Projects My 1936 sedan project
Discussion in 'Traditional Hot Rods' started by 43willys, Jan 17, 2021.
  1. 43willys
    43willys
    Im a younger guy that has always had a great appreciation for traditional built cars. I've always been into off topic cars mainly late 60s and 70s but I finally sold one and picked up my dream car, a 36 humpback sedan.
    I bought the sedan as I have two kids under 10 and want to take them out to the shows.
    When I bought the sedan it was all original, front was in primer, wiring shot and interior in sad shape. I've sense rewired it, got the front sheet metal bolted down and started smoothing it out best I can. Here are some pictures. 20191212_155034.jpeg 20201130_204941.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
  2. 43willys
    43willys
  3. WB69
    WB69
    from Kansas
    Nice. Looks like a great start. Gonna be a fun ride for you and the family.
    Stogy and 43willys like this.
  4. 43willys
    43willys
    Some more pictures, the Lincoln brakes i purchased from speedway, going to run 39 front drums and keep my wide 5 wheels, and my latest pickup a 59ab flathead and 39 trans that hopefully will be in good shape and long term will be swapped in in place of the original 21 stud flathead. 20210109_175942.jpeg 20210109_180018.jpeg 20210109_162541.jpeg
  5. 31Apickup
    31Apickup
  6. AHotRod
    AHotRod
    Great choice for a family Hot Rod ... enjoy the fun
    Spooky, Stogy and 43willys like this.
  7. tub1
    tub1
    from tasmania
    Dam nice car I look forward to pic of the car as it comes together , them 30's fords drive great , find a 37/39 front axle brake drums stubs and wishbone and steering box it will steer great and the front wheels will sit in the correct spot
    oliver westlund, Stogy and 43willys like this.
  8. 43willys
    43willys
    Another update, got the rear Lincoln brakes, a reverse eye spring for the rear and we have been sanding on the front fenders, here's my 7 year old son sanding away 20210319_201906.jpeg IMG_20210327_231127_038.jpeg 20210321_225749.jpeg
  9. 43willys
    43willys
  10. Looking great
    Perfect car for a cool family hauler!
  11. milosmith
    milosmith
    Gotta like those '36s... I like the grey color on yours
    Gambler 1962, Spooky, Dooley and 6 others like this.
  12. reagen
    reagen
    Lookin good !!
    Spooky and Stogy like this.
  13. 43willys
    43willys
    Update on the build, I found rust in the frame in the comon 36 spots, I pulled the body and started cutting. At this point the frame is all repaired and painted. Exhaust from reds is all mocked up and gas tank is installed. New brake lines are also ran. Currently working on my 39 steering box rebuild
  14. Stogy
    Stogy
    Congrats on your trip into an older era in Automobile and Go Fast Hop Up...A great make and model to start with...roomy and great for Family...
    Great job tackling the frame...nice quilting, mancave style...;)
    X2 on the Grey
    Spooky, brady1929 and 43willys like this.
  15. F-head
    F-head
    Cool project. a 39 steering box will be a nice upgrade
    Had one in my old 36 and it worked great
  16. Buckster
    Buckster
    Where did you get the reversed eye spring ?
    Stogy likes this.
  17. Roger Loupias
    Roger Loupias
    Great project, and nice to see the little one pitching in on the prep.
    43willys likes this.
  18. 43willys
    43willys
    Posies
    Stogy likes this.
  19. Dago 88
    Dago 88
    Great car , looks like a good start. Here's one I had in the 70's. Got a bit carried away with it. :) O.jpg J.jpg
  20. 43willys
    43willys
    Sorry for a long pause on updates, I got the frame completely done, but not until after taking it all apart again, having it sand blasted and then top coated with Eastwood paint. Re***embled it and the 59a came back from the machine shop. Then I dived into metal work never done that before but so far I have replaced the floors, repaired the trans tunnel and currently working on the cowl bottoms. 20221231_175625.jpg 20221220_002941.jpg
  21. 43willys
    43willys
    Removed the bracing, and main floor is done, on to making the new toe boards
    Spooky likes this.
  22. uncle buck
    uncle buck
    Looking good so far . The floors look like the ones being sold on eBay?
  23. 43willys
    43willys
    Yes that is what I started with, not bad but need work before they are installed.
  24. 43willys
    43willys
    Tonight I started making metal toe boards p*** side is almost done.
  25. Nice car and great work!!
  26. Smokeshow
    Smokeshow
    Looking good so far! Keep up the good work :)
  27. 43willys
    43willys
    Tonight I continued on the toe boards, drilled holes for the pedals, fit the drivers side to the car, bead rolled, marked the holes and bolted it down. Then did the same to the p*** side. I need to do some work on the floor where the toe boards meet but very close to being done.
  28. choptop40
    choptop40
    nice progress..thats a keeper...
  29. 43willys
    43willys
    Last night I modified the floor and finalized the toe boards. Now all the screws work to hold them down and I made a hole for the throttle rod. 20230118_221345.jpg 20230118_231912.jpg 20230118_235128.jpg 20230118_221345.jpg 20230118_231912.jpg 20230118_235128.jpg
    Outback, Kelly Burns and Chris L. like this.
  30. Smokeshow
    Smokeshow
    Hello, any updates on the car?
