum body, that I think is a Dreyer, OHV Alexander B, Franklin steering, front and rear suspension, and wheels and tires. A collection of parts, nothing from the same car.
    It, unfortunately, keeps getting rotated back in the line.
    Keep yours going!
  22. Carter
    Carter
    Thanks! Hopefully I can figure out some history on these things, but if not, I'm still thrilled to have em.
    Thanks, I hope so, too.
    Nice! Sounds like a fantastic pile of parts from which to build a car!
    I did a quick and dirty mock up today, just for fun. 20s Chrysler tube axle, Franklin steering box, Buffalo #4HC lock ring wheels.
    Might not end up using any of these parts depending on how the research goes, but it definitely helps get the thought process kick-started.
    Okie Pete, V8-m, Lil'Alb and 15 others like this.
  23. 62pan
    62pan
    Why isn't the Hal in that mockup?
    Carter and Retson the Racer like this.
  24. He has a HAL engine?!? Jealous!
  25. Carter
    Carter
    Just a HAL SOHC head, not a full HAL.
  26. SOHC, that cam is driven by a worm gear on the front right?
    Outback and chryslerfan55 like this.
  27. Carter
    Carter
    The HAL SOHC and I believe the DOHC have chain driven cams.
    Outback, 42merc and chryslerfan55 like this.
  28. Carter
    Carter
    I think I may have figured out what car these frame rails once belonged to.
  29. Pete Eastwood
    Pete Eastwood
    from california
    Though , Clyde Adams & Myron Stevens & others , built those type of frames , Harry Miller supplied the blue prints . I have copies of the frame prints & the body prints .
    The are ***led "DT 220" ( dirt track - 220 cu in , ), those cars were designed by Miller to be built by others .
    Most builds used a Chrysler axle , Franklin steering & the engine , trans & rearend of the owners choice.
    The frame blueprints give all the pickup points for the suspension , steering , motor mounts etc .
    I believe several of the top notch Legion Ascot cars were based on those prints .
  30. Carter
    Carter
    Pete, the car that I believe these rails are from was built in '36 by Curly Wetteroth. I have seen a lot of similar hole patterns, but every set of visible holes in every picture of this car matches up with the holes in these rails.
    I'm not 100% certain by any means, but it's definitely a very strong possibility.
    Okie Pete, ottoman, Stogy and 3 others like this.
