Technical Multi Carb Setups -Let's see 'em!
Discussion in 'The Hokey Ass Message Board' started by pkhammer, Apr 11, 2020.
  1. Here is a couple for my v8 60 hp .An original Eddie Myers and an Edlebrock .
    Have the Eddie Myers heads as well ,so up in the air which intake to use , the early chev air cleaners as well . Pairs of 81's as well . 20210327_205318.jpg 20210327_205328.jpg 20210327_205337.jpg 20210327_205355.jpg 20210327_205451.jpg 20210327_205408.jpg
    Dyno Dave, enloe, Deuces and 3 others like this.
  2. Dyno Dave
    Dyno Dave
    IMG_5487 (3).JPG 97[/ATTACH] IMG_5464 (3).JPG An early 216 Nicson intake cast in L.A. Old ad has them painted RED !!! Pair of Chevrolet factory black Carter W-1s, note the C on the carbs and LA in the intake casting... Again one of my favorites... dyno dave
    Lil'Alb, enloe, Deuces and 2 others like this.
    Holley 94's on Offenhauser intake that I recently picked up from a fellow Hamber. I can't wait to get it on my 289 in my T roadster.
    Dyno Dave, WC145, Lil'Alb and 4 others like this.
  4. 1930ModelA
    1930ModelA
  5. Dyno Dave
    Dyno Dave
    A never installed N.O.S dual carb Offenhauser , not the common #1035 manifold. This one was factory finished in the blue, and the rib tops were polished and cast-in part number is 1035-K...Thinking it may have been a custom order or a display piece...Owned it once, didn't remember it, brought it again, detailed the set-up and sold it again. dyno dave IMG_2750 (3).JPG IMG_2696 (2).JPG
    Lil'Alb, enloe, juan motime and 2 others like this.
  6. 65pacecar
    65pacecar
    from KY, AZ
  7. 65pacecar
    65pacecar
    from KY, AZ
    das858, Max Gearhead, Lil'Alb and 3 others like this.
  8. 65pacecar
    65pacecar
    from KY, AZ
    Lil'Alb, Speed Gems, enloe and 5 others like this.
  9. rovertenrod
    rovertenrod
  10. MeanGene427
    MeanGene427
    from Napa
  11. dartracer
    dartracer
  12. lahola1
    lahola1
    from sedona, AZ
    Been running these in different cars since 1970. They work decent as long as I idle above 1000rpm otherwise idle gets finicky. Been thinking about going to a 4 bbl carter carb (getting tired of dealing with Holleys; leaking ,warped metering blocks, etc). My problem is Holleys just look right and nothing looks better than 3-2's. 57 3-2sa.JPG 57 3-2sb3.JPG
    Dyno Dave, WC145, enloe and 3 others like this.
  13. KFC
    KFC
    from UK
  14. 26 T Ford RPU
    26 T Ford RPU
  15. 26 T Ford RPU
    26 T Ford RPU
  16. 26 T Ford RPU
    26 T Ford RPU
  17. 26 T Ford RPU
    26 T Ford RPU
  18. bighemifan
    bighemifan
    Gorgeous engine. Can’t quite tell from the photo..... is that metalflake?
    enloe, Deuces and loudbang like this.
  19. 26 T Ford RPU
    26 T Ford RPU
  20. 26 T Ford RPU
    26 T Ford RPU
  21. 26 T Ford RPU
    26 T Ford RPU
  22. 26 T Ford RPU
    26 T Ford RPU
  23. 26 T Ford RPU
    26 T Ford RPU
  24. 26 T Ford RPU
    26 T Ford RPU
  25. 26 T Ford RPU
    26 T Ford RPU
  26. 26 T Ford RPU
    26 T Ford RPU
  27. 26 T Ford RPU
    26 T Ford RPU
  28. 26 T Ford RPU
    26 T Ford RPU
  29. 26 T Ford RPU
    26 T Ford RPU
  30. 26 T Ford RPU
    26 T Ford RPU
