Projects what have I found in the bush?
Discussion in 'The Hokey Ass Message Board' started by 54 ford coupe, Apr 9, 2021.
  1. It's GM by the looks, I'm in Australia and it has a General Motors Holden's Ltd plate on the cowl, the plate has no ID but is a weight rating. Ch***is 2240 pounds, Gross 5040.
    Can't see any panels or other clues yet but should be able to get a better look next time I'm there.
    Hoping someone recognises that engine to give me a headstart. I don't know if GMH imported built ch***is or just drivelines. 20210409_144836.jpg
  2. X38
    X38
    Truck related.
    Truck64 and 54 ford coupe like this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    @54 ford coupe
    That appears to be a right had drive Chevy pickup from the late’30s upward to early ‘50s. The engine is, I believe, a 216 cu in Chevy six. The reason I believe it is 216 vs a 235 is that 216 engine had a tin tappet chamber side cover that attached to both the head and block. Whereas, the 235 block tappet chamber had a complete perimeter and used a tin cover only on the block portion.
    It is possible that the cowl pictured there is not original to that ch***is.
    Ray
  4. 1934coupe
    1934coupe
    That is my guess also Ray although not in as much detail engine wise, I think GM engine and the ch***is seems to have dual elliptical springs, you can't see them but that seems to be a lever shock mounted to the side of the ch***is much like a GM would have.
    Pat
    Deuces and 54 ford coupe like this.
  5. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  6. By the looks of the ch***is, it was a truck or ute. The sedans with that motor (unless it has had a motor swap) had the "top hat" type ch***is rails . The motor is a "late" stovebolt ( post 34 I reckon).
  7. alanp561
    alanp561
    Good eye;)
  8. lothiandon1940
    lothiandon1940
    ....Leaves of 3, stay away from me!:eek:
    Stock Racer, Deuces, Ford52PU and 5 others like this.
  9. X38
    X38
    Not native to Australia.
    Although, apparently it has found it's way here. I've never seen it.
  10. Yeah the vine wasn't a problem, I was pretty wary of snakes though! Thanks for your input, it gives me some clues to look at more closely next time.
    Had wondered if the cowl was from elsewhere, there is another ch***is there too so will get a better look at everything soon.
    Deuces and chryslerfan55 like this.
  11. squirrel
    If you're interested in trying to find numbers on the engine...look near the back of the block, where the brush covers it, for casting numbers. Might be a long number, and a shorter casting date code. Also there might be stamped numbers, on the pad that is where the distributor enters the block. They will probably be rather rusty and hard to see.
  12. What's found in the Bush
    Stay's in the Bush
  13. Dan Hay
    Dan Hay
    He's gonna need an ocean, of Calamine lotion.
  14. tubman
    tubman
    I see that you started this thread under the subject "Projects".
    You sir, are more ambitious than I.
  15. ol-nobull
    ol-nobull
    Hi. If nothing else there is some free barb wire included. Jimmie
  16. Speed Gems
    Speed Gems
  17. wraymen
    wraymen
    Leaves of 7, feels like heaven. :)
  18. getow
    getow
    Well you have seen it now.. Side leaves look like mittens, will itch like the ****ens.
  19. Fortunateson
    Fortunateson
    I was thinking 216 for the same reason but I can't see the holes where the stove bolts would attach the cover to the block.
    When I was much younger I'd try to explore every "bush" I could find!
  20. Mr48chev
    The frame is 36/49 1/2 ton. The lever shocks ended with 49. The earlier frames had some cast brackets that stuck out in front of the frame horns. 47/49 didn't have those brackets.
    The center crossmember might tell some difference As photos show that they are different on earler trucks than they are on AD trucks.
    If you decide to decode it further the engine serial number stamped on the pad to the rear of the distributor and the cylinder block casting number can probably get you pretty close.
    The black frame is a 41/46 frame note the brackets at the front. Someone changed it to tube shocks with homemade bracket. The rusty one with the engine is a 49 frame. 41 46 frame.jpg 49 Truck frame.jpg
  21. Latigo
    Latigo
    Leaves of 3, wipe with me.
    dan31 and 54 ford coupe like this.
  22. dan31
    dan31
    Lol, you don't want to confuse those sayings
  23. spanners
    spanners
    Don't think that's poison ivy. My guess would be lantana which is nearly as bad.
  24. X38
    X38
    Not lantana;)
  25. Speed Gems
    Speed Gems
    I see what you did there. :D
  26. SS327
    SS327
    It’s a Dodge. No one said it yet.
  27. Truck64
    Truck64
    from Ioway
    Poison Ivy? Pshaw. Watch out for something called "Gympie Gympie", said to feel like a combination of electric shock and acid burns. I think pretty much everything in 'Strya either has thorns or spikes, or is trying to kill you.
  28. 55Belairretrorod
    55Belairretrorod
    from Australia
    Hi Ray, FWIW we also had here in Oz (and I think also the Canadians) what we know as a 'short side plate' 216. It's essentially the U.S. 50-52? 235 but with the smaller bore. It's been known to trick the odd spare parts guy here and there when it comes to supplying gaskets etc. Cheers, Arnold.
    54 ford coupe, Hnstray and squirrel like this.
  29. jimmy six
    jimmy six
    Since we ave an Aussie posting, I will keep what I have found in the “ bush” to myself. A mate!
    54 ford coupe and Deuces like this.
